Question about Holley 1982 Ford F250 Pickup Super Cab 5.8L Mechanical Fuel Pump
Wipers won't return to "park" position or run on low or intermittant
Wipers only work on high and will not park when turned off
    New Friend:
  • 6 Answers
Rust or loose earth connection , wiper switch inner terminals and contacts worn
Posted on Jan 10, 2013
2005 ford escape wiper and washer has no power. cant hear it engage when on but was working a week ago. how can i troubleshoot it and find the fuse
Hi Justin , Do you know what a SJB - smart junction box is and where it is located on you escape ?
Windshield Wiper Operation
The smart junction box (SJB) supplies power to the multifunction switch from the SJB fuse 25 (20A) when the ignition switch is in the ON or ACC position. The multifunction switch supplies power to the windshield wiper motor for the HIGH or LOW/INTERMITTENT input, depending on the multifunction switch position selected. The SJB also supplies power directly to the windshield wiper motor from fuse 25 (20A) when the ignition switch is in the ON or ACC position for RUN/PARK operation. When the multifunction switch is in the LOW, HIGH, or INTERMITTENT position, power is supplied to the windshield wiper motor, which moves the wipers off the park position. Once the wipers are off the park position, an internal switch in the windshield wiper motor switches to the run/park position which directs power to the wiper switch then back to the wiper motor. This maintains power to the windshield wiper motor to complete the wipe cycle. When the cycle is complete, the internal switch in the windshield wiper motor switches back to the park position. If the multifunction switch is in the LOW or HIGH position, power is supplied from the multifunction switch and another wipe cycle starts. If the multifunction switch is in the INTERMITTENT position, the windshield wipers remain parked until the internal relay in the multifunction switch supplies power to the windshield wiper motor. The internal relay supplies power after a time delay that is determined by the 1 of 9 intermittent switch settings.
Jan 08, 2017 | 2005 Ford Escape
'07 Impala Wipers Work Intermittently
Did you check for voltage at the wiper fuse? My info says that fuse is hot all the time. Use a digital multimeter. Everything off, take a reading across battery posts, the generic spec for a full charge is around 12.6 volts. You should get close to same reading at the wiper fuse, hopefully. When checking voltage at the fuse, use chassis ground not the other leg of fuse. There are wiper relays, those are pcb relays, they are soldered into the fuse box, you can't pull them out. Your bcm is also involved with those relays. Your multifunction switch basically tells the bcm you turned on your wipers, then the bcm controls voltage or ground for the relays. You can see wire color for hi and lo speed voltage. Maybe a problem with fuse box or wiring circuit if voltage is low? I hope this was of some help?
Dec 04, 2017 | 2007 Chevrolet Chevrolet Impala LT
Where is the wiper relay
A wiring diagram doesn't show a relay, just a 25 amp fuse in fuse panel under driver's side of dash. Intermittent working is usually from a loose or poor or corroded connection, or the switch is old and tired, or the motor is old and tired.
Here is one way to check, if you have a test light: when the wipers are not working with wiper switch on high, and key is on, pull off the connector to the wiper/washer motor module (in the engine bay, on the firewall) and check if the purple wire has power. If it does, you probably need to replace the module. Inside the module is a park relay switch (to return wipers to down position when turned off) and a circuit breaker between the motor and ground.
If the purple wire does not have power when key is on and wipers on high, the connection is lost between the switch and the module, or the switch may be malfunctioning. The switch has 5 wires, white wire from 25 amp fuse (power in to switch), a pink wire (for the washer motor), a purple wire (high speed wipers), a dark green wire (low speed wipers), and a gray wire (for the park relay switch inside the wiper/washer motor module). If you see a yellow wire also at the module, that is part of the low speed wiper circuit (the dark green wire) coming from the park relay switch and then to the motor.
Good luck. Post back if further questions, or need more help.
Jun 06, 2013 | 1983 Chevrolet Celebrity
I have a 1996 ford Thunderbird. Wipers won't
if i remember right this system is all enclosed as one unit the wiper motor assembly has gone bad
May 23, 2013 | Cars & Trucks
95 Tacoma wipers are in low on intermiitent pos and do not park. Motor test OK
IT SOUNDS LIKE THE WIPER MOPTOR HAS A DEFECTIVE PARK CONTACT SWITCH. THIS IS PART OF THE MOTOR AND YOU MUST REPLACE THE MOTOR TO REPAIR THE PROBLEM
Jun 18, 2012 | Cars & Trucks
Front wippers won't return to off position when turned off
The are contacts inside the motor assembly which are supposed to keep the motor running until the blades are parked; if the motor's just stopping in position wherever you turn the *wipers* off, there's a problem in the motor. If the problem is that the wipers don't park when you turn the *ignition* off, that's normal behavior. While it's theoretically possible to rewire the motor so that they'll auto-park when you turn the engine off, it's more complicated than just swapping a couple of leads, and requires adding some additional parts to the circuit; do it wrong, and the *engine* will keep running instead.
Nov 01, 2011 | 2000 Pontiac Montana
Wipers would not park, customer forced down wiper arm and broke off arm. Now no electric to wipers.
Before 1995 Ford interval wiper systems mainly consisted of a switch, the motor and the interval governor (also called the wiper control module or 'WCM'). The basic wiper systems just parked the wipers at the end of their travel at the base of the windshield and involved just one park switch.
The more complex systems not only stopped the wipers at the base of the windshield, but would actually recess them below the windshield to park them. This involved using two park switches to turn the wiper motor in a reverse direction. These were installed on the Crown Victoria, Grand Marquis, Town Car, Taurus and Sable.
The wiper switch (named 'Multi-Function Switch' on most models) had a common return or ground circuit and two input or signal circuits to the WCM. Basically, the switch was two modified potentiometers that varied the resistance to ground for the two signal circuits. When the wiper switch was placed in the low or high position, the WCM looked at only one of the circuits- the 'mode input' -and controlled the wiper motor accordingly. If the wiper switch was placed in any of the interval positions, the mode input told the WCM that the switch was in an interval position. The WCM then looked at the second input - the 'delay input' - and used it to determine the amount of delay between wipes.
1) To run the wipers on low or high speed, the WCM provided constant power to the wiper motor on the proper circuit to provide the requested speed. Dual park switch motors
1.1 The first park switch operated basically in the same way as the single switch systems.
1.2 The second park switch worked in the opposite manner- when the wipers were off the park position, the second switch provided a ground for the wiper motor. Power and ground were now provided by the park switches.
1.3 When the wipers needed to park, the polarity of the switches changed, and thus provided reversed voltage to drive the motor in the opposite direction.
2) To run the interval wipers, the WCM applied voltage to the wiper motor only momentarily to get the wipers off the parked position.
3) The electro-mechanical park switch made a circuit between the power feed in and the output to the WCM. Power was provided from the park switch through the WCM and back to the wiper motor.
4) When the wipers reached the park position, the park switch made a circuit between the ground and the output to the WCM, and the motor stopped running. The wiper motor and the wiper switch have remained much the same as the single park switch motors of the past.
The main difference is that the switch has become an input to the GEM instead of the WCM.
1) When the wiper switch is placed in the low or high position, the Run-Park relay is grounded by the GEM to provide constant voltage to the High-Low relay, which then provides voltage to the proper circuit of the wiper motor.
2) High-Low relay is in the low speed position unless grounded by the GEM.
3) The park switch not only feeds the Run-Park relay but is now also an input to the GEM. This tells the GEM when the wipers are in the parked position so it can de-energize the Run-Park relay.
4) When any of the interval positions are selected, the Run-Park relay is momentarily grounded to get the wipers off the parked position
5) The park switch then provides voltage to the other set of contacts in the Run-Park relay.
6) When the GEM de-energizes the Run- Park relay, voltage is still provided from the park switch to the High-Low relay and the wipers complete the stroke.
Click over diagrams for zoom:
Hope this helps.
Feb 08, 2011 | 1993 Mercury Grand Marquis
Wipers do not work in intermittent position. They do work in low and high speeds but do not automatically return to the park position. They stop wherever you turn the switch off.
i belive that your wiper switch has gone out on the intermittent side. this is a very common problem.
I hope this helps you
Thanks
Please leave rating
Apr 21, 2009 | 2000 Isuzu Amigo
Holley 1982 Ford F250 Pickup Super Cab 5.8L Mechanical Fuel Pump Logo
74 people viewed this question
Top Holley Plumbing Experts
Gil Shultz
bobalix
rpar
Are you a Holley Plumbing Expert? Answer questions, earn points and help others
