Question about Arris Touchstone Telephony Cable Modem Tm602g/115
Arris modem model TM602G/115 for wireless connection
I am wanting to use this modem with wireless internet is this possible
  • 86 Answers
SOURCE: pulse-dialing with Arris modem?
If you have the current firmware for your modem, it should work with pulse. Arris had to make it's MTA's pulse compatible due to old alarm systems that still utilize pulse dialing.
Posted on Jan 20, 2008
  • 31 Answers
SOURCE: i have an arris tm602gct and cannot connect thru my netgear
Can you connect if you are directly wired into the router?
You may want to try using a ball point pen and pressing the reset button on the back of the arris. Let it reboot and try again.
Some netgear routers come with the wireless disabled out of the box, so you need to be hard wired when you run the CD or if you try to connect through your browser 192.168.1.1
Posted on Apr 09, 2009
  • 31 Answers
SOURCE: Need solution to Networking 2 comps thru an Arris
You will need to purchase a router my friend. The arris does not have a DHCP server built in and cannot assign IP addresses to the work stations. The only way that could work is if you ISP provided you with a second IP address, which would also be extremely unsafe from a security standpoint. Any wireless router should do the trick.
  • 30 Answers
SOURCE: i am looking for usb driver for arris rndis modem
http://www.drivers-fix.net/arris.php. Comcast sometimes has drivers for this device. Use the ethernet connection if you can cause Arris EMTA's usb outputs **** unless your trying to do both which is what I think your doing. If your computer only has a USB connection look for adaptors
Posted on Oct 15, 2009
reyjoshua07
  • 1157 Answers
SOURCE: Arris Model: TM602G S/N: TM02AH1G6 Modem is not
Hi ltuttle650,
If your modem is not communicating with your Linksys router, your Arris modem was most likely installed directly to a PC or Mac when either you or a technician installed it. As soon as it connected it registered your MAC address from your NIC. You need to make your sure that the modem is still talking to the PC or Mac. Please try the steps below.
1. Find out what your NIC's MAC is (go to "Start", "run", "CMD", "ipconfig/all")
2. Copy down your NIC's "Physical Address." That is the MAC.
3. Go into your router's web based utility (Linksys is 192.168.1.1, username:none ; pw: admin) and click on the "Advanced" tab.
4. Then click on the "MAC Address Clone" tab.
5. Type in the number that you copied down. Click "Apply."
6. Now power cycle your Modem while it is disconnected from your computer and router. Power Cycle the router. After everything has rebooted connect the router to the modem and you should be good to go!
In most cases, this should work, and you ought to have internet access now.
If this did not work, the following is a quick fix:
1. Go to the 'Applications & Gaming' tab
2. Click the sub-heading 'DMZ'
3. Click 'Enable'.
4. Click 'Save settings'.
5. Wait for the settings to save, and click 'Continue'.
If this doesn't work, I would recommend calling your cable ISP and telling them that you need a modem that will work with more than one computer, or you need them to send a tech out who is able to set up the internet through a router.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 14, 2011
I need the value for the network address property.
http://www.speedguide.net/routers/arris-touchstone-tm602g-voip-gateway-557
Oct 17, 2013 | Arris Touchstone Telephony Cable Modem...
I have an arris tm602g. What is the IP address to access modem 192.????
Try 192.168.0.1 or 192.168.100.1. Make sure that your pc is connected directly to the Arris TM602G modem and not on a router.
Aug 28, 2011 | Arris Computers & Internet
Comcast installed Arris TM602G/CT Modem yesterday. Attempted to link modem to MAC AIRPORT wireless router. Have net access with my PC cabled to modem. If I hook the modem to the AIRPORT, the PC indicates...
first its a mac so no wonder its broken second its not your modem it would be your router settings. you may want to restore your device back to its defualts then try again.
Apr 13, 2011 | Computers & Internet
I just switched to TimeWarnerCable/Internet. How do I connect two PC's to the Aris TM602G Modem? Then How do I connect my Laptop? Bob
You connect the Aris to a wireless router with say 4 LAN ports.
You connect the PCs with LAN cables to the LAN ports on the wireless router and install a wireless card in the laptop if it does not have one.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
Oct 18, 2010 | Arris Touchstone 300a (CM300) Modem
How do I access my Arris TM602G modem. I want to
Have a look on the Arris website. Go Here:
http://www.arrisi.com/solution/docsis-cable-modem.html
Oct 31, 2009 | Computers & Internet
I am looking for usb driver for arris rndis modem model number is tm602g
Oct 11, 2009 | Arris Touchstone 450a (CM450) Modem
Can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
Sep 28, 2009 | Linksys Wireless-G WRT54GS Router...
Need solution to Networking 2 comps thru an Arris tm602g/ct via a linksys 8 port switch, the seems to be no Usb connection on the modem
Mar 18, 2009 | Arris Touchstone 450a (CM450) Modem
I have an arris tm602gct and cannot connect thru my netgear
Feb 15, 2009 | Arris Touchstone 450a (CM450) Modem
Arris Touchstone Telephony Cable Modem Tm602g/115 Logo
270 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
