Question about GE WPGT9360E Profile Harmony 4.0 cu. ft. Washer with Stainless Steel Basket
We have a ge profile harmony washer, model number WPGT9350COWW and it stopped working. The screen went black . We changed the pcb board, the screen goes on, but there is a message that says "a proble
The serial no. is LG401272M ....top loading ....we have been told that it has to be programmed..how do we do this and is this what must be done, in fact.
5 Suggested Answers
  • 119 Answers
SOURCE: have a message on GE Profile Harmony washer that
Washers - Harmony Washer Error Message or Code
The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
"A problem has been detected with this unit" will be displayed on the screen.
The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Posted on Jan 16, 2010
Jahn27
  • 1554 Answers
SOURCE: GE Profile Harmony Washer WPGT9350COWW. Unit says
There's no specific way in the self-diagnostics that can confirm which specific part is bad. Actual tests must be done at least with the Hall Sensor and the motor. Please be noted that the wiring connections of the Hall Sensor and the motor with the inverter cannot be ruled out completely. It is prudent to make sure that the connections are tight and snug fit as absence of such can result in intermittent connection problem which will trigger the machine to prompt the "motor not rotating properly" warning.
The test needs to be done with the motor is the winding resistance between any two of its three terminals. The normal winding resistance is around 8 ohms between any two terminals. Any significant discrepancy in the resistance readings renders the motor inoperable and it must be replaced.
Measure between pins 1 (blue) and 4 (yellow) and pins 2 (red) and 4 (yellow) with the Hall sensor plugged into the inverter board. Rotate the spin basket by hand. There should be 12VDC pulses as the basket is rotated. If pulses are present, the Hall sensor is good; otherwise, it must be replaced.
It can safely and surely be concluded that the inverter is bad if both the Hall Sensor and the motor show no problem. If you want to verify, disconnect the Hall sensor plug from the inverter board. Check voltage on pins 3 (brown) and 4 (yellow) on the inverter board. There should be approximately 12VDC. If not, the inverter board is bad and must be replaced.
Please accept the solution should you find it helpful and/or informative. Accepting the solution will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Sep 01, 2011
Jahn27
  • 1554 Answers
SOURCE: My GE top load Profile Harmony washer will fill a
The message merely notifies you that there's a problem. Enter service mode in order to get critical information on the status of various components of the washer. This mode will help you identify failed or improper operation of components and systems. The service mode does not use error codes to identify problems. Instead, the LCD screen displays a list of components or systems to be checked if a problem is detected. Once the service mode is entered, all membrane key panel buttons are disabled.
Press the POWER key to turn the washer on. If the washer is on and the HOME screen is displayed, press HELP and the main help screen is displayed. If the home screen is not displayed, press HOME on the keypanel then press HELP to display the main help screen.
Press and hold MY CYCLES and BACK simultaneously for 3 seconds: The control will display any recorded errors. If no errors have been recorded, press EXIT to return to the HOME screen. If errors have been recorded, post it back. A MORE icon will be displayed on the LCD screen if additional problems have been recorded. Press MORE to list additional errors.
Use the BACK pad on the key panel membrane to scroll back through the list. If MORE is not displayed then there are no additional errors. Make a note of the listed errors. Press EXIT, the screen prompts you to unplug the washer before servicing.
Pressing exit clears all error messages and activates the setup mode program. Disconnect power and make necessary repairs. After the problem has been identified in service mode and repairs have been made, the unit prompts you to run a setup/self diagnostic check. The self diagnostic check consists of a series of system tests to ensure the washer is operating correctly. Follow the on-screen instructions.
When all errors have been corrected and the setup/self diagnostic mode has been completed, the washer displays the following screen. Press OK to return the washer to normal operation.
Posted on Sep 17, 2011
richroth
  • 9472 Answers
SOURCE: ge harmony profile wpgt9350 error code serial communication link between main pcb & inverter pcb is down
Take a look at this manual.
Posted on Oct 16, 2012
It reads error is reading or writing improperly, replace main PCB
disconnect washer from dryer and unplug washer for a few seconds. plug it back in and you should get the congrats screen,don't hit the ok button hit start/stop button and power button at the same time. it should bring you back to your home screen.
Sep 23, 2013 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony Washer WPGT9350COWW - Motor is not rotating properly
I once found the lid switch on a model similar to yours that was in between working and literally falling apart. When we removed the front and popped the top the **** thang fell apart. We bypassed it completely and it magically came back to life. Far as I know it still kickin.
Jun 13, 2012 | Washing Machines
GE Harmony washer will not move from problem notification screen.
Press and hold the my cycles button and the back button simultaneously for 3 seconds. This will reset the control panel and allow you to see any stored errors.
Feb 28, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony Clutch probs./Invertert PCB history
Your inverter board is operating 7 degrees over the max temp...
Clear this error be exiting the service mode and run set up ...
if it comes back you will need to replace inverter board....
let me know if you need more help...
Jul 30, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony dryer error message
Possible Solution...
When you get message first try turning off. Open door spin drum one or two times. Close door. Power back on/start.
Works for our problem. Post if this helps.
Oct 29, 2007 | GE Profile Harmony DPGT750EC Electric...
GE WPGT9360E Profile Harmony 4.0 cu. ft. Washer with Stainless Steel Basket Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
