Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer not heating
Hello, recently my dryer stopped heating and a tech told me that I needed a new timer which I bought and installed and now it still isn't heating. Everything else works fine, turns on and spins, turns off if you open the door and buzzes when the cycle is done. I looked in the door to the bottom when it is on but there is no flame and the gas is on. This is the DG4000 Maytag dryer, gas.
  • timnikikuhn Jan 26, 2009
    I have the exact same problem with 2 exceptions... 1. I have an electric dryer and 2. The light only flickers (bulb replaced) when I open the door but stays off.
It was a voltage problem with mine. My negative power supply at the dryer had come loose... which seems like a dangerous design flaw. I tighted all the 220V wires in the back, and it works perfect. The light bulb works now, but still flickers as the dryers is slightly bumped from unloading clothes. Hope this helps anyone else!
Posted on Mar 14, 2009
    Guru:
  • 462 Answers
Do you get a "glow" the glow (orange in color) is for the gas to be ignited. No glow indicates a no voltage problem to the burner or the ignitor is out. Confirm power to the gas valve area 110V usually. If you have voltage the problem is somewhere in the area your in; probably the ignitor.
If you don't have 110 Volts the problem is in the controls. The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1. Hope this helps. With any luck all you need is a new ignitor. Clean the duct out while replacing the ignitor. Because the main thing that causes ignitor burn out is low air flow. A kinked Dryer vent hose, lint, and plugged up fan on the motor are the 3 main causes of low air flow. If yours has little holes in the inside cabinet these can get clogged with lint also and cause a problem. Hope this helps and please rate me accordingly Thank you and good luck.
Posted on Mar 13, 2009
My fridgidaire dryer (gas) stops functioning throughout a timed cycle - I then reset the dryer timer and it doesn't want to operate again. Other than calling a tech to come fix the dryer, what t
Probably the motor behind the knob. I replaced mine in a Kenmore recently. No big deal for someone with average skills. Go to washer/dryer forums. Lots of them. This will have a ton of solutions. Try YouTube
Aug 06, 2013 | Dryers
I have a Maytag Model LDE4916ACE dryer that recently the timer stopped woking two days ago, the next load it did the same went and went now today it does not heat. Any clue?
the heating element has overloaded and shorted out - new heat element is required along with a new timer switch .
Jul 23, 2011 | Dryers
The dryer won't stop running after a heating
Hello, Thank You for using FixYa. I will be helping you today.Replace the timer.It has a bad contact.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Kenmore 64882 Electric Dryer
Stopped heating. Had service repair yesterday and he replaced the ignitor. Does not heat again, even though it warmed up briefly after the repairman completed the job. What else could the problem be?
Hello- Have him come back out (AT NO CHARGE) and check the gas valve coils these are probably not opening the valve, thus letting the gas out. It is a common issue and sometimes we, the Techs, need to sit there and watch the ignitor light the gas for a whole cycle. Often it will heat for 30 minutes and then the coils will stop opening the valve when told to by the timer. It is possible that there is a thermostat issue but less likely. Hope this helps, best regards.
Sep 27, 2010 | Amana ALG331RAW Gas Dryer
Heating part of Indesit ISA60v tumble drying has stopped working. Can you give me info as to where to look im a Electical-tech cheers chris
Hello there chris
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
81f68d1.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
97ed1ca.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
0a798b8.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
7e97613.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Jan 13, 2010 | Dryers
Replaced timer, new one stops turning and doesn't turn dryer off.
Some dryers have a "press guard" setting. This willkeep the dryer tumbling with no heat at the end of the cycle. Usually you can select it on or off and in some cases can set the time. see if you have this feature.
Apr 07, 2009 | Dryers
Samsung dryer is not drying and its new
It ended up being a easy fix. Our old dryer was working fine and had been ran an hour before I hooked up the new Samsung dryer. Therefore I assumed when the new dryer did not work there had to be something wrong with it. There ended up being nothing wrong with it and it was my dryer vent. It was barley plugged which caused it to not heat up properly. I was told that the new dryers have a lot more sensors on them and its very sensitive about needing a clean vent to vent out the heat. My vent was not very dirty, but it had just enough build up of lent in it, it caused the dryer to not vent properly and it would keep shutting the flame off. Blew it out with my leaf blower and now it heats up and dry quick. I hope this helps
Aug 03, 2008 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Maytag Neptune MDE5500AY Electric Dryer Logo
204 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
