Question about Bugaboo Bee Baby Gear
My bugaboo bee 2007 back wheel won't come off. It is rusted and needs replacement.
I have the new wheel, but can't get it on until I can get the old one off!
    Novelist:
  • 200 Answers
Refer to the link....http://shop.bugaboo.com/INTERSHOP/web/WFS/Bugaboo-Bugaboo_US-Site/en_US/-/USD/ViewProduct-Start?SKU=580520&CategoryDomainName=Bugaboo-Spare_parts&CategoryName=Bugaboo_bee_parts
Is this the part you are working with? If so it maybe be necessary to drill out the pin, and depending on the amount of rust may be still difficult to remove. Try this... before trying to remove it again wrap the point where the wheel is attached with an old wash rag, wrap it tightly and secure with some string (wrap it as if you were wrapping an Ace bandage around your ankle) now soak it with penetrating oil, (WD-40 or other parts loosen-er) leave it over night (outside would be best, it smells a bit) Unwrap it and tap a few times to loosen; try again to remove. If that does not work it may need major surgery.
Posted on Jan 11, 2013
  • 274 Answers
SOURCE: our bugaboo bee handle adjusters have had it can
it should be covered under warranty so take it back to the shop and ask them to send it back to bugaboo for a free replacement. Or try www.buggypitstop.co.uk for new or second hand bugaboo spares they might be able to help.
Posted on Feb 11, 2010
  • 419 Answers
SOURCE: does a kiddyboard bugaboo fit to bugaboo bee?
In short, no. There are no buggy boards that are suitable for the Bee.
Hope this clarifies this for you.
Posted on Apr 03, 2010
macnutz
  • 541 Answers
SOURCE: do the 2009 bugaboo bee maxi cosi car seat
I haven't worked on a 2010 (yet) But I'm 99.9% certain you'll have no problem Bugaboo are good at keeping mounts standardized unlike some makes where each year it's virtually a different stroller. With chain store brands they usually are.
Posted on Nov 25, 2010
SOURCE: i need to change the rear wheel on the bugaboo bee
I have the same issue.
Found these 2 websites which may be of some use
http://www.lilimay.com/buggies/bugaboo/spares.php
http://www.buggypitstop.co.uk/Bugaboo-spares.html
Posted on Jan 18, 2011
SOURCE: Hello, one of the rear wheels of our Bugaboo Bee
http://www.youtube.com/watch?v=
Posted on Mar 26, 2011
Bugaboo bee 09 rear wheels
Yes the Bee+ wheels fit you need two 4 mm alan / hex keys to take off the wheel. You could just change the bearings they use a 608zz bearing any bearing or skate board shop would sell but you may need to add a few spacing washers as the Bugaboo bearing has an extended core.
Dec 30, 2013 | Bugaboo Bee Stroller
Can't get wheel off bugaboo bee (to replace it)
Screw the inner bolt back in but leave sticking up by a 1/4 inch then use a block of wood and a hammer to tap inner bolt to force the outer bolt out.
Jan 30, 2012 | Bugaboo Bee Stroller
Bugaboo bee pram won't fold - the white button has jammed. How do I releas it?
Not an easy fix the handle unit is all closed in with pop rivets so you need a drill and pop rivet gun just to open it. Try spraying silicon spay in to the inside of the handle where ever can then pull up ******* the release buttons while flexing the joint back and forth.
Jan 01, 2012 | Bugaboo 192 Cuddy Cabin ORDER TOD Baby...
Bugaboo Bee 2009 back wheel won't come off
Not sure if your problem is removing the Hex bolts or pressing the axel out. Either way what you have tried is all you can do at home. Pop down to your local engineering work shop. They can press is out in no time. Max they'll charge is half an hour around $40 they may do it for free if in a good mood.
Nov 05, 2011 | Bugaboo Bee Umbrella Stroller
I have a problem with my buggaboo Bee plus pram wheels.
Everyone seems to have problems with the bees small wheels. There's an ongoing forum on Bugaboos ask an owner app on Face Book. You're still under warranty so get a new set of wheels from Bugaboo Customer Service also ask for the front wheel washers to fix the swivel jitter problem.
If anyone finds this helpful please tick the box. If it's not let me know.
Aug 25, 2011 | Bugaboo 2010 Bee Stroller
I'm looking for instructions to attach the buggyboard to a bugaboo bee +
I'm not sure the board fits the Bee+ Check with Bugaboo Customer Service If you can find a shop with Mutsy's try their board. It's a far better design and we use one on our Cameleon it has a set of rubber adaptors for the Chameleon. Frog & Gecko but the Bee has a higher and not so wide back bar so check first.
Aug 24, 2011 | Bugaboo Bee Umbrella Stroller
I'm trying to find the bearings on my bugaboo bee to clean them. where are they?
The front wheels are held on by capped star washers. Removing them will damage them so you need to find replacement washers before you try that. The back wheels can be removed but you need two hex keys. I just stick the wheels in hot soapy water, hose off and wipe dry. I than spray with silicon spray. If you are having the infamous Bugaboo Bee front wheel jitters try putting a rubber washer over the swivel pin.
Jul 14, 2011 | Bugaboo Bee Stroller
On my bugaboo bee 2009 model the rear wheel makes a grinding noise gets worse if on a pavement that is slightly bummpy can anyone help please?
There has been a lot of complaints about the Bee's wheels on the internet including Bugaboo's own Face Book page! Your Bugaboo is ether in or only just out of the 2 year Warranty so contact Bugaboo customer service about getting a replacement set. The rear wheels are held by Hex nuts and are easy to remove with a small hex key any hardware shop can sell you. I use Silicon grease (as used to lubricate taps) when I repair stroller wheels. I think the Bee is a neat little Stroller and my wife has one but it really is only a Shopping Mall Stroller and those little wheels won't tolerate to much rough suburban footpaths.
May 26, 2011 | Bugaboo Bee Stroller
Baby Gear Logo
119 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
