Question about Casio G-Shock GA-120A-7A GA-120A-7 Analog Digital Mens Watch
G shock analogue time setting
I can't get the hands to stay set on correct time I need a ATP by step guide please
  • Casio Master
  • 18,429 Answers
Go here > http://www.gshock.com/support/ to download the manual
Posted on Jan 11, 2013
2 Suggested Answers
escapement
  • 2338 Answers
SOURCE: I need to set the analogue time on my casio g
browse through my tips and you will find link for all Casio watch manual downloads.
Posted on Oct 01, 2010
I have a Waveceptor 3353. If I change time zone I can usually set the watch to show ,say, Paris time both digitally and in analogue. When I try to go back to my home time zone, London, the second hand...
If you cannot find the automatic way of setting the hands, you can manually reset the analogue hands by pressing the mode button until you reach the "HS" mode and using the 2 or 4 o'clock buttons to adjust the hands.
Dec 30, 2010 | Casio DW9051B-1V Wrist Watch
My g-shock ga-110c-1a hour hand is 6 hours ahead. The digital time is correct but the hour hand is six hours ahead. If i set the time at 6:00pm the hour hand will move to 12:00. the minute hand is fine, i...
go to support page on casio. and get your manual. youll probably gonna look for a 3 or 4 digit number located at the back of your watch. once you got the manual. go to page 4. and follow the steps of "Hand Home Position Correction". that should fix it.
i also have ga 110c and i have encountered this issue
Dec 29, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
I have a Casio Wave Captor 4757 WVQ-142E and after the change in time this fall I can't seem to set the time correctly. I am in Paris, so GMT +1, however it is 10:30 and my watch reads 3:03. I have reset...
I sympathize, it took me ages to work this out - I had the same problem having had the battery replaced in my watch which only lasted 18 months...the irony was that my previous watch was still working & set to the correct, time date etc!
The following instructions are for the Casio Wave Ceptor 4757 WVQ-142E, the official Casio instructions are available at the following:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4757
For the extra information Casio neglect to tell you in the manual, read the following:
First, the watch needs resetting. To do this you need a watchmaker's screwdriver, remove the back (4 screws - obviously, you do this at your own risk), remove the thin plastic cover to reveal the battery.
On my watch on the battery cover it says to reset the watch, get a pair of tweezers & connect the battery back to the negative (marked -) plate for about 2 seconds, thus forming a circuit.
The watch stops, the screen goes blank for about 30 seconds, replace the plastic cover , back & screws.
Wait until the watch has picked up the correct time signal, the digital part will show the correct local time, the analogue screen won't at this stage.
Set the watch to the desired time zone that you require or HS (Home Setting).
Then press button "C" (bottom left) to scroll through until "HS" is displayed on the screen, then press button B (top right) for about 5 seconds until it flashes "OO" in the screen, then press the A (top left) button down & to reset the analogue time (so all 3 hands are pointing up) to 12 O'clock, it has to be set to 12 so the watch will recalibrate itself, if it is not set to 12 O'clock, it won't work! - sadly Casio don't tell you this bit in the manual....& of course this is really obvious to us mere mortals!
Now that you have aching hands & repetitive strain injury, press the B button (top left) to exit the (watch) hand setting mode & the watch will now wind the hands by itself to the correct analogue time, (or in theory it will, it took three attempts to set my watch).
Yes, for the record Mr Casio, if you hand a watch to someone & tell them to set it to the correct time, they will set it to the current local time (assuming that it is not 12 O'clock) & as opposed to 12 O'clock by default!
This is not rocket science, if your company is able to make & market a radio controlled watch which is in theory accurate to one second in a million years because it is controlled by the Rugby atomic clock, you'd think that the instruction department could write some decent instructions!
Hopefully this solved the problem!
Nov 02, 2010 | Watches
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Oh, one additional thing about my CASIO 'WAVE CEPTOR' watch: After I got (finally) the manual and set up the watch, it set the DIGITAL display to the correct time & date, but the ANALOG display re-set...
You can align the analogue time with the digital time by pressing the mode button until you reach the hand setting position (HS) and then press one of the right hand buttons to change the hand position.
(Check out this with the instructions- it is all there!)
May 07, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
RE: G-shock giez 1050 watch. we are having trouble setting the analog and digital time the same we have digital right but analog is 15 mins behind can you please help
To set the analogue to the digital time press the mode button (lower left until "HS" appears. Then use the two buttons on the right to advance or ****** the hands.
(these instructions are for my watch but I think that your will be the same. If not, go to the Casio web site (casio.com) select support, manuals, watches, agree terms and then watch manuals archive; fill in your watch details and download full instructions.
Jan 20, 2010 | Watches
Need to fix time on Casio G-Shock
The hands are set independent from the digital display
Setting CASIO G-Shock Watch
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C __ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached (high beep).
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
Apr 18, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Analogue display does not sync with digital
Go to the Casio web site. Download the manual for the watch. Go to the section called "To Adjust the Analog Time." The answer is there, step by step.
Sep 22, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Seiko Sportura SNJ007 chrograph watch instructions
Best solution is to download the ORIGINAL INSTRUCTIONS MANUAL directly from SEIKO's main website:
http://www.seikowatches.com/support/ib/index.html
Aug 25, 2008 | Seiko Sportura SNJ007 Wrist Watch
How to set analogue time
How to set the time on my Casio G Shock G511
· Press (c) button until you get to H-SET
· Press and hold the (A) button until digital time starts to flash
· Press and hold the (D) button to move the analog hand
· Or Press and Hold the (D) button and while holding the (D) button also press the (B) for automatic
Feb 18, 2008 | Watches
Casio G-Shock GA-120A-7A GA-120A-7 Analog Digital Mens Watch Logo
628 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
