Question about Frigidaire FRS26R4A Side by Side Refrigerator
Ice Maker when i plug my control board in the ice pours out and wont stop
  • 59 Answers
This could be a result of a stuck switch, bad switch, or swaped wires. or if a contactor is used in the wire ing a bad contactor
Posted on Jan 21, 2009
Maytag MFX2570AEM5 Ice maker not working no water entering ice maker
But you still have not verified that the hose is not kinked from the internal T where the water splits between the front water and ice maker. When you said you removed the solenoid, the water should have been pouring out. Seems to me a blockage between the T and the solenoid.
Jan 10, 2016 | Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Have model gs5svaxva00, (whirlpool frig) ice maker stopped making ice over the weekend but water dispenser still works?
The problem is one of two places,
the ice maker is the reason or the dual water control valve=> 4389177
Try pouring tap water inside the ice maker if cubes are not there. Let freeze
and if ice drops into the ice bucket then the water control valve on the side
that feeds ice maker is bad.
GS5SVAXVA00 Parts
List
Look up in the scrollbar and go to page 17 and you will see the water
control valve listed an item 5 and item 15 is the ice maker thermostat. That or
the ice maker module are most times at fault if the water control valve for ice
maker side had 120vac connected to it water would possibly flow. I have found
that sometime if the ice maker is bad just to replace would be the best route,
Tell me how the water test goes and if someone has a multi meter or ohm meter I
will answer how to test those components, Thanks, Sea Breeze
Click
here=> 2198597
Ice Maker Assembly
Feb 10, 2011 | Whirlpool GD2SHGX Refrigerator
Ice maker stopped working...water works, ice tray has water, ice maker is turned on. curious if I should just replace the motor or if it could be something else
If your ice maker is not making ice and you poured water into the ice maker, that would indicate the ice maker is not cycling. If you have any make or model except a whirlpool, kitchenaid or sears kenmore, if you replace the ice maker, you will be making ice in no time. If you have one of the aforementioned brands, AND the ice BUCKET is mounted on the door, you will have to replace the electric eye boards on either side wall as well, as these often short, damaging the icemaker electronics in the process.
Nov 09, 2010 | Kenmore Refrigerators
The ice maker just stopped making ice.
First , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve ( pt. # 4389177 ) . If it does not dump the cubes , replace the ice maker ( pt. # 4317943 ) . After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Dec 04, 2009 | Whirlpool ED2FHEXN Side by Side...
Icemaker stopped making ice.
If not filling with water the water control valve is most likely the problem. Pour tap water into tray let freeze and if it cycles and dumps the ice then the water control valve is the problem. If the ice maker does nothing trying this the the ice maker is most likely the problem, I need your model number to confirm which type ice maker you have because some do not have replacement parts. The model number of your Whirlpool Refrigerator, Thanks Sea Breeze
Oct 02, 2009 | Whirlpool Refrigerators
Profile ice maker stopped making ice
ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ive got a GE profile and my ice maker stopped working. I get water through the door so i took the ice maker line off to see if it was clogged or something. its weird no water comes out the ice maker side...
GE made different versions of the model listed above your post. If the Ice Tray is empty pour tap water into the tray and let it freeze. If it empties on its own, then I would tell you that the water control valve for the ice make is defective. For a few years the ice maker came with an electronic control board behind the front cover on ice maker. To make sure I will need you to look for the correct model number on locations pointed out below in photo. You also are welcome to get answers from me or our sites free. Enter your model number in the search feature and this will pull up the model with pictures and parts. Either way let me know what you find and if I can help you better, Thanks, Sea Breeze
appliancepartsse@yahoo.com click on link below
http://servicepartstec.blogspot.com/
We may need to test the water control valve on the back also, here
is a picture of the dual valve
May 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker pouring water
there must be something wrong with the solenoid valve that controls the water flow to the ice maker
Jun 14, 2008 | Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
56 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
