Question about Necchi 4575 Mechanical Sewing Machine
Machine is locked up
My needle broke while I was sewing, I've removed the needle but now I can't get the arm to move at all.
  • Norm Himebaugh May 11, 2010
    Do you still need help?
When you say you can't get the arm to move are you talking about the needle bar, if this is the case the chances are if you broke the needle there may be a piece stuck in the bobbib case area but can you be a bit more explicit. Thanks Ken drivewithken@blueyonder.co.uk
Posted on Sep 18, 2007
  • 44 Answers
M8 i havent tryed sewing machines befor but i would take it apart and se wat was casing it to get stuck.also try gettin the skematics for that make and model of sewing machine if nothing else it will atleast give you a better understanding of how the machine works and may help you solve the problem.
Posted on Jul 03, 2007
SOURCE:
Oily cotton when stitching
Oily Cotton:
1. Remove the bobbin case.
2. Wipe out the oil.
3. Bobbin case rides unto an area that looks like a race track. (Called Race). Wipe out oil.
4. After cleaning oil out take a drop and place unto race.
5. Replace bobbin. (Wipe oil if there is any.)
6. Remove oil from the needle arm. (Goes up and down holding unto the needle.)
7. Replace a small amount of oil on the needle arm.
The sewing the machine should sew very well. It may have some resistance when you turn the hand wheel by hand. Likely, this is due to the machine being new and not being broke in. Otherwise, it would need to be lubricated throughout the machine. Give it while!
Mar 23, 2015 | Janome Sewing Machines
Needle locked in right position
Remove the needle holder using a tool suitable for it and remove the needle and fix it again in the correct position and continue the stitching in zig zag .
Thank You
Sep 13, 2008 | Husqvarna Viking 1
Main motor lock, inappropriate needle position, after broken needle
The broken needle may be lodged in the bobbin housing. If you cannot locate, take it in for professional servicing. You may have put the timing out of whack.
Mar 09, 2014 | Brother Sewing Machines
Motor is locked up
when the needle broke it could have caused the machine to just time, it would be a good idea to have the machine checked at a sewing machine shop...
Jul 12, 2013 | Baby Lock Esante
Babylock Esante ESE-2 error beeps when performing embroidery arm test?
Something is wrong with the sensors. Take it in for a repair.
Aug 23, 2012 | Baby Lock Esante
Janome 1600p-DBX is not taking the bobbin
have you checked to see if the needle is inserted correctly into
the needle clamp,,all the way up into the needle clamp
& that the needle is turned the right way
also check to make sure the bobbin is inserted correctly into the
bobbin case.
if you have checked for this then the following is possible
it's very possible that when you broke the needle that it caused
the machine to jump time, & it would have to be taken to a sewing
machine shop to be retimed.
Aug 01, 2012 | Janome 1600P-DB Mechanical Sewing Machine
White Classic 312 - I turned on machine, reloaded bobbin and put it back in. Threaded needle, tighted needle arm after threading bobbin and pushed on peddle to start sewing. The machine locked up,...
Bake cookies. This is why you never paid attn when Mom tried to teach you in 1977, and why sewers are on a higher mental plane than yourself, Pammy.
Aug 12, 2011 | White Sewing 312 FS
I have a Finesse sewing machine and I was sewing some placemats but it suddenly stopped feeding the material although it keeps sewing (foot moves up and down). According to the book I have checked the...
Can you see the feed dogs moving?
un thread, raise the pressure foot then manually turn the flywheel towards you and watch the feed dogs (the teeth that move under the needle plate). If they are not moving around and coming up above the needle plate then one of two things:
either you've accidentially disengaged the feed dogs, check the manual for instructions to reengage, sometimes a knob, button or slide, often on the front base or around the back of the free arm.
If they are engaged but not moving up at all, then something has gone in the drive to them, usually a gear in the free arm area. In which case, take to the shop for repair.
Jul 01, 2011 | Sewing Machines
Hi i just brought my machine and it has been working fine until a needle broke and now the whole machine is jammed the needle lever will not move. can you help?
did you turn the machine off and unpluged it for awhile...locking up may be a safety feature to protect machine from further damage
Make sure to remove broken needle if possible and turn lever by hand after restarting machine
Feb 04, 2010 | Brother PC-420
My zigzag broke on my Sewing Machine
Use white lithium grease on the gears, and sewing machine oil on the other ... or broken, get a replacement from your sewing machine supplier
Jun 26, 2009 | White Sewing 2037 Mechanical Sewing...
Necchi 4575 Mechanical Sewing Machine Logo
324 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
