Question about Bissell 3522 PowerForce Bagged Upright Vacuum
Not sucking from bottom into bag, but blows out the side filter,..yet it DOES **** FROM HOSE ATTACHMENT. How can this be?...the.belt is fine recently replace, the rollers clean..I can feel anything i
Not sucking from bottom into bag, but blows out the side filter,..yet it DOES SUCK FROM HOSE ATTACHMENT. How can this be?...the.belt is fine recently replace, the rollers clean..I can feel anything in the translucent hose tha runs from the bottom to the attachment, SHOULD there be some kind of swith baffle there? can I get a DIAGRAM of the inside before I take this thing apart completely!?
  • Bissell Master
  • 18,389 Answers
Here is a diagram ,it's probably the hose behind the brush bar thats blocked.
http://www.vacsite.com/en/bissell-parts-1/bissell-parts/3522-powerforce.html
Posted on Jan 11, 2013
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Blowing out?
Did you check the inlet down by the brush roll?
Posted on Feb 13, 2008
carlsbiz
  • 1124 Answers
SOURCE: Vacuum doesn't vaccum!
Sounds like there is a clog near where the hose conects to the lower brush part.. Try to look up in there.. Under the brush there should be an opening that goes into the hose.. There might be a clog there..
Posted on Jul 08, 2009
heatman101
  • 43501 Answers
SOURCE: Bissell proheat blowing out air instead of sucking in air
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
vm,v
Posted on Sep 30, 2010
Andriod Man
  • 271 Answers
SOURCE: my bissell 6590 works fine
replace the roller,belt and before instalation clean motor shaft where belt rolls. you can turn on the vacumm and using a knife scrape the motor shaft from the black dirt.
Posted on Feb 19, 2011
I have a hoover Dust Manager DM6200. actually it is my friend's. She said it wasn't working well, so I took a look. It wasn't picking up, and seemed to be spreading dirt in fact. I emptied...
Hey Julie,
Hopefully we will get this solved together.
To me, this problem sounds like either the filters are choked up and cannot breathe, OR.... the bagless cannister is not quite sitting in the machine properly.
Honestly, I am more leaning towards the cannister not quite in properly, that is assuming that everything is out of the suction hose.
Start with the process of elimination. Remove and clean the filters with a paint brush or other brush. Get as much dirt and debris off of them as you can and replace them into the machine.
Turn on the machine, and using only the hose attachment, feel if the suction is there. If not, try a re-alignment of the cannister and check the hose. a small coin or marble running through the hose will tell you if there is still a blockage in there.
Where the attachment hose connects to the bottom of the machine could also be blocked up as well. This will also give the same effect of the dirt blowing out the bottom of the machine.
Lastly, it is also quite possible that the belt has stretched or worn out. This too will contribute to it not picking up.
Let me know if this helps, and we will go from there.
Good luck,
Mark
Jan 24, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Hoover U6476-910 - Very little suction from the bottom
If you haven't already, remove the beater bar. This is accomplished by unplugging the vacuum and turning it beater bar up. Remove the clips or screws that hold the plate on the beater bar and set aside. The beater bar sits in sockets, so carefully remove the bar, noting the correct position of the sockets. This will make reassembly much easier. Slip the beater bar out of the drive belt. Now, inspect the suction cavity that the beater bar would discharge into. Usually, things clog up here as there is a flex hose that catches things, creating a pluggage.
Hope this helps, --W/D--
Jul 18, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
Suction only through attachment, but not without attachments
have you removed the bottom plate...as if you were going to change the belt....look for where the intake hose is under or near the roller brush...most likely that is where your clog is.
Mar 27, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
I have a bissell power force vacuum and I just pulled the bag out to change it and when I put it back in it began blowing air out the filter on the side and is no longer sucking
Try checking the attachment hose for clogs. It should come completely off of the vacuum with just a few screws. Also, check the little hole underneath the brushroll where the dirt goes in. Hope this helps...
Marci
Nov 25, 2008 | Vacuums
No suction or very little
Make sure you have a good bag installed in the vacuum and the door is properly in place. Remove the attachment hose from the bag chamber and turn the machine on. You should have good suction coming from the hose inlet. If you don't you have a problem in the bag chamber. Bad bag, door is not on correct, door is defective, dirty secondary filter.
Connect the hose back to the machine and pull the other end out from the bottom, and turn the machine on. You should have good suction there. If you don't you have a clog or hole in the attachment hose and it needs to be unclogged or relplaced.
Reconnect the to the bottom. Flip the mahine upside down. Take the screws out of the bottom plate and remove. Remove the brushroller and belt. Turn the machine on and you should have suction at the inlet coming off the brushhousing. It you don't, then you have a clog in the nozzle hose and it needs to be removed. It will probably be more accessable from the bottom side since that is the way that it entered.
Sometimes a suction problem can be confused with an brush problem. The belts on that machine should be replaced every 6 to 8 months because they will strentch and wear. This is an inexpensive maitainance that will dramatically improve its function. Part Numbers are 38528-035 and 38528-034
Nov 21, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Kirby Ultimate G will not suck with main brush head attachment
You may need a new belt, it may have stretched enough so it isn't turning the brush roll anymore.
Mar 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Blows dust and dirt out of brush area
Did you make sure to cut all the strings, hair, etc. out of the brush attachment on the bottom? Look in the corners too to make sure none has gotten stuck on the sides that needs to be cut out.
Jun 03, 2007 | Kenmore 25812 / 25813 Progressive Bagged...
Bissell 3522 PowerForce Bagged Upright Vacuum Logo
179 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
