Question about Gateway MT6916 MT6917b
I replace the screen on my gareawawy mt6916 and need tp install the vydro controler druver but doesnt connect to internet help me please
Replce the screen and need to install the video controker drive but doesnt connect to internet from safe node can somebody help me
  • 2,878 Answers
Safe Mode is for trouble shooting only. Download via another device and copy over. Make sure to install in regular mode. You have bigger problems if you can't get there.
Posted on Jan 11, 2013
How to set up my router with modem?
Connect the router to the modem with an ethernet cable, CAT 5, 6 or 7. Try amazon.
Jul 19, 2016 | TP-LINK Computers & Internet
How to setup tp-link TL-MR3220 on xp2002?
Connect the router's WAN port to your cable-modem.
Connect the computer to one of the LAN ports.
No other "setup" is needed.
Apr 29, 2014 | D-Link AirPlus DI-524 Wireless Router
Connect mifi
Open internet option's or "create homegroup" option on your pc and enable your pc to become an access point. Doing so will allow the pc to share the wifi with any compatible device. The handset cannot find the IP due to a firewall so turning those off manually would also work but do so only as a last resort.
Apr 03, 2014 | TP-LINK Computers & Internet
Tp-link tl-r480t+ becomes stuck whilst configuring the network parameters after selecting the Dynamic IP connection type as detailed in section 3.2 of this guide...
first try resetting the router, if that doesnt fix the problem, you will need to re write the firmware(or update it if available). even then if doesnt fixes, you need to replace the unit :/
Feb 23, 2014 | TP-LINK Computers & Internet
TP-LINK TL-WN321G - Hi-Speed USB - 802.11g driver not install in window xp
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"
Apr 03, 2013 | TP-LINK TL-WN321G - Network adapter -...
I have Windows 7 64-bit Home Premium on a Gateway desktop computer. I plugged in the newly purchased TL-WN722N wireless adapter and installed the driver from the CD. I connected to the Linksys WRT54G...
Dear ubose1, This is Howard from TP-LINK Support Force. Maybe the anti-virus software blocks the driver installation. Please disable the self-defense function and exit it. Then try to install the driver again.
TP-LINK Support Force http://www.tp-link.com/en/support/ http://www.facebook.com/TPLINK
Sep 18, 2011 | TP-LINK TL-WN722N Wireless USB Adapter...
I bought a TP-link TL-WN821N wireless network USB adapter. I installed the driver on my desktop and I cant connect to our network nor the internet. I connected it to my laptop and deactivated the...
Dear Joeri_troch This is Howard from TP-LINK Support Force. Could you please check if your desktop has recognized the wireless adapter? And can you see Wireless Network Connection icon?
Sep 17, 2011 | TP-LINK TL-WN821N (TPLINKWN821N) 802.11b...
Hello, I have been having problems with my TP-LINK TL-WN353GD 802.11g/b Wireless Adapter on my PC, which is running windows xp. Unfortunately I am getting extremely low internet speeds with it (download...
Try disabling Windows power control over the wireless adapter. you can do this from control panel > network adapters > double-click the wireless adapter > "Power management" tab > un-check the "Allow the computer to turn off this device to save power"
I hope this helps
Jun 07, 2011 | Computers & Internet
How do you replace the throttle position sensor
Removal & Installation
  1. Remove the idle air control (IAC) electrical connector (1) from the IAC sensor (4).
  2. Remove the manifold absolute pressure (MAP) sensor electrical connector from the MAP sensor.
  3. Remove the water pump belt cover.
  4. Remove the TP sensor retaining screws electrical connector (2) from the TP sensor (3).
  5. Remove the TP sensor electrical connector (2) from the TP sensor (3).
Detaching electrical connectors prior to TP sensor removal
Identifying components for removal of the TP Sensor
To install:
  1. Install the new O-ring on to the TP sensor.
  2. Connect the TP Sensor electrical connector (2) to the TP sensor (3).
  3. Install the TP sensor (2) on to the throttle body (1). Tighten the TP sensor screws to 2.3 Nm (20 inch lbs.).
  4. Connect the IAC electrical connector (1) to the IAC sensor (4).
  5. Connect the MAP sensor electrical connector to the MAP sensor.
  6. Install the water pump belt and tensioner cover.
  7. Perform the TP Sensor learn procedure:
  8. Turn the ignition to the RUN/ON position.
  9. Wait 1 minute.
  10. Turn the ignition to the LOCK/OFF position.
May 12, 2010 | 2000 GMC Jimmy
I have a toshiba laptop, already have existing computer all set up but having trouple conncted laptop to wireless. Have adsl modem and tp link router. tp link is asking or network key to be able to...
Your wireless network is secured and thats why its asking for the network key. If you dont remember the same, contact your router manufacturer or ISP and get the router reconfigured
Jul 03, 2009 | Computers & Internet
Open Questions:
Can I hold DHHS accountable for the burden they put upon me? If not, is there someone that can be held accountable? What can I logically and honestly do to remedy this prob. I explained my prob below! I was getting QMB part of Mainecare and my spouse at the time we were dating but living together was getting the QI part of Mainecare. We are both disabled and only get SSDI. However being honest and do our best to always do the right thing we go to DHHS office on Griffin RD in Bangor, ME within a month of us getting married where the worker we saw tells us we don't qualify for anything but the min of FS and both Q1 part of Mainecare and serious voice tells us to divorce. I have made a few trips within last months to same DHHS. One sends us to Eastern Area of Aging to see if there were secondaries we can get. This past Monday hubby and I went to our appt with Eastern Area of Aging & was told they strongly believe I could get spousal exclusion also warning it could mean my hubby loses help but because it was a volunteer a newer one at that that she couldn't tell me definitely cause she didn't know the formula as she still learning; tells us to go back to DHHS to ask about spousal exclusion. So I go back to DHHS this past Thurs and got a worker with more smarts, heart with approx 10 yrs working for DHHS tells me I qualify for spousal exclusion and took the time to answer all my questions. I told her I had QMB till hubby and I married June 2016 & shared with her what the DHHS worker told us when hubby and I went in to show marriage certificate to update the change. She looked at me with shocked eyes and dropped jaw in bewilderment. Then says I would of never lost it as I would of qualified for spousal exclusion from the day we married. And had it been her that we got when we were being honest wouldn't have only told me about spousal exclusion but would of applied me as she could see I have major medical problems that is too much a financial burden for my hubby and I. She also told me I was to submit all unpaid bills even if monthly making payments were being made. I thought I was only to submit bills I paid in full or on a payment plan. So started Thurs night on a Medical Bills Tracker to go through all the medical bills and sort things out. I haven't even put a dent in the pile and see I'm responsible for just over 6K I'm predicting once done I could be closer, if not over, 10K. In collections is currently 1K but once done with pile amount in collections could be closer to 2K or more. So the mess has impacted my credit and if things were done by professionals I wouldn't be losing my hair stressing over my medical bills and how it declines my credit. I know I'm in a small group that actually pay their medical bills any and all bills to be honest! I am disabled and get SSDI. Worked 1992-2013 a lot of times working 2 jobs! Dr in 2013 practically dragged me out of work as was just diagnosed with Hep C, CKD Stage 3 & liver disease! I also have depression disorder, panic attacks, anxiety disorder! So even this incompetent DHHS worker putting extra financial burden on me unnecessarily affects those things. I am trying to do the right thing but get kicked down by the very people that are paid to help me. What are my rights and can I fix this at a faster pace then not even fixed it by the day I die?
Jun 23, 2018 | Major Computers & Internet
See all Gateway MT6916 MT6917b Questions
Gateway MT6916 MT6917b Logo
46 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
