Question about Tomtom GO 730 Car GPS Receiver
How to update speed camera data base on tomtom730
How do i update saftey camara data base
  • 78 Answers
Theres an option to add new POIs when you connect to TomTom Home, and just search down the list for the camera POI to add. It was the first update I made to my 930
Posted on Jan 22, 2009
When i plug my digital camara into my computer, my computer do not recognize it
At first try to connect through USB
  • Just connect your camera data cable into the USB port of the Computer
  • On your camera
  • Then Right Click on My Computer select Manage then Go to the Device Manager and Click on Update Hardware Option
  • After updated you see a Icon as yellow Question Marks with The name of your camera.
  • Just Right Click on it and select Update Driver
  • Do as per the given Direction.
After successfully install your driver you just restart your computer. Your camera is now installed with your PC
May 18, 2011 | Kodak Easyshare C813 Digital Camera
My nokia 2680s-2 camara on standby problem
dear sir,
this is the problem usually caused by viruswhich happens when you are receiving files from p.c or untrusted mobiles...... and sometimes it might be software failure also, which causes some of the menu not tofunction,the only solution is to flash ur phone software from the nearest nokia care,it also updates your mobile software which increases the mobile speed....
thank you.....take care................
Oct 08, 2010 | Cameras
How i can connect my nikon coolpix s4000 digital camara to my PC
First install the software of the camera to your computer it should be on the CD that came with the camera, then connect the camera via data cable USB and make sure the camera connectivity setting is USB connection. After that open the software and you should be able to see all the data inside the camera's memory and transfer it to your computer.
Sep 07, 2010 | Nikon Cameras
Driver and software loaded but when I run the software it says "Device not Ready." Device manager thinks it's a "Coach" digital camera.
open device manager
start>run>devmgmt.msc>ok
rigth click on the Coach digital camera and update driver let windows search the inter net for the soft wear. if you are unable to find beter softwear try to uninstall the camara and restart your system then plug in your camara in device manager you should see it conect rigth click and update driver aviod searching your system hope this solves your fault
Dec 18, 2009 | Largan Mega 2 Digital Camera
Shutter speed won't go over 5 frames a sec. on d300
Even if your camera is rated at shooting more than five continuous frames at a time, those are stored in a memory buffer in the camera, when the buffer is full the camera writes the images to your flash memory card. How fast the memory card can accept the data will determine who fast space is made available in the buffer for a sixth or seventh shot.
The main limitation on how many images can be shot in continuous mode is based on the storage capacity of the memory buffer and also how fast images can be written to your inserted memory card.
So, the higher the resolution the image the more space it takes in the memory buffer. Should you shoot in a smaller resolution you should be able to shoot more frames continuously. However, there are a few variables involved. If the Camera is preset at the factory to not store any more than five images no matter what the resolution than there is no way around this encumbered feature. And, or the speed at which the memory card you use can accept written data will also decide how fast the buffer is cleared for new data.
The highest speed flash memory conforms with Version 6 and has a write speed of 188x.
So, the things to double check is if a limitation is built into your camera of five images and no more than five no matter what the resolution. This is not uncommon. The second is the speed at which data can be cleared from the buffer and written to the memory card, less common but a newer standard now that faster flash memory cards are becoming available.
Now, all that being said, There are 'firmware' updates released from time to time that make adjustments to camera features than can change these variables
Most Nikons use Compact Flash so see if you can get a high speed card that is version 6 compliant. But, first, check the sony support site for your camera and see if 5 is the limit no matter what. And if so, see if there is a firmware update under downloads at the support site that increases the number of shots that can be stored in buffer while being written to the flash memory card.
I have a client wtih a D60 who when she switched over to 133x Compact Flash was able to shoot more frames faster in continuous mode.
Please don't hesitate to use the comment text box below for any further assistance, such as the support page at Sony for your camera if you don't have in in yoru manual. Or any information you may need regarding shooting in high speed mode and what format to use. Most Pros that consult with me are using JPEG uncompressed. If you have questions please provide more detail on how you have your camera setup and under what conditions you are shooting in when attempting to capture more frames per continuous mode shotting.
Regards,
Worldvet
Jan 14, 2009 | Nikon D300 Body Only Digital Camera
Can't update speed camers on navman 7700 gps
No, the service will be proprietary to that device. Evesham will have paid the supplier of the camera data.
With Garmin, if you took the camera data as a trial, you still got the warnings after it expired, but not any new camera locations. With newer Garmin GPS units, speed camera information is supplied FOC and updates are done automatically when you are in range of your home wifi. Garmin are the brand leaders. I have had two since 2006 and am considering buying a third as they just get better and better.
You could use the smartphone app 'Waze'.
Sep 24, 2017 | Evesham Nav-Cam 7700 GPS Receiver
Digital camara and memory card
Basically picture files in memory card have corrupt data that's why computer doesn't recognize it.
HP recommends following action...
Close the HP Image Zone or HP Photosmart Software, disconnect the camera from the computer, and reset the camera. (can see this at HP Support)
2nd option is to find some memory card data recovery software on internet and use it to correct data files in memory card.
Thank you.
Oct 03, 2008 | HP Cameras
Camara not working
elvintromp - have the phones firmware reflash or updated to correct the issue, you can take it to a mobile center close to you to have that done.
asdf1092 - replace the camera and service the phone.
Nov 12, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Can't place camera image file into another document
Nikon digital cameras record images in the "EXIF" (Exchangeable Image File Format) file type. Even though the file name (when shooting compressed files) ends in ".jpg" it is not a regular JPEG image. This format includes not only the JPEG picture data but also the shooting information (f/stop, shutter speed, lens, etc.) and other text-based data. Writing this type of information is part of the global "DCF" standard for images from digital cameras. Some applications do not properly read this data and will display various errors and warning when opening these files. The only way to use an image in one of these programs is to open it in an image-editing program and save the file to a new file name. This changes the file from an EXIF image and saves it into whatever format is chosen, stripping out all of the extra data. Contact the developer of the program which does not properly open EXIF files for possible updates.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Tomtom GO 730 Car GPS Receiver Logo
199 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
