Question about Toshiba TN43V71 43" Rear Projection Television
Cannot get video to work.
I cannot get any video to be displayed by hooking up my cable, DVD, or VCR to any of the F-connectors. Using the red and white A/V cables I am able to get sound for the VCR but no video. I have tried using the yellow video cable for all of these and it does not work either. None of the F-connectors work nor does the S-video jack. I would appreciate any help on how to possibly replace the F-connectors or whatever it is attached to which must have shorted out to keep the video from appearing. Also, the TV is able to show the channel, volume, brightness settings, etc. so there are no problems with the picture tube. I am no expert at repairing TVs by any means, but I would like to try to fix it myself before paying a bundle for a repairman.
  • 44 Answers
M8 the pitt is right try and find the av cable connection. then jus see if theres any black sutt marks if not.i would plug it in and use multimeter to see if there was voltage goin to that part but dono if you should do this m8 dont want you to electricute your self so if you not experienced dont try.parts are not hard to get.its just finding the problem witch is time consuming.if you live in west yorkshire in the uk. your in luck as these guys are located there an they cheap. http://www.mobilephoneservicecentre.co.uk/
Posted on Jul 03, 2007
  • 32 Answers
JMC21: If you already open the back or your PTV, check if the Video Jack Connectors board and check for any cold soldering spot.
SOURCE:
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Mar 13, 2011 | Samsung DVD-V4600 DVD Player/VCR
My coaxial broke off the back of my tv, I was told that you can still hook it up without that by using the yellow, white and red cord. My question is which spots do these color ends go into to make this...
You don't give much information. Coax from what broke off? TV antenna, or from something like a DVD or Dish or DIRECTV? Depending on where it came from, you might be able to use ylw, white, and red. If wherever the coax comes from has those outputs, simply use a ylw, red, and white cable and run to an available input on your TV. Having a VCR and DVD player already hooked up makes no difference whatsoever, as long as you have more inputs available. If you are out of inputs on your TV, you can buy a "video switch box" which allows you to use only one input on your TV, which keeps you from switching the TV input back and forth, by pushing a button on the "video switch box" to choose DVD, VCR, Dish, or whatever. (Yellow is video, red and white are left and right sound). Or, you might have red, blue, and green out put on your device. If you do, run them (using a cable with the same color scheme) to the appropriate input on your TV. BUT: you can get a new coax cable with connectors on each end for a couple dollars most anywhere, that would be easiest.
Feb 02, 2018 | Televison & Video
DV1130 hooked up to TV, DVD works great. VHS has
If you are using RCA cables (Red Yellow White) the video (yellow) could be bad or not in the connector all the way. When the VCR mode is selected try pulling the yellow connector out then back in and see if anything changes on the tv.
If you are using another type cable let me know and I will help you diagnose.
Hope this helps
TankMurdock
Apr 25, 2009 | GoVideo DV1130 DVD Player/VCR
My akai receiver to my vcr
hi my name is mark, if you have cables. first unplug the power cords to the vcr and the receiver. on the back of the vcr there will an input and an output audio and video connectors. if your vcr does not have them you will need a new vcr that does. if you just want sound, find the Output connectors. there will two. they will be idenified as Audio OUT. plug one end of the red plug into the one labeled Audio R OUT, then the white in the one labeled Audio L OUT. if you are connecting the video up connect the yellow plug to the connector labeled Video OUT. the other ends connect to the receiver, on the back of the reciever find connectors labeled vcr or dvd AUDIO IN. then connect the red plug to the connector labeled R IN and the white plug to the connector labeled L IN.if you are just hooking up sound you done. to hook up video find vcr dvd Video IN and connect the yellow plug to the Video IN. on reciever. if you want the reciever to switch the TV you also need to run a yellow video cable from Video Out from receiver to Video IN on back of TV. when finished plug in vcr and receiver. select dvd or vcr on receiver to listen ot vcr on the receiver i dont know what model you have or it features i hope this helps thanks for your question.
Mar 17, 2009 | Akai 42 in. LCD TV
Lost manual, can't get VCR to play
There are several Philips and Magnavox DVD/VCR combos that have sepearate video connectors for the DVD and VCR side. Double-check the yellow composite cable that is plugged into the back of your Magnavox - it should be plugged into an area that says either "DVD/VCR" or "VCR". If you are currently using red, green, and blue video cables, you will need to add a second video cable - a yellow composite would be easiest. The reason for this change is that red/green/blue cables will only operate the DVD side on most Philips/Magnavox players - that is just the way they decided to design them. If you happen to find a model number listed on the back of your combo unit, and have the model number of your television, I can take a second look at it, and tell you exactly which connections to make. Good luck!
-Tha Mp3 Doctor
Feb 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Hot to hook up cable
This monitor with a television tuner does not have a coaxial connection. I was able to get cable by connecting (buying if you don't have) to my dvd/vcr which had the coaxial connectors. Then I ran the video component cable (green, blue & red - had to buy that) from the tv to the dvd/vcr. Then I ran the audio cable (red & white) from the tv to the dvd/vcr. A little tricky figuring out where on the tv to actually connect but eventually got it. YUV2 on the side.
Dec 24, 2008 | TruTech PLV16320 Television
Can only get DVD audio when hooking it up to Goldstar VCR...
The DVD must be connected with the RCA jacks-plugs [usually black & red] to the INPUT of the VCR, not to the RF connector. You must press the VCR\TV button to VCR so that the VCR takes control.When you place a DVD movie or AUDIO program it could be copied to the VCR. or played through the VCR.
Nov 11, 2008 | Televison & Video
Hook up vcr
yes, you need to use an Audio/Video cable (red, white, yellow) to hook to the TV. I've never seen a VCR that doesn't have coax connectors for the antenna input and TV ouput, but maybe the new ones are starting to leave that out. Normally, you run the antenna or cable coax into the VCR's input, then run another coax from the VCR output to the TV's input (or use an A/V cable)
Dec 20, 2007 | Sharp VC-A420U VHS VCR
Hooking tv up to my vcr/dvd combo
hook the antenna to the VCR rf conecter IN. buy some RCA jacks and a three way deal and hook the red to sound red out ,white to sound output white, and yellow is always video hookit to yellow vido out on the vcr/dvd. The other ends go to the inputs on the TV....same color code. or you can just hook a cable to rf connector OUT on the vcr and other end to( it with problably just same antenna in) to TV.
Aug 29, 2007 | Sanyo DS31520 31" TV
RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Jun 25, 2006 | RCA F27645 27" TV
Toshiba TN43V71 43" Rear Projection Television Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
