Question about ECS P4s5a Socket 478 Motherboard
Front usb wireing diagram
Need pin wire diagram for front usb wireing
    Scholar:
  • 127 Answers
ECS P4s5a info here :
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=37&CategoryID=1&MenuID=18&LanID=0
go to the above link and click on download and manual. Look near the bottom of the page for the user manual and click on the closest country to you to start the download in PDF format.
The front pin diagram is on pages #14-15
and the USB pin diagram is on pages #28-29
you will need adobe reader or similar to be able to read the pdf files
Posted on Jan 10, 2013
Need circuit diagram for HP m8100 GC673AA
HP Support > Pavilion Media Center M8100n Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=3440614&lc=en&cc=us&dlc=en&lang=en&cc=us
Product information > Product specifications > Motherboard Specifications, MCP61PM-HM (Nettle2 {HP name} ),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077676&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3440614
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires connect to, is the Front Panel header.
(Power On switch, Power On LED, HarDDrive activity LED, etc)
The Front Panel header is Black, rectangular in shape, and is situated in a vertical position; located in the Bottom Right corner of the motherboard. (Next to the mounting hole)
It is a standard 9-pin HP Front Panel header,
http://h30434.www3.hp.com/t5/Desktop-Hardware/Getting-a-new-case-i-need-Front-Panel-pinout/td-p/842897
Scroll down to the 9-pin Front Panel header photo, and pinout.
The 4-pin side is the EVEN side. Pins 2, 4, 6, and 8. There is NO Pin 10.
The 5-pin side is the ODD side. Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light Emitting Diode, so it is redundant to call it a light)
Pin 1 is for the Positive ( + ) wire.
IF the HDD LED is dim when the harddrive is active, (IN use), switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Reserved for factory use, and it is +5 Volts.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
Scroll the HP Support Motherboard Specification page down. Click on the + sign next to Motherboard Layout.
Left to Right on bottom edge of motherboard, Internal Connectors;
AUDIO_1 is for the audio ports on the Front Panel.
ATX_IN is where the small audio cable from the optical drive plugs in.
(CD/DVD drive)
IF TWO optical drives are used; the Main, or Primary optical drive, is connected with the small audio cable. NOT the secondary optical drive.
HD_AUDIO also connects to audio ports in the Front Panel.
May be mistaken, but don't believe SPDIF_OUT header is used.
1394A1 header is for the Firewire ports in the Front Panel (1394a)
USB 2 and USB 4 headers are for the Front Panel USB ports.
USB 1 and USB 3 should be for a Card Reader.
Need where the power cables go, and what they look like? Just post back in a Comment.
(Be SURE to FOLLOW Anti-Static Precautions)
Regards,
joecoolvette
[ Didn't think you actually wanted an actual circuit diagram. That is copyrighted by HP, and Elitegroup Computer Systems. (ECS)
Dec 03, 2012 | Computers & Internet
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
Hi i have a Codegen model 450x case and i am trying to install a Gigabite GA-P35-DS3R motherboard and am having troulbe with the start switch wires, the cases wires do not matgh the diagram in the...
I'm not sure what you mean when you say the case wires don't match the diagram. You might mean there is already a plug on the end of the wiring, and this plug doesn't match the board header. If you're reusing the case from a name-brand machine like a Dell or HP, this is possible. They often get custom versions of motherboards made, and their front panel connectors are usually a nonstandard layout. On the other hand, in a generic retail case, the front panel wires normally have separate connectors on the ends for the switches, indicator LEDs and any front panel USB and audio jacks.
This is the front panel header diagram I found in the manual for your board (I looked at version 2, but the connections should be the same if yours is a different version):
This board has an Intel standard layout for the header. If your wiring has separate connectors, the start (power) switch wires will plug onto pins 3 and 4. I have never seen a retail case come with anything other than a two-pin plug on the end of the power switch.
If you are dealing with a custom plug on your case's wiring, what you can do is remove the pins from the housing. They almost always are held in by a plastic tab on the connector shell that engages a tang on the pin. Use a thin object like a small flat-blade screwdriver or a knife tip to lift the tab and you can slide the pin out. Insulate each pin with small-diameter heat-shrink tubing if you have it, or a layer of electrical tape. (I prefer the heat-shrink tubing, which is neater and more permanent.) Then you can put each pin over the corresponding pin on the motherboard's front panel header. Unless the pins are very loose, they will stay in place by friction. I often use this technique when salvaging a case.
As for the CPU fan, be sure you have the connector over the right pins. Here is the diagram from the manual:
You might need to rearrange the pins in your fan power connector if they don't line up correctly. This layout looks a little strange.
Dec 21, 2010 | Codegen (PS-450W) (PS450W) 450-Watt Power...
How do I connect the front usb wires to my fic c51g motherboard header?
How to Install Front USB by Connecting Front USB Ports to a Motherboard?In order to have front mounted USB you must have 3 things.
  1. A case with USB ports in the front of it.
  2. A motherboard that supports front USB (usually)
  3. Appropriate wiring between the USB port and the motherboard
A case can support front USB in two ways: via a pass thru connection, or via a port to header connection. The former, pass thru connection, is compatible with all motherboards that have USB ports. Pass thru front USB Pass thru front USB works by having the ports on the front of the case connect to either a standard USB cable, or a fairly small rounded cable. The cable goes from the front of the case to a special slot cover with either a hole (for the standard USB cable) or a special connector for the rounded cable. If the pass thru USB had a standard cable, then you would simply plug the standard cable into one of your back USB ports. If it had a rounded cable, then you have a secondary attachment with something that looks like an old style SCSI connector. The attachment plugs into both the slot cover, and the back USB ports. The draw back of pass thru front USB is that you lose the ports in the back.
Many 3rd party devices that add front USB to a system use the pass thru system. A good example is this now discontinued Front IO panel
directron_1721_2292726
Front USB via a Port to Header connection In order to hook up a Port to Header connection you have to make sure that the wires from your port will connect to your motherboard's header. To do this you need to know what header you have, and what type of connector you have on the wires. You'll find information on both below.
Almost all motherboards these days have a USB header. Due to size and cost restraints many motherboards only have 2 USB ports on their back panel, but often they can actually support more then 2 USB ports. They will typically support additional ports via the use of a USB header. A USB header is either a single or double row of header pins on the motherboard that can be used to add additional USB ports to a computer via the use of an appropriate set of header connectors, wires, and a USB port. Each pin on the header corresponds to a wire inside a USB cable. These pins must be clearly marked so that you can hook them up to the wiring correctly. There are 2 common layouts for a USB header.
Intel Standard USB header Layout: (used by over 90% of motherboards)
Gigabyte Style USB header Layout: (used most commonly on Gigabyte brand motherboards)
instusb2b
Now that we know the types of headers we have to take a moment to understand the USB wiring. Understanding the wires First off: All USB cables have 5 wires. 4 of these wires are actively used. Here's a reference from the official USB standard.
instusb3
On a front mounted USB port you'll have either the first 4 wires connected to properly colored wires (red for power, white/orange d-, green/yellow d+, black for ground) or all five wires attached to the port (same as the former, but one extra black wire). Now where it gets tricky is how to attach each of those wires to corresponding pins on the motherboard.
The wires are "tailed" (attached to a header connector) using any one of a number of different types of connectors. Below you'll find a list of the common ones.
Common USB case header connectors 4 joined pins + 1 extra ground.
usbheader
Compatibility: Compatible with both header arrangements because of the extra ground. May not work with some odd arrangements To hook up carefully match each pin. For the Intel hookup you'll have the extra ground wire not attached to anything. For the Gigabyte hookup you'll have the extra ground hooked to ground pin on the motherboard, and the standard ground jumper will be over the missing pin on the header.
All pins separated
instusb6
Compatibility: Compatible with every header. If all the pins are separated the only real issue is lining up the pins with the appropriate places on your header. It should be compatible with all headers. Just make sure you read the writing on each individual connector. Please check the troubleshooting info at the end of the article for important information on this configuration
Power and Ground separate, d-, d+ joined Lian-Li style
Compatibility: Compatible with all common headers. This sort of arrangement is common to almost all Lian-Li cases. Make sure that you get the wires connected to your header in the proper order. If you find that the port does not function the most common cause is accidental reverse of the d-,d+. Try switching it.
All pins joined Intel style easy connector
usbinst4
making the Connection Once you know what type of header you have, and what type of connector you have on the wiring, you need to connect the two of them. In order to do this, you must first figure out what pin goes with what part of the connector. To do this, you should first consult your motherboard manual. Below you'll find an excerpt from a fairly recent motherboard manual for the Asus A7M266 motherboard. It's typical of a motherboard manual for a board using the Intel standard USB header.
instusb5
The first thing you'll probably notice is that the wiring from your case and the names of the pins might not quite match up name wise. This is a common problem. Motherboard makers and case makers really haven't decided on what to call each pin. Here's a rough list of names.
Power may be called: P, VCC, USB Power, Power, and PUSB. On wiring it's always red. Ground may be called: G, GND, Ground, and GUSB. D- may be called: USB-, USBP-, D-, or just -. D+ may be called: USB+, USBP+, D+, or just +.
To complicate things a bit more you'll probably notice that there's a number before each one. Take a look at the picture above from the USB hookup diagram for the A7M266.
You'll see that Asus decided to number the middle pins. On the first row (starting with pin 1, and marked with a 1) you'll find that they list D- as USBP2-, and D+ as USBP2+. The number 2 tells you a few things. First off: It's the 3rd USB port on the motherboard (they started numbering at 0), second it tells you that that D- and D+ must be used for the same port. Case manufacturers are just as likely to number their ports differently.
Take a look once again at the 4-pin joined picture: usbheader
Notice that you're D-'s have either a 1 or a 2 on them. These also tell you that they are part of the same USB port. (Remember, 1 port has 4 required wires). The numbering on the connector and the numbering on the header doesn't have to match.
To connect everything grab the following connectors: a same number D pair, (D-, D+), 1 power, and one ground. If your power and ground are numbered make sure all 4 are the same number.
Tip: Most cases that use all separated pins will bundle these together for you to make it easier.
Now, take your Power, D-, D+, and Ground and line the connector up with the appropriate 4 header pins on your motherboard. The header pins will be in a row under the Intel style, and in the Gigabyte style it will either be a row of 1 pin, a gap, and then 3 pins, or 3 pins, a gap, and then 1 pin. Press the connector down over the header pin and make sure it's firmly attached. Once you have done this go back and grab another set of connector wires (Power, D-, D+, Ground), and hook up your second front USB port. If your case has more then 2 front USB ports, and your motherboard has more then one front USB headers, then repeat the above as necessary.
Example: If you were hooking up the front USB on a A7M266, on a case with the pictured 4-pin joined connector type then: VCC lines up with USB Power, USBP2- lines up with USB1-, USBP2+ lines up with USB1+, and GND lines up with GND. For port 2, VCC lines up with USB Power, USBP3- lines up with USB2-, USBP3+ lines up with USB2+, and GND lines up with GND.
May 21, 2010 | Computers & Internet
USB56 Front USB hook-up to case
there is no chance to join differport to join in computer asmbaling. we should look port and size and conneting corner shape. we can asambling any port reading in bords smallptints and casing wire there is aprint in casing wire /reset/ p.led/hddled/ usb u can get front usb print in mother bord,
Oct 30, 2009 | ASUS P4S8X-X Motherboard
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
I am trying to hook up front panel usb ports.
check out this diagram i think it might help you
http://attachments.techguy.org/attachments/107266d1180693321/standard-usb-pinout2.gif
or if the link is unavailable then here is the same info
pins 1,3,5,and 7 are one usb connection
pin 1 = +5V
pin 3 = D-
pin 5 = D+
pin 7 = GND
pins 2,4,6,and 8 are another usb connection
pin 2 = +5V
pin 4 = D-
pin 6 = D+
pin 8 = GND
pin 10 is not used
Dec 04, 2008 | Intel Motherboard
Searching for a wiring diagram for my E machine....
Industry Standard Architecture exists here.
The pin arrangements for USB are standard, some usb headers are attached to the boards in the opposite direction but the pin arrangement is the same.
USB headers consist of 9 pins, arranged as 4 pins and one missing, and 5 pins like this:
x x x x o
x x x x x
these are marked as:
vcc1 usb 0- usb 0+ n/c
vcc2 usb 1- usb 2+ n/c
colours are:
red, white green black
Note: some motherboards have these connectors back to front but the connection sare as per the diagram
the audio header is arranged as follows:
X X X O X
X X X X X
top row = gnd, vcc5, mic2,n/c line
bottom row = mic1,mic r, line out,front spk r, lin out L
The cable colours may differ but the preformed plug will only fit in one place /direction
Oct 27, 2008 | E-Machines (308714) Motherboard
Havimg prob with the 2 usb ports located in front
Hi manky, Normally front USB ports have a pair of 4 wire cable with connectors marked red wire is vcc; white wire is -D; green wire is +D; and black wire is gnd. The motherboard would normally have two pairs of dual pin connectors that would be sitting side by side or in-line with uneven pins - 4 and 5 pins; then another 4 and 5 pins. Please refer to the attached simple diagram for your connection. For some reason I couldn't get hold of a manual from the Gigabyte site of your particular model GA-81KHXT. Nonetheless hopes this works for you. Pls post again how things turn up. Good luck and kind regards.
Jun 01, 2007 | Intel Motherboard
ECS P4s5a Socket 478 Motherboard Logo
96 people viewed this question
Top ECS Computers & Internet Experts
David
David
WTF Chuck.....
WTF Chuck.....
Coss
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
