Question about Midland LXT326 Two Way Radio
My midland 2 walk walkie doesnt work
It will turn on and recieve messages but nothing else it wont even turn back off unless i remove the batteries....and solutions?
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
See other entry...
Peter
Posted on Mar 06, 2013
vrc_tech
  • 109 Answers
SOURCE: need manual for Midland 75-515 FRS Speakeashy Ultra
Howdy from South Texas and Merry Christmas;
While I did not see any radios with the model number you mentioned here is a lik to the Uder Manuals on Midlands website. http://www.midlandradio.com/owners_manuals.asp
Patrick Patterson
Posted on Dec 16, 2008
SOURCE: Midland GXT800 radio, opened, reassembled, won't charge now...Help!
hi ive got a midland 3001 and i carnt find any one to speek to ?
Posted on Jan 12, 2009
SOURCE: can't get the click and back off of my walkie talkies to change
I had problems removing mine also. 1st remove the clip. With the back of the radio facing you push down firmly with your thumb and slide it off. At 1st I didn't think mine removed but after some extra force I was able.
Posted on Jan 30, 2010
SOURCE: Opening battery compartment on Midland LXT80 2-way radios
First take the clip off by pulling the tab while sliding it down. Then once the clip is off, push in and down on the top of the battery compartment and it should come off.
Posted on Aug 19, 2010
  • 31 Answers
SOURCE: I need new Battery packs
you can contact the mobile service provider........
Posted on Aug 31, 2011
My midland gxt quit working,why is that
is there power across the charger contacts ?
get a volt ohm meter & check for starters
usually if you leave the wall wart plugged in all the time they burn out & fail
Dec 25, 2014 | Midland Radio Midland Gxt795vp4 36 Mile...
One walkie talkie will send but not receive
Check your programming, specifically the private line (PL code) settings. This is one problem which can cause the problem you are describing.
Feb 22, 2014 | Midland Radio Midland Gxt 795 Vp4 Radio...
My Midland walkie talkie quits transmitting about 3 seconds after I start transmitting
It is more likely a power issue. PTT switches do not normally cause a short circuit. Check the batteries, swap the batteries and see if that helps. Radios take a great deal more power to transmit than turn on or receive. If not the battery, try a low voltage battery, such as a cordless phone battery. If it still occurs, check your warrany and send it back to the factory.
Nov 10, 2013 | Midland Radio Midland X-tra Talk Frs/grms...
Trying to get our Motorola (yellow/ black) to communicate with Midland two way radios. They Midland will receive messages from Motorola, but they can not send to it Motorola.
Most likely your CTCSS tone codes are not turned on on the Midland radios. The CTCSS codes are also known as "Privacy Codes" or similar.
They will be from 1 to 38. Your Midland manual will tell how to set the codes on the radios. The Motorolas usually show the selected tone code below the channel number.
Alternately, you may be able to turn off the tone code on the Motorola radio(s) by setting it to "0" or "off". Then you will not need codes turned on on any of your radios and they should all communicate fine.
Dec 16, 2010 | Motorola Walkie Talkies 2-Way Radio
Can't get the click and back off of my walkie talkies to change
Dec 31, 2009 | Midland LXT310 2-Way Radio
One of my midland lxt 420 walkie talkies wont charge!!!!!
If it has rechargable batteries in it like mine does, the batteries have probably lost all of its life.. you can replace them.. if you dont have batteries, you could have a loose wire inside the walkie talkie that wont let it charge..
Jul 29, 2009 | Radio Communications
Im only able to hear out of one of my walkie talkies
Make sure you are using the same channel and privacy code as outlines in the manual for each radio.On the creen the large number is the channel and the smaller number is the privacy code.
Here is a link to the manual: http://www.midlandradio.com/comersus/store/catalog/LXT410%20Owners%20Manual%20RevH.pdf
May 06, 2009 | Midland LXT310 2-Way Radio
Need to tune and peak my midland 1000 cb
sounds like a problem to me . I have one that was in fair shape that had the same symptoms , I pounded the crop out of it with a hammer and now it doesn't recieve anything . You can't find a service manual for it ,unless midland will sell you one but don't hold your breath . Remember a 26 oz. hammer works good but not the radio.
Apr 07, 2009 | Midland 1001Z 40-Channels Base CB Radio
T5900 Walkie Talkie Issue
Hello Bo Duke,
If one radio won't walk to the other my guess if that you have the Privacy Code function set up incorrectly.
The privacy code function mutes the radio unless it receives a signal from another radio transmitting the same privacy code. If Privacy Codes are turned on for Radio A but not turned on for Radio B then you will be able to transmit from Radio A to Radio B but not from Radio B to Radio A. If Privacy Codes are turned on for both radios but each unit is set to a different code then neither radio will be able to talk to the other.
Make sure that the radios are both set to the same privacy code or that the privacy code function is turned off on both radios. You can find more information on how this function is set in the radio's Owner's Manual.
Hope this helps!
Ken
"Go Ahead. Use Us."
Jul 02, 2008 | Motorola Walkie Talkie 2-Way Radio
Midland LXT326 Two Way Radio Logo
124 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
