Question about Kenwood eXcelon KDC-X689
Kenwood excelon KDC-X689
The fold up hide away cover actually folded up w/o the face plate in it. How can I reset it so it folds back down ready to accept face plate?
I have already disconnected the battery as a first attempt,, then removed radio from vehicle and used different power source,, to no avail,,, also fuse on back of radio tested fine
  • unionsparky May 29, 2011
    Did you ever solve this problem? My radio is doing the same.
5 Suggested Answers
SOURCE: Kenwood Manual for KDC-X589
http://www.retrevo.com/support/Kenwood-KDC-X589-Car-Receivers-manual/id/479dj585/t/2/
There you go, i dont know if you already found it but there it is for anyone else as well.
Posted on Jan 09, 2009
  • 105 Answers
SOURCE: what is the security code for this kenwood car
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Posted on Jul 15, 2009
SOURCE: I want to change the clock on my Kenwood Excelon KDC-X589.
Put it in standby and push the "menu" button, once in there use the right am/fm knob to scroll.... done
Posted on Aug 10, 2009
  • 2267 Answers
SOURCE: Where can I download a free operating manual for a
Click here to download the user's guide.
Posted on Sep 07, 2009
adnanbhatti
  • 1188 Answers
SOURCE: I need the manual for a Kenwood eXcelon KDC-X993
You can download the original user's manual from Kenwood website. Click on the link below and an online pdf will open in you browser window:
Be sure to have the free adobe pdf installed. You also right-click on the above link and select "save as" to save this online manual for further reading.
To visit Kenwood website for this receiver click here.
Posted on Oct 20, 2009
I have a kenwood kdc-x689. The screen went dim before it stopped working. The fuse on the back of the unit is still good. Please help me! Thanks!
There are more fuses which are to be checked other than the one at the back , The power supply fuse should be within the fuse box of the car , Do check them and you'll be fixed for sure , Just find the fuse box and how to replace one using your owners manual
thank you
Jun 01, 2011 | Kenwood eXcelon KDC-X689
The fold down panel does not retract all the way when the unit is turned off
you may have a gear inside the deck that is out of position.
it probably needs to be taken apart and adjusted.
Oct 13, 2010 | Kenwood eXcelon KDC-X769 CD Player
Radio does not turn on, and can not eject cd.
HAVE YOU REPLACED UNIT? IF YOU HAVE THEN IT COULD BE THE SWITCHED / CONSTENT FEED BEING AROUND THE WRONG WAY, YOU CAN TEST TO SEE IF YOU HAVE A CONSTENT FEED WITH IGNITION OFF ON ONE OF THESE, AND A FEED ON THE OTHER YOU TURN IGNITION ON, THE THESE ARE NORMALLY RED AND YELLOW SWAP THEM ROUND, GROUND/EARTH IS BLACK, FUSE N HEAD UNIT NORMALLY BEHIND THE PLUG THAT FITS IN THE HEAD UNIT
Dec 06, 2009 | Kenwood KDC -X815
Cant remeber my code 4 digets to unlock my phone
bring it in to an authorized dealer and they will unlockit for twenty dollars
Jul 16, 2009 | Kenwood eXcelon KDC-X689
Cd player locked
It has a defective ribbon cable between the face and the motherboard. This is a common repair, but must be done by a repair shop. My shop charges around $60-70 for parts and labor for that repair, to give you a ballpark of what to expect.
Sep 09, 2007 | Kenwood eXcelon KDC-X689
Car Audio & Video Logo
59 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
