Question about Sony VAIO VGN-FJ270/B Notebook
Display problem i tried to boot to safe mode but still no display. i dont know what's the problem with my laptop. when i boot to ubuntu linux there was a display. Sony laptop display stays off even after reboot. Happened a few days ago and after a couple reboots it lit up again. No luck today. Any ideas?
  • Unclemiketoo Jan 22, 2009
    Is there help like these for SONY Laptop's?
  • Anonymous Jan 22, 2009
    I have the same problem, do you know if anybody can repair it for what the sony company does?
  • Sony Master
  • 32,281 Answers
If the laptop appears to boot up and the hard disk is spinning and the hard disk LED is flashing then the hard disk is OK.
Then the fault could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jul 20, 2009
My FUJITSU SIEMENS AMILO PA 1538 screen comes black ? HELP
Try connecting the laptop to an external monitor and see if all is working Ok with that, if it is, then you may need to get the laptop display serviced - if it does the same on the external display, then try booting the laptop from a CD or DVD such as an OS install CD (Windows or Linux) or a boot utility CD such as Hiren's Boot CD - this will allow you to test whether the problem lays with your installed operating system or with the hardware. . . .
Note: do not go any further than the initial displays if using an OS install CD unless you are using a Linux Live boot CD which will not destroy your installed operating system. . . .See http://www.hirensbootcd.org/ to download a copy of Hiren's Boot CD to burn to a CD. . . .See http://www.ubuntu.com/download/ubuntu/download to download a copy of a Ubuntu (Linux) Live CD.
Dec 17, 2011 | Computers & Internet
I have a Medion Akoya E5211 laptop that won#t reboot
How far through the boot process will it go? What version of windows are you running?
To get your data off the hard drive you have a couple of options. The easiest is to take the hard drive out and mount it as a second hard drive in another computer, then simply access the drive from windows and copy your data.
If your laptop is more than a couple of years old (has a pata drive) or your computer does not have an open sata port, then you can use an adapter like this to connect it to any computer with a USB port.
If you don't want to remove your hard drive (and you have a spare usb thumb drive laying around), then you can make a bootable usb drive to boot your computer and copy your files either to another networked computer, or to a usb memory.
To do this, go to http://www.ubuntu.com/download to get a copy of ubuntu linux... click on the "Try it from a CD or USB stick" option.
On the page that opens, under step 1, click on start download to begin downloading the latest version of Ubuntu. You'll probably have better driver support with the 32 bit version.
Then go to step 2. Select "USB Stick" and click on "Show Me How" and a fold out will open with more instructions.
You will be asked to download a utility to mount Ubuntu on your USB drive (needs to be at least 2GB capacity). Download this utility to the same folder as the Ubuntu installer.
Once Ubuntu has finished downloading, run the utility and follow the rest of the instructions from the Ubuntu download page. Note that the instructions refer to version 11.04, but the current version is 11.10.
If you followed their instructions properly, you should now have a bootable USB drive. Insert this drive into an open usb port on your laptop and start it up.
You will most likely need to go to your bios setup and change the boot options to include USB devices. Make sure it it set to check the usb device before the hard drive, or it will just keep trying to boot to the hard drive.
to get into your bios setup you need to hit a key while your machine is first booting... it should tell you something like "Hit F2 now to enter setup". F2 is the most common key, but it could be the delete or some other key.
Once you set up the bios, save the changes and exit to reboot your computer. It should now detect the USB drive and boot to Ubuntu.
Ubuntu is a linux based OS and has good driver support for newer computers, so you should be able to connect to a wired or wireless lan without too much trouble.
Nov 22, 2011 | Computers & Internet
Laptop turns on, goes to first screen which reads IBM TRHINKPAD. THEN FLASHES OFF TO NEXT SCREEN WHICH READS THE WINDOWS XP LOGO then it goes black and doesnt come back on
Your installation of Windows is most probably corrupted. Try pressing and holding the F8 button on your keyboard when the 'IBM THINKPAD" screen disappears. That should bring you to a Windows menu where you can select various modes. Select Safe Mode and press enter. If it boots, then you know that something's wrong with Windows and not the notebook itself. What have you installed prior to this problem? Maybe you should try uninstalling it while in safe mode, and then try starting up Windows normally again.
If your windows doesn't start anyway, you should get some live OS (OS that can boot from CD) like Ubuntu or Puppy Linux, so you can save the data from C: partition (burn it or copy it elsewhere) and then reinstall your copy of Windows XP.
Sep 01, 2011 | IBM ThinkPad R32 2658 Notebook
My laptop get restart in an intervals or get hang ...
This will occur if the Windows files are Corrupted or Fragmented, the solution is to backup by logging in to Safe Mode. Please restart the computer and try pressing F8 Key to select Safe Mode. If the Safe Mode is working fine then please backup the data and Format the computer using the Window XP or the Operating System Disc which you have. If the Safe Mode is not working then use any Linux CD like Ubuntu (www.ubuntu.com) it's free! Then boot the CD to backup the data for any external Hard Drive or Pen Drive and format the Notebook using the appropriate Operating System Disc like Windows XP, Vista, or Windows 7.
Mar 26, 2011 | Toshiba Satellite Pro L300 Notebook
Freezing up when booting up in the dell screen when it has been off for a will it will start to boot windows XP and dont go any farther thn the welcome screen before it freezes up. I tryed replacing the...
Have you tried booting from the original system CD? Another option would be to download and burn an ISO image of Linux Ubuntu Workstation 9.10 Live CD. Try to Boot from this CD. If it boots successfully, it should give you the ability to access your hard drive to retrieve your data. It might also indicate if your system is having a hardware issue. We have installed and run Ubuntu Linux and plenty of these machines with good success... great way to troubleshoot hardware functionality and allow access to data without loosing it.
Apr 12, 2010 | Dell Latitude D610 Notebook
Installed ubuntu 9.10 now can't boot XP. Black
Now that you have installed ubuntu which is linux did you make your pc able to do dual boot. It is possible you have overwriten some important files like master boot record while doing ubuntu installation. Most times blinking cursor means no hard drive or operating system. you can try poping in XP cd and try to do recovery if you have it. Also easiest would be if you could boot into safe mode and try to fix the issue by replacing missing or corrupt files.
Dec 14, 2009 | Computers & Internet
Blue screen unmountable boot volume error, I have tried to reboot with the CD windows XP and the F-12 and F-2 no success. I have tried to reboot in safe mode last configuration still no success.
Sounds like a bad hard drive. You can try using a live linux cd like Knoppix or Ubuntu
Ubuntu is easier for most.
That way you'll know whether it's the hard drive or another issue with the laptop.
Feb 21, 2009 | Dell Inspiron 1300 Notebook
Display problem
are you using ubuntu, there is no easy way to safe mode in ubuntu what command are you using to go into safe mode,
here is an helpfull link
http://ubuntuforums.org/showthread.php?t=915948
have you tried to install windows after linux was there and you are getting some grub error or something
if so let me know the error
Further queries are welcome
if you find my solution helpfull please do rate me
Dec 12, 2008 | Dell Inspiron B130 Notebook
Dual boot
There's probably a problem with your display drivers in XP.
Try booting in Safe Mode (F8 on startup). Now your display should work.
If you boot in safe mode with networking, you can visit the graphics-card manufacturer's website and download the latest drivers. After installing these, try rebooting normally...
Dec 11, 2008 | Dell Inspiron B130 Notebook
HP Pavillion ze5600 notebook won't boot up
Try booting, hit F8 for the list, go to safe mode but right after you hit enter to go into safe mode hold the left and right <ctrl> keys. That loads minimal amount of drivers as possible. Do you have you Win XP disk in case a repair is needed? Let me know what happens.
Apr 14, 2008 | HP Pavilion dv1000 Notebook
Sony VAIO VGN-FJ270/B Notebook Logo
156 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
