Question about Samsung Televison & Video
Samsung tv tuning problem. Bit error level 2000
Please can anyone help me? I have a Samsung tv (model code: UE32C4000) which I am having problems with. I had a plug in aerial in the tv which picks all the channels up perfectly. I had this for the last yr and no problems. I took the aerial out at Christmas to put on a different tv. Now I have plugged it back into my tv and it's not bringing up any channels at all. I have tried everything. All is connected correctly. There is no problem with the aerial as it still works fine on the other tv. Looking at the settings on my tv I found a menu which said: Bit error level = 2000. I have spent hours trying to re tune my tv. Please can anyone help?
SOURCE: will not store bbc1 dvb channel
I have contacted Panasonic, they are aware of the problem and will post you an update card to correct the fault.
Posted on Oct 27, 2009
  • 15 Answers
SOURCE: SAMSUNG LCD WONT TUNE INTO NORMAL TV STATIONS
You need to have a licensed antenna repairer out to fix your antenna. Just because your old tv is receiving enough signal to JUST get a picture doesn't mean your new tv will, A new tv doesn't mean you will get a perfect picture if your antenna is dodgy
Posted on Dec 30, 2007
  • 61 Answers
SOURCE: troble tuning in
If your recorder is hooked up after the cable box, then it can probably only receive channel 3...the set-top box does the switching, and sends everything to the TV (and recorder) on Ch. 3
Posted on Jan 27, 2008
tvtek
  • 1284 Answers
SOURCE: Digital TV Tuning problem
I would try letting the set autoprogram again.
Posted on Mar 08, 2008
  • 3 Answers
SOURCE: Vason 10.4 inch portable tv tuning problem
I returned my original TV/DVD to the suppliers who then sent me a new one.
I experienced exactly the same tuning problem with the new TV.
The only way I could tune it, was by using the fine tune facility to find and store the missing stations. This took a lot of time and continuous button pushing, so patience is essential.
Once found and stored, the previously missing channels are perfect.
It would appear that the DVD player doesn't like DVD- recordings from my home recorder. If they are re-coded they work.
Anything recorded on DVD+ is fine.
In my opinion this is a good unit let down by a couple of niggling faults.
Posted on Mar 23, 2008
My Samsung refrigerator Model RFG297HDRS-XAA has 15-E code flashing.
Existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
You might be having two error codes instead of one code
error 1 and Error 5.
Error 1 refers to 1. Ice Maker Sensor:
Ice Maker sensor connector missing, contact failure, electric wire cut, short-circuit, Ice Maker sensor failure.
Indicates an error when the temperature sensed by Ice Maker sensor is higher than 150 or lower than -58.
Error 5 refers to 5. Ice Maker Function Error:
Ice ejector and level failed three times or more.
Jul 12, 2017 | Samsung Refrigerators
Please can anyone help i cant tune my tv it wont pick up any channels when i auto tune it it says weak or no signal but i plugged aerial and tuned another tv and its fine
Are you trying to get over the air channels? IF you are does your TV have the digital tuner on analog? TV went digital and if you have an analog tuner will need either e new TV or converter box.
Jul 01, 2015 | Samsung 65" F9000 Series 4K Ultra HD Smart...
Samsung model wa 7584C1. has 1E error code have changed pressure switch and tub hose still shows the same error please help
IE - Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
  • Apr 06, 2015 | Samsung Washing Machines
    My Samsung LCD LE32A457C1D wont find any services please help
    Hi there Convince yourself that all cords and plugs are where they should be. Especially that the input is correct. If you have HD then it is best to use HMDI connection. It should also work with the scart connections in the right place. It usually says on the cable and the port. Godd luck Kolbrun
    Jun 24, 2012 | Cell Phones
    I need a code for my Samsung tv model LE37A456C2DXXU, to connect my Sky remote to the television. Thankyou.
    Please rate this solution if you find it helpful. Thanks.
    It really depends which version of Sky remote you have. You can check this by looking inside the battery compartment. If you have a sticker with RC1600/00 then it probably wont work your TV. If it says Rev 4, or Rev 6, it might work with this code: 0646
    If you have a Rev 8, then try these 3 codes: 1340, 0840 or 0646
    Sky's information is a little bit contradictory regarding your particular model of TV, so I don't guarantee success. However, 0840 and 0646 seem to be generic Samsung codes, so I think these would probably control the power and volume functions on you TV if nothing else.
    Try the codes above and report back.
    Oct 16, 2010 | Samsung TV Set Top Box Remote Control
    Under signal information I've got bit error level 10 and signal strength 0. TV just stopped showing channels. What do I do? Already tried retuning, didn't find any channel.
    Hi zaikovskis
    I`m going to help you with your tv but first; could i have the brand name and model number?
    Should be written on the back of the set.
    Mar 31, 2010 | Samsung Televison & Video
    I need help finding the code for my tv. i have a Philmore universal remote pm-rc13. My t.v is a white-westinghouse
    Here is the code for your TV 0154 along with the advanced codes.
    Advanced Codes for TV_0154TVs ------------------ <TV Group>
    0154 244 ACM 165 Fine Tune Up 251 SAP 167 Surround Mute
    244 Auto Chroma 244 MTC 231 Speaker In 168 Surround Vol dwn
    251 Bilngual 234 PIP Location 233 Speaker Out 164 Surround Vol up
    169 Fine Tune Do 228 PIP Select 247 Stereo 129 Component 2 (discrete)
    TELEVISION. Uses with:
    TUNER/CD/TAPE/PHONO/AMP..CDs................AUX2 088
    TELEVISION...............TVs..................TV 154
    VCR......................VCRs................VCR 047
    VCR......................VCRs................VCR 104
    On some models,
    100|AM/PM|1-- may be 100/Enter;
    Func|Sel may be Digicon;
    Level Up|R may be Control Right, Level Up/Minute or Menu Up;
    Level Dn|L may be Control Left, Level Dn/Hour or Menu Down;
    Review|Qck View may be CH Recall or Quick View;
    SetTime Fast may be Stereo Matrix;
    SetTime Slow may be Time/Day, Set Up, Clear or Menu;
    TV/Video/AV may be TV/AV, Video Mode, Input or A/V;
    Wide|TV|Loud may be Stereo Matrix, Surround or Mode;
    MTC|OBC|Auto may be ACM or Auto Chroma.
    181 0...............0 185 1...............1
    120 ENTER...........1-- 120 ENTER...........100
    183 2...............2 187 3...............3
    180 4...............4 184 5...............5
    182 6...............6 186 7...............7
    053 8...............8 057 9...............9
    185 1...............A 123 A/B.............A/V
    120 ENTER...........AM/PM 059 CHANNEL DOWN....AM/PM
    183 2...............B 187 3...............C
    249 RECALL..........CH Recall 059 CHANNEL DOWN....Channel Down
    055 CHANNEL UP......Channel Up 122 PROGRAM.........Clear
    250 STOP............Control Left 246 PLAY............Control Right
    250 STOP............Cursor Down 059 CHANNEL DOWN....Cursor Left
    055 CHANNEL UP......Cursor Right 246 PLAY............Cursor Up
    180 4...............D 055 CHANNEL UP......Day
    184 5...............E 120 ENTER...........Enter
    182 6...............F 121 SHIFT STOP......Fine Tune Dwn
    117 SHIFT PLAY......Fine Tune Up 248 PAUSE...........Function
    186 7...............G 053 8...............H
    250 STOP............Hour 057 9...............I
    123 A/B.............Input 181 0...............J
    059 CHANNEL DOWN....K 250 STOP............Level Down
    246 PLAY............Level Up 122 PROGRAM.........Menu
    250 STOP............Menu Down 246 PLAY............Menu Up
    246 PLAY............Minute 116 SHIFT PAUSE.....Mode
    245 MUTE............Mute 230 SHIFT FFD.......PIP Freeze
    235 FAST FORWAARD...PIP On/Off 232 SHIFT REW.......PIP Replace
    119 POWER...........Power 052 DISPLAY.........Recall
    249 RECALL..........Review 248 PAUSE...........Select
    122 PROGRAM.........Set Up 118 REWIND..........SetTime Fast
    122 PROGRAM.........SetTime Slow 056 SLEEP...........Sleep
    116 SHIFT PAUSE.....Stereo Matrix 118 REWIND..........Stereo Matrix
    116 SHIFT PAUSE.....Surround 122 PROGRAM.........Time/Day
    056 SLEEP...........Timer 181 0...............Timer Set
    056 SLEEP...........Timer Start 116 SHIFT PAUSE.....TV
    123 A/B.............TV/AV 123 A/B.............Video Mode
    058 VOLUME DOWN.....Volume Down 054 VOLUME UP.......Volume Up
    116 SHIFT PAUSE.....Wide
    Hope this helps. Let me know if I can help you with anything else.
    JimmyC
    Sep 29, 2009 | Televison & Video
    Side by side Samsung TV's need remote control solution
    If possible turn one off and tune the other. Then turn the other off and tune it. Then turn on the other. That is your only option at this point.
    Feb 16, 2009 | Samsung PN50A650 49.96 in. Plasma HDTV
    NO DTV CHANNELS
    There may be an input button on the remote, or on the TV, that allows you to switch from the standard ATSC tuner to the DTV tuner.
    Let me know if you can't find it and I will dig for an owner manual. But the above should allow you to switch tuners and input sources.
    Feb 16, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
    Car radio code
    I had the exact same problem, I contacted Mitsubishi and they gave me the code.  All I had to have was the serial # (the number you have is the model number - the Serial # is on top of the radio, you will need to pull the radio out a bit to read it) and of course your VIN.  Their contact statement on their website is as follows:
    For questions regarding your Mitsubishi vehicle, please contact Mitsubishi Motors North America, Inc. at 1-888-MITSU2009.
    I hope this helps you out with your issue!
    Oct 26, 2008 | 2000 Mitsubishi Galant
    Televison & Video Logo
    2,375 people viewed this question
    Henry  Thomas
    Henry Thomas
