Question about Universal Heating & Cooling
The red light on my "receive/alarm" on my WR1 wireless system box is constantly flashing?
The boiler is working but I don't understand what the red light flashing means
SOURCE: vokera combi boiler
air in system
Posted on Aug 11, 2008
SOURCE: HTS9800 Wireless receiver not working
I have just bought one of these today and have had the exact same problem. No rear sound and no blue light on the receiver box.
Solution:
What philips don't tell you in the manual and on the support site is that the receiver box has a switch hidden under a white sticker; next to the left of the right speaker connection. The switch has 3 positions which can be selected. I had tried each switch position and power cycled the subwoofer each time until eventually i got a blue light on the receiver box.
You may also need to select the correct channel on the control box by pressing the "sound" button for 5 seconds on the remote control.
It took me quite a while to try the different combinations until it finally worked. I can't imagine that Philips would have sent the system out without testing the wireless partnership first, so I am guessing my wireless network could have had something to do with it. (forever the optimist).
I did expect the subwoofer standby light to have gone off or changed colour once operational, but this just seems to stay on no matter what state it is in.
Posted on Sep 30, 2008
MAD ICE
  • 52 Answers
SOURCE: wireless mouse stops to work after i turn off the computer
visit this site it will tell you the instructions step bye step
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00006821&cc=ca&dlc=en&lc=en&jumpid=reg_R1002_CAEN
Posted on Apr 15, 2009
SOURCE: wireless mouse not working
try changing the battery to the mouse. my brother suggested this to me and I thought it was a dumb idea because the batter in my mouse was working fine. well...low and behold, changing the battery worked.
Posted on Sep 22, 2009
aasc
  • 1606 Answers
SOURCE: Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Posted on Sep 27, 2009
Testimonial: "Will try suggestions. Thanks!"
I have a Worcester 24di combi boiler and it's not working I have a red flashing tap light have represurised the pressure but still not working I have no heating or hot water can you help me please
Red flashing lights usually mean trouble.
There is not enough air getting to the combustion chamber, or the chimney is not working properly. (Stopped up flu)
If this is not a pretty obvious problem, it is better handled by someone who knows a lot more about it than us.
Feb 26, 2016 | Water Water Heaters
Red sercurity light flashes in my truck
You could try re locking the doors then unlock them. Then open the hood and disconnect the negative terminal on the battery for 2 minutes. Hook up the battery and start the truck. This will flush the PCM's cache and restore everything to its normal state.
Dec 11, 2011 | 1999 Dodge Durango
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
How much is it to replace the lamp and how do I do it. The red light flashing for lamp means the lamp needs to be replaced for sure?
I'm sorry that the LAMP light flashing. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the TV flashes, it indicates that the lamp of the TV needs to be replaced. Based on the information you have provided, it is the time to replace the lamp with a new one. XL2100 is the replacement lamp for the TV.
The Original Replacement LAMP costs $199 from Sony. Please click hear to order it online.
Please refer page # 16 of the Instruction Manual of the TV to get the instructions to replace the lamp.
Click hear to download the Operating Instructions if you don't have one handy.
I hope the information helpful. Thanks for understanding. Please let me know if you require any additional help/clarifications.
Aug 01, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hi, I droped my SP-320 yesterday and now i can't turn it on. The red and green light is flashing. What does the flashing lights means? Joe
I have the same problem with flashing red and green light when I tried to turn on my Olympus SP-350.
I don't know what's wrong, so please let me know if you have any clue. I personally did not drop the cam, but someone else might and did not tell me :(
May 25, 2011 | Olympus SP-350 Digital Camera
Panasonic kx dt 333 When the phone rings the red light doesn't flash to denote which line it's coming in on. Any idea how to resolve this?
Which means what? You have a solid red light on the line or you don't have the line at all. A TDA system rings by a process called ICD groups. You can have a phone in an ICD (600 by default) and tell it the number of rings to delay, not ring, or immediate ring, but that means that the line button will flash as the call is coming in. If you don't assign it to a group, it's really stupid and won't do anything but light solid red.
If you have access to installer programming, you assign the extension to the main ICD. If you don't you have to call your Panasonic installer or dealer.
Carl
May 11, 2011 | Panasonic KXDT333 Phone
Flashing red light on ice maker control unit inside freezer
I understand the price seems pretty high have you tried an OEM for a better price. I am understanding that your filter is a common filter 4396510 I think is the aftermarket number
Apr 15, 2009 | Refrigerators
Heating & Cooling Logo
2,365 people viewed this question
Top Universal Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you an Universal Heating and Cooling Expert? Answer questions, earn points and help others
