Question about Casio FX-300MS Calculator
Geometric Mean I am trying to Calculate the Geometric Mean on a TI-30Xa and am unsure as to the correct sequence of keying. Thank you.
  • 8,197 Answers
Before using the gonometric functions (), *,
+, " V, " W, or " X), select
DEG, RAD, or GRAD with #. Note: Before using a DMS
value in a calculation, you must convert it to decimal
with " q.
# (if necessary) DEG
90 ) DEG 1.
> 30 * DEG 0.866025404
J DEG 0.133974596
1 " V DEG 90.
> .5 J DEG 89.5
Also if you need heereis the manual
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck
Posted on Jan 21, 2009
    Sergeant:
  • 378 Answers
Http://www.wikihow.com/Calculate-the-Geometric-Mean
get the exact system of how to calculate the geometric mean of any equation you want.just click the link and follow the directions step by step.
  • 3,037 Answers
Hi rsaavedra602
Here is the guide if you need it
http://www.casioeducation.com/resource/pdfs/fx300ms_training_guide.pdf
Standard Deviation
Use the [MODE] key to enter the Standard Deviation (SD) mode when you want to perform statistical calculations using standard deviation. [MODE] [2]
• To clear statistical memory, press [SHIFT] [CLR] [1] [=].
• To enter data, use the following key sequence: <value> [DT]
• Input data is used to calculate the following values:
Sum of the squares (σ x2) [SHIFT] [S-SUM] [1]
Sum of data (σ x) [SHIFT] [S-SUM] [2]
Number of data items (n) [SHIFT] [S-SUM] [3]
HERE > Mean of the data [SHIFT] [S-VAR] [1]
Population standard deviation σ n [SHIFT] [S-VAR] [2]
Sample standard deviation σ n-1 [SHIFT] [S-VAR] [3]
let me know if you need anything else
bestdarngood
    Sergeant:
  • 221 Answers
Http://www.retrevo.com/support/Casio-fx-300MS-Calculators-manual/id/467dj289/t/2/
get the instructions for using a calci in the link above.
    Genius:
  • 1,269 Answers
What exactly are the value that you are trying to compute?
Hi, how do i calculate log^-1(-2) on my ti-30xa? thank u.
The inverse of the log function is the power function.
For log in base 10 that inverse is 10 to a power of
More generally, let b be the base of the logarithm. If y=log_b (x) then x=b^y
For your case log=log_10, to calculate the inverse you perform 10^(-2)=0.01=1/100
On calculators the log in base 10 and its inverse share the same physical key. One is accessed directly, the other is the shifted key function.
Sep 09, 2011 | Texas Instruments TI-30XA Calculator
Hi, how do i calculate log^-1 on my ti-30xa? for example, in order to calculate log^-1(-2), what do i do? thank you.
The inverse of the common log function is the power function with base 10 (10^). It shares the same physical key as the log. You acees the function by pressing [2nd] [log]
I can't seem to get my calculator into statistics mode. could you please explain it very clear. i must be mising something. i have a texas instrument calculator(Ti-30xA).thank you.
The TI-30Xa does not have a statistics mode. That statistics operations are available at all times, just like addition and subtraction. Just enter the data with Sigma-plus and then calculate the desired statistics---mean, standard deviation, and so forth.
Full details are in the "One-Variable Statistics" section of the guidebook (page 9 in my copy). If you need the guidebook, you can download one from
http://education.ti.com/calculators/downloads/US/Guidebooks/Detail?id=6132
Jun 23, 2011 | Texas Instruments TI-30XA Calculator
Now that I know where the square root button is on my TI-30Xa, how do I calculate a "geometric mean" when the equation inclues a time period? For example the problem is setup like this: 6...
You don't want the square root. In this example, you want the sixth root.
Press 4 5 2nd [xth-root] 6 =
The xth-root is the shifted function of the y^x key, located just above the divide key.
Jun 11, 2011 | Texas Instruments TI-30XA Calculator
Which button do I use for the square root button? I have to perform math problems on... geometric mean population standard deviation sample standard deviation
The square root button is two up from the 9 key, just to the left of the divide key. To calculate the square root of 2, for example, press 2 square-root =
Jun 10, 2011 | Texas Instruments TI-30XA Calculator
Okay so i am using a TI-30XA What is the button on this calculator for (Prb) ??
There is no probability key on the 30Xa as there is on the 30XIIS. The shifted functions of the 8 and 9 keys will calculate the number of combinations and permutations, respectively. The shifted function of the 3 key will calculate the factorial. There is no random number generator.
May 09, 2011 | Texas Instruments TI-30XA Calculator
How do you use the -log function on the TI-30XA calculator? I downloaded the manual and there is no instruction for finding the -log of a number
Do you mean the antilog? For the common antilog, use the shifted function of the LOG key (marked 10^x). For the natural antilog, use the shifted function of the LN key (marked e^x).
For example, to calculate the common antilog of 0.5, press . 5 SHIFT [10^x] = and get about 3.16. To calculate the natural antilog of 0.5, press . 5 SHIFT [e^x] = and get about 1.65.
Mar 29, 2011 | Texas Instruments TI-30XA Calculator
Finding a cube root on calculator
You can calculate cube roots by using the cube root function (the 2nd-shift of the 0 key). You can calculate arbitrary roots by using the x-root function (the 2nd-shift of the y^x key, just above the divide key).
May 27, 2010 | Texas Instruments TI-30XA Calculator
How do i find the negative log on a TI-30Xa
Ex: calculate -log(15.32)
  1. Calculate the log 15.32 [LOG] [=] result 1.185258765
  2. Then press the change sign key (-) result -1.185258765
You can also try 15.32 [LOG] (-) [=]. Try to veriufy it on your calculator.
Hope it helps
Dec 13, 2009 | Texas Instruments TI-30XA Calculator
The e to the x button
If you mean (e to the power x) minus 4, where x = -1, the key sequence would be:
+/- (above 3 key)
2nd
LN
Result is -3.63212.....
If you mean e to the power (x-4) where x = -1 again, it's:
10.0067379....
+/- (above 3 key)
2nd
LN
Answer
Jun 26, 2008 | Texas Instruments TI-30XA Calculator
Casio FX-300MS Calculator Logo
138 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
