Question about Apple TV 2010
Apple tv 2 picture cut off - Apple TV 2010
Tip
How to connect an iPod to a TV
<p>The iPod is a very capable media player personal, but sometimes that tiny screen just does not cut it. Fortunately for owners of iPod, Apple allows users to connect their devices to a TV, so that the videos from your iPod to transmit to the screen. For this connection, iPod owners to buy an extra TV out cable, which is sold in most electronic stores. <br /> <p><br /> <p>1. Buy a cable TV output compatible. Apple sells three TV-out cables, iPod composite cable, composite cable Apple and the Apple Component Cable. See the References section for an iPod TV out cable compatibility list to ensure that you have purchased the correct cable. <br /> <p><br /> <p>2. Connect your iPod to TV out cable TV. Depending on the output cable TV you bought, the cable connects the input of the composite or component input on your TV. Each entry is color coded to the appropriate plug-ins to handle. <br /> <p><br /> <p>3. Connect the other end of the cable to your iPod. The cable consists iPod is connected to the headset connector iPod, Apple, while the other two-plug cables into the wall socket. <br /> <p><br /> <p>4. Turn off the TV mode on your iPod through the opening of "Video Settings" from the "Videos" menu on your iPod and change "TV Out" to "On." <br />
on Aug 09, 2011 | Apple iPod touch
With apple tv sound is low and picture with green spots
if its a apple tv 2 or 3 it may be a defective unit or a bad hdmi cable
Aug 10, 2013 | Televison & Video
When cut on times out and cuts self off. some times comes on and the picture is good
The tv projection lamp been inside the tv like 1 1/2 or 2 years already and tv been on used daily like 4 or 5 hrs daily?Yes,the tv projection lamp life are ending.Replace the tv projection lamp.
Mar 18, 2011 | Sony KP-46WT520 46" Rear Projection...
Cable jack is connected through the comcast box and then hdmi cables are connected from the comcast box to the tv. The cable jacks on the tv do not work. The picture was clear and then it cuts in and out...
The tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must be replaced to fix the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 05, 2011 | Toshiba 57H83 57" Rear Projection HDTV
We have an old TVwhose picture cuts out every 5mins or so
Not a picture tube problem. Re tune the the TV by auto search or manual tuning.
Store your favorites later in your way.
May 03, 2010 | Televison & Video
No picture on television when connecting s-video outlet from JBL radial and showing a film or pictures on a docked i-pod touch.
Hi, I have this problem and when I spoke to JBL techical support they told me that Apple have changed their software on the New Nano and the ipod touch and of course the iphone and regrettably the radial does not support S video for these products. I'm told it will work with first generation ipod classics. PS: i had to carefully cut off some of the plastic plug to make sure the connection goes all the way into the back of the radial
Dec 27, 2009 | JBL Radial Speaker Dock Docking Station...
What`s seems to be the porblem
IT SOUNDS LIKE THE VERTICAL I.C. NEEDS SOLDERING. WHEN IT LOOSES THE PICTURE DOES IT HAVE ERROR CODE 2 ? THE RED LED BLINKING 2 THEN 2 THEN 2. THAT IS LOSS OF VERTICAL. IF YOU SMACK THE SIDE OF THE SET.(NOT TO HARD) WITH OPEN PALM ON LOWER BACK IF THE PICTURE COMES BACK IT IS THE VERTICAL IC THAT NEEDS TO BEE SOLDERED.
DON.
Jan 31, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture but has sound
have a 42 inch rca 42PA30RQ NO PICTURE OR SOUND WHAT CAN I DO MY SELF BEFORE SPENDING A LOT OF MONEY TAKING TO A REPAIR SHOP
Dec 14, 2007 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
hello .this does sound like bad solder joints .all printed circuit boards do this after a while due to heating and cooling .is not advisable to try to repair yourself .possible electric shock and spiking .will do a lot of damage .take to a shop to have repaired
Oct 30, 2007 | Sony KV-36XBR450 36" TV
Apple TV 2010 Logo
27 people viewed this question
Top Apple Televison & Video Experts
Carlos L. Burgos
Carlos L. Burgos
Andrew Taylor
Andrew Taylor
Are you an Apple Televison and Video Expert? Answer questions, earn points and help others
