Question about Lexmark Z600 InkJet Printer
Hello, I just installed a new black cartridge into my Lexmark Z600 but the ink light is still on and the on light is flashing, Help?
    Problem Solver:
  • 3 Answers
Take the cartridge back out .and bang it around to loosen up the ink
Posted on Jan 21, 2009
My printer does not acknowledge presence of ink cartridges.will only print in black
It could be that the color cartridge is not seated properly or just needs cleaning.
Try to re-seat your color ink cartridge. Open the printer cover > remove the color cartridge > re-insert the color cartridge and make sure it's properly seated > close the printer cover. Try to print again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark Z600 Series folder.
  4. Select Lexmark Solution Center / All-In-One Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Feb 04, 2012 | Lexmark Z600 InkJet Printer
I install new inkjet cartridge for my Lexmark Z600 printer, but the printer still showing no ink
Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
If problem continues and you're using brand new genuine Lexmark cartridges, please contact Lexmark Technical Support Center for further assistance.
Jan 07, 2012 | Lexmark Z600 InkJet Printer
I am trying to print and nothing comes out on paper. cartridge black half full and color full and it will not print anything from an open document to a new document with some typing on it. lexmark z600...
Try to clean the print cartridge nozzles. On your computer, go to Start menu > All Programs / Programs > Lexmark Z600 Series > select Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a clean test page forcing ink through the cartridge nozzles and clean them. Try to print your document again and to check if print quality is achieved.
Jul 25, 2011 | Lexmark Z600 InkJet Printer
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
Lexmark printer always want a new cartridge
What you need is to reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
May 28, 2009 | Lexmark X2500 All-In-One Printer
Lexmark Z517 wont print black ink
I have a z600 that i use. If not used for about a month the ink does clog the print nozzles and eventually ink cartridge does dry out. To avoid this even if i dont have to print anything I run a diagnostics test that prints out a nozzle aligment test every two weeks.The great thing about this is that it uses very little ink.You can find this test in your software that was provided by Lexmark. This will keep your nozzles cleaned and you will notice this helps extend the life of your cartridge.
Sep 21, 2007 | Lexmark Inkjet Z517 Photo Printer
Lexmark z600 series printer problems
my lexmark printer does this, i removed the ink cartridges and then put them back in ,it pops up a box asking about the cartridge, i then told it it was a new one it was then happy , i find the printer very tempremental......but thats another story, good luck , hope this works for you!
Oct 09, 2006 | Lexmark Z600 InkJet Printer
Lexmark Z600 InkJet Printer Logo
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
