Question about Nokia N70 Cellular Phone
Nokia N70 no signal problem
I left my phone in the office for 2 hours. Then when I got it back I has no signal. for 2 days now the signal has not been restored yet.
  • Nokia Master
  • 14,641 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Jan 11, 2013
famid
  • 49 Answers
SOURCE: n70 restore font
DOWNLOAD FONT REMOVER SIS FILE FROM GOOGLE SEARCH INSATLL IT IN UR MOBILE IT HELPS U
i guarantee my solution is always right
plz dont forgetme to rate on fixya (blue line)
Posted on Nov 12, 2008
SOURCE: how to restore nokia n70
i have an N70 and i forgot my keypad password what can i do to unlock it? thnx andres
Posted on Nov 17, 2008
myjosh007
  • 530 Answers
SOURCE: my nokia n70 phone weak of signal
hi im josh in cebu phils.friend may i help you? your problem is weak signal. friend when the phone is weak signal there maybe a problem in hardware of the phone. the frequency reciever is weak im sure.but you can boost its functions throught entering the setting and go to network settings and select manual search.your phone frequency will search the network connections around so the hardware will be force to boost.once it will show the network providers around you select the network you are using and it will be setted to the network in more/ higher frquencyh signal. thats all friend hope i helped you.good luck/
Posted on Feb 28, 2009
jhenny
SOURCE: Nokia N70 Cellular Phone nokia n70
you have to call tmobile customer service they have the unlock code to help you out with your problem....
Posted on Mar 03, 2009
SOURCE: How to format my Nokia N70
just type *#7370# and follow the procedure
Posted on Mar 09, 2009
How to transfer music to N70 without using a card reader or bluetooth ? my card reader is missing ..
Good Day,
Transferring file to a PC from an N70 phone, can be done in three ways
1: via Bluetooth 2: via memory card (by the use of memory card reader) 3: via Nokia PC Suite using standard N70 (DKU-2) Cable chiefmecha_4.jpg
I guess you are left the last option, which is I am sure you have a cable for your phone. Because it is included in the box when you bought the phone.
But before you can actually connect your phone to your PC, even if you have the cable, you must install Nokia PC Suite first. Just go here and download the software. http://nds1.nokia.com/files/support/global/phones/software/Nokia_PC_Suite_eng_web.exe
After installing you can go and connect the cable to your N70 phone and connect to a USB port on your PC. The phone may ask you on its screen to choose what kind of connectivity you want, if you want to just transfer files, you may just choose Disk option or removable disk access, and access its MMC via the windows explorer just like a card reader.
Hope this helps you. Thank you for using Fixya.
Aug 09, 2011 | Nokia N70 Cellular Phone
Hi! My name is Steve ,and i want you know if its normaly to keep my battery working just 2 days,after then i must recharging
Hi Steve,
Well, it depends on the type of phone as to why your device is only lasting 2 days of battery power.
Your phone, the Nokia N70 is rated to last 3.5 hours of talk time, or 11 days of standby time, meaning if you are not using the phone that's how long the battery will last when the phone is on but the screen is off and you have minimal apps running on your phone.
Which means that you must be using your phone for more than just calling. For most people, they can barely get 2 days of battery real life on this phone, especially if you are a power user.
It is a color screen phone and that is one of the reasons why it uses up battery so much. The other reason is because it is connected to the internet as well.. that draws a lot of battery over just a regular flip phone. Nowadays, people using a smartphone can only get a day's worth of battery life out of their battery. Although, some smartphones can last 2-3 days or longer depending on battery size, how its software regulates drawing/using battery, and the technology inside the phone. The Nokia N70 has a 970 mAh battery compared to the new smartphones with as much as 3000 mAh batteries.
see the article attached for how to increase your battery life:
Life with Nokia N70
Oct 13, 2009 | Nokia N70 Cellular Phone
My nokia n70 frequently restarts and the battery lasts not more than 10 hours.
Hi!... Try to reformat or reflashing the phone. An updated software is available at their site and the instruction on how to format. And with your battery problem, if you are using voice calls frequently it 10 hours is normal or if not, if your battery is already 1 1/2 to 2 years try to replace with new.
Oct 01, 2009 | Nokia Cell Phones
My nokia n70 phone weak of signal
Feb 28, 2009 | Nokia N70 Cellular Phone
Hanging and virus back on n70
possibly the software which you migrated might have corrupted ..So take your mobile to a nearest nokia service centre for flashing your mobile and changing your OS again..
Aug 22, 2008 | Nokia N70 Cellular Phone
Nokia N70 white screen
jus use a hair dryer for a FEW min ONLY...prob solved
Jul 17, 2008 | Nokia N70 Cellular Phone
Nokia n70 white screen
nokia-n70-network-signal-problem
Jun 03, 2008 | Nokia N70 Cellular Phone
No signal
do a network settings check and see if thaht helps, if not try servicing the phone.
Feb 29, 2008 | Nokia N70 Cellular Phone
N70 lost signal
reset your phone it might work
Nov 30, 2007 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
56 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
