Question about Gateway DX4200-09 PC Desktop
I replace the screen on my gateaway mt 6916 and cant install the video controler driver
  • 314 Answers
Instructions
Prepare the laptop for disassembly. Shut down the laptop completely, then wait a few minutes before removing the battery and unplugging the AC adapter. Turn the laptop over and lay it down on a flat surface so that the battery area is facing away from you and the hard drive is located at the bottom left corner.
Remove the hard drive cover. Remove the two screws located on the left side of the hard drive cover, then lift the cover to remove it completely from the unit.
Remove the memory cover. Unscrew the eight screws holding the memory board in place; this cover is located above the Gateway product sticker.
Disconnect the Wi-Fi adaptor. Remove the Wi-Fi cover by unscrewing the single screw holding the Wi-Fi adapter in place; this is located directly above the hard drive. Remove the two cables connecting the wireless card to the adapter and snap the card out of the holder.
5
Remove the memory modules. Gateway computers typically have two memory modules located in the center of the motherboard; lift these out gently with your fingers and set them aside.
6
Release the heat sink. Unscrew the four screws around the heat sink assembly; this unit is located to the left of the ventilation fan and is surrounded by a copper base. Carefully lift the heat sink and the cooling fan off the unit and unplug the cable attaching it.
7
Remove the CD/DVD drive. Unscrew the small screw located to the left of the CD/DVD drive, then push the drive out to remove it from the laptop completely.
8
Remove all screws around the base of the laptop. You will now be left with a total of 18 screws located around the edge of the base of the laptop, and in between the stickers and hardware components in the center. Remove all of these carefully and set aside in a safe place.
9
Prepare the cover for removal. Turn the laptop up on its edge so that the back of the laptop is facing you; you will see two screws on the hinges of the computer. Unscrew these and set them aside.
10
Remove the hinge cover. Open the laptop so that the screen is laying flat; use the flathead screwdriver to pry open the hinge cover and pull it off gently with your fingers.
11
Remove the keyboard. Lift up the keyboard and reach behind it to release the cable. You will need to tug gently on the cable to unhook it from the motherboard.
12
Unhook the LCD screen from the notebook. Unplug the Wi-Fi antenna cables located on the right side of the motherboard directly under the screen, then unplug the video cable located directly under the hinge cover. Remove the pair of screws located to the left and right of the LCD screen and gently lift the LCD screen off the notebook's base unit.
13
Remove the system board. Turn the base unit over and unscrew the five screws securing the motherboard to the base. Two of these are located near the hinge cover, and two are located beneath and to the right of the hard drive unit. The fifth is located a few inches below the top right edge of the laptop.
14
Disconnect the motherboard. Lift the system board, then unhook the cable connecting it to the base unit.
Posted on Jan 10, 2013
MEDION MT 7 boots but no signal after a fall
please download the driver update from your computer supplier. then go to device manager, search for audio uninstall the driver corrupted and install the new driver update. see the proper when your see the dvice make click, and proceed according.fix it.
God bless you
May 31, 2013 | Medion Computers & Internet
Cant get a full screen
You may need to change the screen resolution.
Go to Control Panel - Display - Settings tab - in Screen resolution, move the slider to 1024 x 768 and Apply.
If you cannot increase the screen resolution then most likely the incorrect video driver has been installed. Install the correct video driver and you will be able to increase the screen resolution.
Apr 02, 2012 | Computers & Internet
I bought this cooker from a rummage and need a replacement part. who do i contact?
To contact us, please write to or call:
Attn: Repair Center P.O. Box 6916
708 South Missouri Street Columbia, MO 65205-6916
Macon, MO 63552 1(800) 947-3744
Email: consumer_relations@toastmaster.com
www.Toastmaster.com
hopefully thats right. good luck
Jun 21, 2011 | Toastmaster TRC-5 5-Cup Rice Cooker
My gateaway gt5040 computer does not have audio
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 22, 2011 | Gateway GT5040 PC Desktop
Hp compaq dc5100 mt pz581ua ethernet drivers
TRY THESE DRIVERS
MODEM_AND_HP_WIRELESS_ASST
http://rapidshare.com/files/286881164/MODEM_AND_HP_WIRELESS_ASST.rar
BROADCOM_WIRELESS_DRIVERS
http://rapidshare.com/files/286884551/BROADCOM_WIRELESS_DRIVERS.rar
INTEL_PRO_WIRELESS
http://rapidshare.com/files/286884550/INTEL_PRO_WIRELESS_sp31678.exe
Sep 30, 2009 | HP Compaq dc5100 Desktop PC - Intel...
Hp comapq d 220 mt ethernet driver problem
please follow this link of HP and you can have origional driver to download and install.
and please dont forget to rate my answer
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=337531&prodTypeId=12454&prodSeriesId=337529&swLang=13&taskId=135&swEnvOID=1093#11395
Sep 05, 2009 | Computers & Internet
I rebooted my whole computer and reinstalled vista. Now my computer screen appears to be a low resolution but the options say its the highest resolution possible. The screen saver cant be displayed because...
JUST INSTALL ONLY THE DRIVER OF VIDEO CARD. there are two driver that, 1.) for video card.. second for video card controller. install that all to solve your problem if you don't have driver just download form the support site..
Jun 03, 2009 | IBM LENOVO VIDEO CARD 760E 39H6226 Graphic...
Screen small picture
What operating system are you using (ie Windows 2000)
Try re-installing the Video Drivers Available Here
Mar 27, 2009 | Toshiba Portege 7200CT Notebook
Modem Drivers for chinese mobile phone MT 6227 and Mt6228
You can download your modem driver from here
http://www.filebuzz.com/findsoftware/Download_Mt6228_Modem_Driver/1.html
May 18, 2008 | Cell Phones
Gateaway
Please uninstall the sound driver and install the correct driver of your machine to fix all the reccent problems of your system.
You can download the drivers here: http://www.emachines.com/support/product_support.html?cat=Desktops
Please input the necessary data of your system.
It is very important to install all the driver regarding your system for its optimum performance.
Jan 16, 2008 | E-Machines eMachines Refurbished EMA...
Gateway DX4200-09 PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
