Question about Simplex Kaba Ilco Unican L1000 keyless lock
L1000 keyless lock at our office that we can't reset 4 digit cod
We have a L1000 keyless lock at our office that we can't re-set the 4 digit code on. Can any one tell us how to re-set it?
  • 10,865 Answers
You can call Simplex at 877-439-5377. They will be able to assist you. good luck
Posted on Jan 22, 2009
Have simplex lp1000 keyless lock sytem is zeroed out but will not reset or take new code, aleays stayes unlocked
"If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution
Solution: Follow the procedure for changing a combination except omit step 3 (do not enter
the existing combination)."
I excerpted the above from the full instructions on how to change the code. If you don't have them, got to this link:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
and go across from L1000 to the last column, "Tips".
When you hover your mouse over PDF, two choices will appear; left click on the upper one, "Changing the code/..." to download it.
The download will be a PDF file format. If you are unable to open it, you will need to download and install Adobe Reader on your computer. There is a link (Get Adobe Reader) at the top right of the literature grid.
When you do get the download open, you will have the stepwise procedure and illustrations necessary-but don't forget to omit Step 3, if you believe that you have the ZERO code problem!
Good luck--and please provide feedback if this helps!
Oct 31, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
NEED TO CHANGE LOCK CODE
You will find a link to download the manual for your model on this page:
Hover your mouse over "PDF" under the "TIPS" column and the two choices of "Changing the Code/Combination" or "How to Reset a Lost or Unknown Combination" will appear--move your mouse over the appropriate one and click to download the info.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader, if the file will not display for you.
Aug 03, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
I forgot my nokia 3230's lock code how to unlock it please tell me
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 01, 2011 | Health & Beauty
Forget phone code .want to reset phone code.
OR:
Jul 18, 2011 | Cell Phones
LOST CODE AND LATCH WON,T RETRACT WHEN LEVER IS TURNED.
Navigate to this page, which show a grid of Simplex products, then scroll down to the L1000 entry:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=1000
Then go to the rightmost column (TIPS) and hover your mouse over "PDFs", which will pop up a window with two choices: Changing the code, or How to reset a lost combination.
You will then be able to download a PDF file of your choosing for instructions.
If you don't already have Adobe Reader or another PDF reader program installed on your computer, there is a link at the top of the the grid chart to download Adobe Reader.
Apr 01, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Can a L1000 series simplex kaba be switched to mount a right handed door
No. The Kaba L1000 is factory-handed and is not field-reversible.
That information comes from the grid found on this page:
under L1000/Specification/SimplexL1000 Catalogue PDF
Apr 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Find missing combination serial no. 329366
Navigate to this page, which is the product grid:
Then to L1000, and under the "TIPS' column, hover your mouse over PDFs, which will pop up a balloon of two choices; select "How to reset a lost or unknown combination"
This will download a PDF of the instructions you need. There is a link at the top of the product grid page to download and install Adobe Reader if you don't already have it, so that you can open the PDF download.
Mar 31, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
How do you zero out the Unican L1000 (with levers)? The lock is not responding to the old or new combination.
Yow will find a link to download the manual for your model L1000 on this page:
This will download a PDF file; you will need adobe reader installed to open it. There is a link on this same page to download adobe reader.
Customer service can be contacted from this link:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Feb 14, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
The KABA L1000 Simplex lock that I have won't open from one side of the gate. The master key and correct code will turn the handle, but the latch doesn't engage. The latch will open from the other side...
I recommend that you contact Kaba Ilco directly with your problem.
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Feb 02, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Simplex Kaba Ilco Unican  L1000 keyless lock  Logo
882 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
