Question about HHB CDR830 Plus CD Player
Repair on HHB CDR-830 Disc Recorder
I am having a problem with my HHB CDR 830 in that it goes into the rapir mode and does not record sometimes. The repair light comes on and you have no audio when it tries to finalize the program that you recorded? This is annoying as I try and record a program. I have tried bith CDR and CDRMusic CD's. Tom Bychinski
  • HFSDATech Dec 26, 2007
    I have the same problem. Sometimes after what looks like a successful recording, the display will show "New Disk" or "Repair". I've tried using the recommneded slower speed CDR's including HHB's own.Help!
  • Anonymous Mar 22, 2009
    We have the same problem as described above, we only use it on Sunday to record our service. If any body has a solution please post it. Thanks
SOURCE:
  • 112 Answers
SOURCE: about the HHB CDR 850 compact disc Recorder
You may need a new laser - it's a sony unit inside.
Posted on Dec 09, 2007
aravan
  • 27 Answers
SOURCE: hhb cd recorder
at the time of burning to avoid this problem select multisession option in nero:
Posted on Sep 30, 2008
  • 32 Answers
SOURCE: i nead a new manual for a phillips cdr 775 dual recorder
http://www.usersmanualguide.com/philips/home_audio-video__cd_recorders/cdr775_00
Choose your specific model and language. Downloads in pdf format.
Good Luck,
BB
Posted on Jan 06, 2009
dunnbiker
  • 8546 Answers
SOURCE: can't finalize after recording, disc error
So are they always CD-RW?
I have a Pioneer PD509 which is a spittin' image of the HHB CDR830 but tied down to use CD-Audio discs only.
My experiece with Rewriteable Media has been that they don't hold up to multiple uses. I used them to make quick 'n' dirty dubs of cassette audio then worked it into a polished copy with proper track marks and sweetening later for copy over to a CD-RA. After a few passes I'd start getting audible problems when copying off the -RW's, so I routinely just use them about 5 times. With two DVD players and a Blu-Ray I sometimes get through the errors on one of them for one final digital copy and then I can them.
BTW: you may want to try the failing disc in a DVD player. Mine will play through an unfinalized CD but can't cue up to anything. So if the recording is vital you might retrieve it that way. Just remember to pause the Recorder at the end of the last cut you want because the DVD will just crash right into the old data without changing track numbers or any warning.
Posted on Mar 04, 2010
SOURCE: I NEED A USERS MANUAL FOR A KLH DUAL DECK AUDIO CD/RW RECORDER
one channel will not record
Posted on Jul 31, 2010
HHB CDR 850-No laser lit up...shouldn;t there be light ie. laser
YesI when the unit is first turned on the laser will emit a red light when scaning, if no beam is present it is time to replace your player, not cost effective to repair.
Mar 05, 2012 | HHB CDR850 CD Recorder
Hi, I have an HHB Burn-It CDR 830. Whenever I'm recording, along about the 5th track in- the player starts to fuzz out. The time stutters/freezes momentarily, and then continues normally for a while...
If it's always around the same physical location on a given CD it would have to be a physical problem with the transport, not the lens.
Esoteric but comprehensive advice....
http://www.repairfaq.org/sam/cdfaq.htm
Sep 20, 2011 | HHB BurnIt CDR830 CD Recorder
Hi , My cdr 830 stopped recording at maximum fidelity, and most recently all data disappears upon finalization, the prompt reading "new disc" after recording a whole 70 plus cd. Frustrating...
I can't speak to the hardware issues that might be at play here but I would advise you to retain the 'bad' recordings. I've copied unfinalized CD's from an old DVD player. It will read the CD but you won't be able to manuever around the tracks. As I recall, the track marks will still be there.
I don't know what you mean by 'maximum fidelity'. The CDR records at the CD standard of 44.1kHz. Digital is all ones and nones. Just data. If it is written correctly or with tolerable errors the ADC of the player (ANY player) turns it all into music.
Mar 02, 2011 | HHB BurnIt CDR830 CD Recorder
Hi there, when recording analogue from mixer to HHB Burner 830 the blank cd does not read properly, and records blank even thou the connections are in the right ins and out (phono to phono) And the input...
I can only assume that it's not changing the analogue signal into a format suitable for transferring to a CD. Check the recording settings. Make certain the signal is being converted to say a WAV format or MP3 etc.
May 01, 2017 | HHB BurnIt CDR830 CD Recorder
What does pma rec mean on the hhb cbr 830 ? it just stops recording
The recorder is writing TOC data to the disc's PMA (Program Memory Area). Never turn off the power while this display is
showing.
http://www.retrevo.com/support/HHB-CDR830-CD-Players-manual/id/3875ci874/t/2/
Aug 13, 2010 | HHB BurnIt CDR830 CD Recorder
User manual
You can get it at www.manualsonline.com,www.manualnguide.com or at their website.
thanks and good luck
Jun 04, 2010 | HHB 830 Plus CD Recorder CD Player
Anytime I try to record with my HHD BurnIT cdr 830, the red record light will only be bleeping and the time counter will not work as well. And there will be nothing recorded on the cd.
Just a guess, but did you ever try to hit the record a second time once you're all set up to start? The first press of the record button places the machine in record/pause mode after it calibrates itself to the disc.
Jan 19, 2010 | HHB BurnIt CDR830 CD Recorder
Cannot use the finalize function anymore
they wear out have it serviced and cleaned
Nov 05, 2009 | HHB BurnIt CDR830 CD Recorder
HHB-830 CD TRAY does NOT open.
It's made for HHB by Pioneer, you could try one of their agents?. Opening up is fairly straightforward if you are methodical and take your time if you need to. There is a test mode sequence you can try - hold down the 'menu/delete' and 'auto/manual' keys together for 5 seconds until the display blinks all the lights then press the stop button. Now ONLY press the open / close button - pressing any other keys will change settings and without the service manual you won't know what you're changing. Press stop then power it off to exit.
I can email you the service manual if you need it. It sounds like a gear has come loose inside to me. I strip these machines for parts quite regularly so may be able to help you out if you're able to work out what if anything is broken but I'm in the UK. It may be as simple as a belt has come loose :-)
Feb 28, 2008 | HHB 830 Plus CD Recorder CD Player
About the HHB CDR 850 compact disc Recorder
Aug 14, 2007 | HHB CDR850 CD Recorder
148 people viewed this question
Top HHB Audio Players & Recorders Experts
Ekse
Daniel
Daniel
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
