Question about Sony FD Trinitron WEGA KV-32HS510 32" TV
I have a Trinitron Wega 32HS510 that sometimes will not turn on. It sounds like it is going to turn on but shuts down immediately. The red light fast blinks either 6 or 7 times over and over again - usually 7 times. I have tried the recommended power reset (hold the up arrow button down while turning on TV), but that hasn't worked. Unplugging the power sometimes works...for a while. Later, the symptoms return. Any inexpensive ideas? I love the 170 pound TV but not enough to spend as much to fix it as to buy a new 20 pound flat screen. Thanks
    Top Expert:
  • Sony Master
  • 75,581 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Apr 30, 2017
SOURCE: Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
My Sony KV36HS500 Trinitron is doing the same thing. Last night the next street over was hit by lightning. The "7" blink pattern was happening, so like the manual stated, unplug it for 4 hours. Which I did. The t.v. is back up and running fine. It's a nice t.v., better than the plasma I paid over a grand for, that's already shot. It's a good t.v. and good that Sony put in the stand by protection to prevent the t.v. from dying an unnecessary young death. Patience, don't rush it, unplug the t.v. and leave it sit. Also, don't use a power strip, that was my mistake, and unplug your t.v. if storms are in the area, I was too lazy to and now I had to deal with this, in 8 years, only twice did this happen. I'd buy another one tomorrow if they still made them.
Posted on Jun 15, 2008
  • 61 Answers
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Posted on Oct 15, 2008
SOURCE: Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Posted on Dec 01, 2008
SOURCE: Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I think I have the solution for you. I have the same tv and it does the same thing when you turn on the power button on the remote when the tv turns on you hear a click then the red light flashes about 5 to 6 times then the tv comes on. on the remote there should be two buttons on top of the remote one says power and the other one says system hit the power button to turn on the tv when you hear the click and see the red light flashing then hit the system button which will turn off the tv then hit the power button again and it will turn the tv on without the red light flashing it should work
Posted on Jan 10, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
What is the life span for the Sony Wega KV-32HS510?
10,000 continous woking hours is calculated to most of the CRT based TVs.
It is only calculation, but the life span might be much more that that. I've repaired a Sony TV recently, which was released by Sony Corporation Japan. The model is KV1820, an 18" Trinitron TV, still works perfectly. Just see, it is an '80 model one.
Jul 31, 2014 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony trinitron KV-32HS510 has vertical hold problem
It could just be a resistor or two ,
check for Vert Oscillator Circuit & AGC
Jul 27, 2012 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv wont turn on and the light keeps flashing red
Your video path is defective,check IC301....hope this helps...
Mar 10, 2010 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Problem with 1999 Sony Trinitron Wega 32 inch TV
sounds like the tube has gone any good tv repair shop will be able to replace it cheapley.
Mar 08, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv shuts itself off randomly
hi
you have defective power oscillation in power section
this needs to diagnose for a qualified technician
Thanks!
Feb 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Jun 29, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony FD Trinitron WEGA KV-32HS510 32" TV Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
