Question about Sony God of War 2
God of war cheats codes to unlook eaver thing
SOURCE: game
hey i dont know how to pass through a stage in god of war 2 pls help me that stage is after getting a big hammer
Posted on May 29, 2008
rizla
  • 1463 Answers
SOURCE: Cheat Sheets
hi melanie
which platform you wanting cheats for psp xbox ps2 etc .
but if you try here these might have some god of war
select your platform and search for the codes
riz.
Posted on Jun 03, 2008
  • 16 Answers
SOURCE: Cheat Codes
search on google for cheats
Posted on Jun 29, 2008
mdavinci
  • 20 Answers
SOURCE: my problem is you don`t give cheats in god of war
Theres no standard cheats codes by the looks of it, just walkthroughs and codes for the Action replacy cheat add on device - you may find out more here:
http://vgstrategies.about.com/od/toppicks/tp/godofwarps2.htm
Posted on Mar 19, 2009
Jmizpah777
  • 290 Answers
SOURCE: God of War 1 and 2(Unable to read disc)!
Check your cd if it can play in different ps2 consoles. if it can, then theres nothing wrong with the cd.
probably your game console has problems on disk reading.
FIX Those Ps2 disk errors.
You're going to be surprised when you find out how easy this is. Read the instructions all the way through before you attempt the repair just so you'll be familiar with the entire process. First take off the outer cover of you PS2. If you haven't done this before, you will have to remove all the screw covers from the bottom of the unit, both plastic and rubber, these will be the only screws you will have to remove in order to take off the outer cover.
To remove the outer cover, lift up from the rear of the unit and pull towards the front in order to clear the controller jacks and the eject/close buttons. As you remove the outer cover you will notice a small metallic ribbon cable inside the machine leading to the eject/close and reset buttons on the front of the unit, this cable is usually taped to the top of the disc tray. This cable is not a sensitive as it appears; just remove the tape holding the ribbon cable. Once the outer cover is off you need to remove the cover to the disc tray, this will require a rather small phillips screwdriver (I've seen a few that use a standard slotted screw). Now that the tray cover is off, the first thing to do is to clean the laser eye. All you will need is a Q-Tip dipped in alcohol. Just swab the eye a few times and allow it to dry on its own, making sure that no lint was left behind from the Q-Tip.
After the cover is off of the disk tray and the laser has been cleaned you will need to plug the unit back in, (The unit needs to be hooked up to a TV as well to test it while you have it open. You should have a DVD, a game disk with a silver or gold back and one with a purple back in order to fine tune the system to play all three.) It will be necessary to have the unit powered up to perform the repair. Press the eject button so that the tray slides forward exposing the undercarriage. At the back of the unit you should see a small white, geared wheel about the size of a quarter. This little bastard is the cause of all your problems.
This wheel changes the angle in which the disk is held. You will notice that there is a small metal tab that holds the wheel in place. Take a felt-tip marker and mark the point on the wheel that meets the tab. That way you will always know the original position that the wheel was in. Now that the orig. position has been marked, feel free to spin the wheel for a few full rotations in order to see how it changes the angle. It will only alter the angle a few degrees before it goes back to zero, after it reaches the maximum angle it will go back to flat after each full rotation. Once you've toyed with it to see how it works, put the wheel back to the original position that you have marked. Then advance the wheel about 1/8 of a turn and place the disk tray cover back on top of the disk tray. (You will not need to screw the tray cover back down in order to test the machine; you will only need to hold down the cover with your fingers while trying to load/test a disk) Now place a DVD in the tray and press the eject/close button in order to close the tray and load the DVD (hold down the cover as explained above). Wait to see if the DVD loads, you may have to use the browser in order to load each disk you test. If the DVD loads, eject it and load a silver backed disk, if that loads try a purple backed disk. If all three loaded successfully, congratulations you're finished. If not, remove the tray cover, eject the disk and advance the wheel another 1/8 turn and repeat the process. It just a matter of finding an angle that will facilitate the operation of all three types of disks. Once you've found the proper angle and the system is operating to its full potential, close it up and let'er rip. I also do not recommend placing the PS2 on its side once you have fixed it. Although Sony says they recommend it in the owner manual, I have since seen internal Sony documents retracting the statement and attributing many malfunctions to storing and operating the unit on its side. Keep it flat at all times.
well. i hope this works.
pm me if problems continue.
Posted on Aug 08, 2009
Cheat codes god of war 3
God of War 3 doesn't have cheat codes.
Apr 29, 2014 | Video Game Consoles & Games
Cheats for god of war 2 for ps2
there is NOT a cheat to unlock everything. Not that i know of anyway. most things are unlocked as you beat the game. There are few places where you can exploit it to max out kratos.... http://www.ign.com/cheats/games/god-of-war-ps2-661321
Mar 28, 2014 | Video Game Consoles & Games
Cheat of god of war 2 ps2 code paper
THERE ARE NO CHEAT CODES FOR GOD OF WAR 2!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jul 02, 2011 | Sony God of War for PlayStation 2
How to cheat the level on godswar 2011
An excellent resource for discovering Walkthroughs, FAQs (Frequestly Asked Questions) and cheat codes for God Of War III is here :
http://www.gamefaqs.com/search/index.html?game=God+ofg+War+III&platform=0&s=s
First:
Select you gaming platform (Xbox, PS3 Wii PC etc)
The FAQ section will contains complete Walthroughs:
For exmaple Here: http://www.gamefaqs.com/ps3/943928-god-of-war-iii/faqs/59367
Good Luck !
May 07, 2011 | God of War III
Cheats on the game of god of war
Visit this link to get the cheat codes for the game God Of War.
Good luck and have a nice day
Apr 12, 2011 | Sony PlayStation 2 (PS2) Console
My problem is you don`t give cheats in god of war
Mar 19, 2009 | Sony God of War 2
Cheats
Cheats such as god mode or infinite ammo? No.
But here is a guide to unlockables and easter eggs:
http://www.gamefaqs.com/console/xbox360/code/938611.html
Jan 02, 2009 | Microsoft Gears of War 2 for Xbox 360
Cheat Sheets
hi melanie
riz.
Jun 03, 2008 | Sony Video Game Consoles & Games
Sony God of War 2 Logo
35 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
