Question about Samsung RS261MDWP - 26 cu. ft. Side by Side Refrigerator
Fridge Model# RS261MDWP Ser # JJ674BBC300678X 1) Filter Indicator/Icon: is OFF (no light) (normal)?? yes or no a) till I open Fridge OR Freezer door or run water (3 separate actions) independent of each other. Then the light comes on when doing any of these three functions. 2.) Water Icon: This Icon is always OFF. It does NOT come on when I run water. My manual states it should come on when I run water.Should it be OFF normally and then come on when I run water.
2 Suggested Answers
kerry_hales5
  • 9 Answers
SOURCE: Why is ice forming under the bottom drawer of my Samsung American fridge freezer Rsa1shpn and then water eventually leaking out the door? I have defrosted the fridge freezer but still have the proble
There is a drain tube located under the panel of most freezers. If that clogs up, the auto defrost can't work. The freezer defrosts by evaporating all the moisture out of the compartment. So, check that first. Secondly, a leaky door seal can also cause that problem. You can order door seals online or on Amazon.
Posted on Oct 17, 2014
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
Freezer has moisture dropping from bottom of door. Just started Saturday 8/9/14. What could be the problem? Also, where do you fine the model number?
You might have a torn seal around the door. CHeck that carefully and clean it with a damp sponge.
The model number is on a tag somewhere inside the fridge, usually easily readable so check by the filter or the light.
You might also have frozen coils, and might need to defrost it (turn it off for a day with the doors open) so get some freezer boxes and some dry ice to store your food and keep a towel on the floor in front of the freezer to absorb the melted ice.
Aug 10, 2014 | Kenmore Freezers
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
Iterior light flashes on/off in fridge when door is opened,every so often it starts a series of buzzies with the exterior indicator light flashing on and off ,most importantly in the freezer part things...
Get out your manual for the book. If indicator lights and buzzers are going off, there may be an error or failure that is being picked up by a diagnostic.
Sometimes, the amount of flashes and buzzes will help to narrow down where the problem may lie.
Jun 13, 2010 | Freezers
Fridge not working but freezer is ok fridge light works
There is probably an ice build up between the two sides of the appliance. There may also be a problem with the damper unit which controls the cold air coming from the freezer side to the fridge. The fridge is controlled by the freezer. Dependant on appliance. The door opens and closes letting the cold air go into the fridge and when the fridge is cold enough the door will close agin. This is not something that you will see happening it is normally concealed behing a diffuser.
Feb 24, 2010 | Freezers
The green light on the front indicator panel is not working, although the ppliance is operating normally. Is the lamp replaceable, and how do I get to it? Does the front indicator panel open, and how?...
to be honest the price would not be worth the cost. but yes you can replace bulb. all you have to do is click it off. but do get in touch with manifactors Manual for blub size and info.
Oct 29, 2009 | Zanussi 14.62 cu. ft. / 414 liter Chest...
Filter changed but still 1% on display panel
Is this a side by side fridge freezer? Most Whirlpool models with LCD display on front- reset filter indicator to display 99% by pressing and holding 'OK' button until filter resets to 99%. If you have a different model, or of this doesn't work, advise on model number and I can instruct further
Aug 10, 2009 | Whirlpool Freezers
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Samsung RS261MDWP - 26 cu. ft. Side by Side Refrigerator Logo
53 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
