Question about Crosley 0187SST Turntable
What's your problem?Crosley Radio CR2405C-PA Director CD Recorder won't record on side two of the phonograph. Why?
Why can I record on one side of the phonograph, but when I do side two I recieve an error code that looks like 2 upside down "h"s?
  • doubltrouble
    doubltrouble Apr 09, 2013
    Mine is doing the same thing!!! Did you ever get an answer??
  • 42 Answers
SOURCE: what replacement cartridge should be used on Crosley 245 Director
I would suggest you contact the MUSONIC web-site.
They specialise in cartridges and styli and will no doubt be able to suggest a solution.
Posted on Jan 25, 2009
  • 133 Answers
SOURCE: Crosley Radio CR246 CD door will not open
Try checking these:
- the CD door motor rubber drive belt (if there is one), it could be either loosened or broken, if so, it needs to be replaced
- the door open/closed sensor switches (contacts), they could be oxydized or damaged, they are located somewhere under the CD tray, possibly at the front end of the unit (depends on brand and model), you need to clean these with some fine sandpaper
It could be something else like the door motor driver IC, the power supply for the motor, a bad capacitor in the motor drive section, a loose connection or a broken wire somewhere, but hopefully, it's just a bad rubber belt or a dirty contact.
regards
3rq8 (Triarcuate)
Posted on Aug 08, 2009
  • 17 Answers
SOURCE: I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Posted on Jul 24, 2010
  • 6771 Answers
SOURCE: HELP! Christmas gift not working!! Crosley CD
I would suggest you contact the person who gave the Christmas gift, because this is a item that cannot be fixed easily, from the description you have a function selector problem which is controlled by an IC.
Posted on Dec 20, 2010
SOURCE: Why does my crosley turntable/cassette player/cd
I would suspect that you have a bad record laser in the CD recorder assembly, this is common, and this is usually what it is. To this end you would need to replace this unit's laser assembly, it will/may still play a CD OK, but will not write to the CD, as they are two separate lasers. So if you wish to try to repair you will need to contact Crosley and ask them what to do, ask for a referral to an authorised service center or perhaps even return it to them? In any event ONLY ask for a "Quote" first and see how much it may cost before proceeding.
Posted on Oct 17, 2011
I have no sound
Very difficult to speculate what it could be with the info provided. You may need to open it up to gain access to the circuitry inside, to do some component level inspection and testing.
Feb 29, 2016 | Crosley Music Writer Cd Recorder - Paprika...
Phono input only plays one speaker and receiver shuts down after playing record for a few minutes
are you using a phonograph with a built-in preamp? If so, then you need to hook it up to a different input. Phono input is only for non-amplifier phonographs, otherwise you will over-drive the amp.
Oct 10, 2015 | Sherwood RX-4109 Stereo Receiver Black
How do i fix the cd holder when it is stuck
The gears usually dry up or get stuck with hair. You need to open the panel and re-grease it.
Jul 22, 2015 | Crosley Radio CR2406A-PA Director CD...
Where can I get a schematic of the power board E315942?
Find somebody from Manila, Philippines and ask them to get you one at Raon. If they don't have it in stock they will make it for you.
Jul 02, 2015 | Crosley Radio CR2406A-PA Director CD...
Have a error,not LE, but looks like an upside down 7 with a line thru the middle, then E???
often referred to as an 'le' code. looks kinda like an upside down 'F', correct. replace motor position sensor--the hall sensor.
Mar 22, 2015 | LG Washing Machines
I just purchaseday crosley model #2405c and when you put a cd in and push play button it does not work
Hi
You can find a manual here
http://imgserve.crosleyradio.com/manuals/CR2405C%20manual%20%20%20English_French_Spanish%202011.12.19.pdf
which may or may not help with your problem.
However you state that you have "just purchased" the machine. If this is so and particularly if the machine is new then you should take it back to the vendor for him to replace with a working unit, because clearly the one you have is "not of Merchantable Quality".
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 26, 2014 | Crosley Audio Players & Recorders
How can I get my crosley cr2405a out of standby mode?
http://www.manualslib.com/manual/503736/Crosley-Cr2405a.html this is the URL for the manual.
May 07, 2014 | Crosley Director CD Recorder with Cassette...
Owner Manual
http://crosleydirectdpd.com/product-documents/CR246_Manual.pdf
Dec 09, 2013 | Crosley CR2405C-PA Director 3 Speed...
I have a crossley lp player cd recorder and dont know how torecord from lp to cd
Is The Lp Player Stand Alone Or Does Have To Connect To A PC Via USB Cable.Your Pc Should Store The Recording In A MP3 File.The Resulting MP3 File Can Then Be Downloaded To The Cd.
Apr 10, 2013 | Crosley CR-2402C-PA - CD Recorder...
Crosley 0187SST Turntable Logo
111 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
