Question about VeriFone VX510
File group password for Verifone vx510
To wipe the memory and to program for card processing, I need two passwords for this machine. One password is correct - 1, alpha, alpha, 6, 6, 8, 3, 1. But the second password that should be the same as above (it is called "file group password") was changed for some reasons. And this password is unknown. I tried everything that I found in Internet, including 0000 or 1234 or 9999 or 1111, etc. Is it possible to resolve this problem or I have to thru away this CCM?
  • 42 Answers
You need password reset software to reset Group1 password in Vx510.
psoftware109@gmail.com
Posted on Jan 16, 2013
  • Ronald Erickson Mar 14, 2014
    CardSystemTechnologies.com can reset a vx510 610 or570 password for $32, reset verifone passwordfree return shipping
Reset memory on Verifone VX510 payment terminal
if you want to remove all the memory you can do that easily, if you want to allow for more memory room you can press F2 and F4 at the same time, enter the password 1alpha alpha 66831 enter and then select the purple key under the arrow pointing down. select memory functions, and it will ask if you want to clear the memory, do this in group 1
Aug 19, 2013 | VeriFone Omni VX-510 Credit Card Machine...
How do i reboot
To Reboot the Verifone VX510 or VX570 terminal you will press the "F2" and "F4" buttons at the same time. When it prompts you for the password, you will enter it (this depends on which credit card provider you use) and it will bring you to a "sys mode menu 1" screen. The "F4" option should give you a "RESTART" option, which is the same as rebooting the machine.
Aug 31, 2012 | VeriFone VX510
I'm trying to reset the Group 1 password on my Verifone Omni 3750
The password on most vx510's can be reset by pulling battery and clearing RAM. Reassemble, clear Tamper and password will reset to original password (1aa66831). But if the certificate has been changed, only your download provider can help you. Call Frank @ 775-338-6634
Jun 08, 2011 | VeriFone Omni 3700
I have two verifone vx510 cc machines. 1st) Need
bad RTC can be repaired. the machine is equipped with multiple sensors inside. if one of them goes bad, or the Battery is dead tampering or bad RTC will show this can be fix by replacing the sensor and or the battery if you need this to be done call me @ (775) 358-2922 hope this help : - )
May 31, 2011 | VeriFone VX510
Hello, i have a verifone vx610 POS ant it shows the mesagge : bad rtc chip, please reboot, please say to me how i can solve this problem. Also I want to know how i can change the system and group...
bad RTC can be repaired. the machine is equipped with multiple sensors inside. if one of them goes bad, tamperring or bad RTC board will come password should be 1AlphaAlpha66831Enterif not them try 23378463 : - ) hope this help if not then call me 775 358 2922
Sep 24, 2010 | VeriFone VX510
Verifone vx610
#1 You need the Vmac and Comserv applications that were deleted when you cleared memory in order to perform an IP download. Without them you can only perform a dial only download.
#2 The programming for your VX510 will not load in your VX610 because they doth identify to the server as different models. If you did get the vx610 to connect and request your vx510 file you would only recieve an error "Application not configured" or "file not found"
Pro Tip: You can still clone VX terminals reguardless of model with the correct cable. Enter system mode and press 0 the # or 0 then * to send and recieve. This would put the application from the vx510 into the vx610 but your vx610 may not work through a com method other than dial depending on your processor.
Feb 10, 2010 | Computers & Internet
I have verifone vx510
GO ON LINE
VERIFONE OMNI 3700 SERVICE MANUAL
OR
VERFONE VX510 SERVICE MANUAL DRIVERS
ENTER
OR
VERFONE 3700 VX510 FLASHING LIGHTS
ENTER
ROD
Feb 10, 2009 | VeriFone Omni 3700
Verifone VX510
Yes he is somewhat correct. At the main sale screen hit the option 6 usually the password is 1 Alpha Alpha 66831 if it gets you to the Terminal Phone COMMs screen it is good. Choose phone then next and choose PBX code that is what needs to be dialed out from your phone system to get an outside line IE: 9,,8,... once that is edited choose enter then exit if that doesnt work at teh main screen hit the more key or the tip key until you see other setup then the password again. 1 ALPHA ALPHA 66831 hit the tip or more key again until you see COMMS. Select it then hit next until you see baud rate hit edit and that field and then next until you see 300 hit enter then exit save changes hit ok then the red X key to get back to the sale screen try that.
Other fixes as well but it needs phone conversation.
Call me at www.greenlightpayments.com ext 105
Jan 04, 2009 | VeriFone Omni 3700
Verifone omni 3750
here's some passwords you can Try: 1, 0000, 1234, 1701, 1739, 000000, 12345, 998877, 123456, 752036, 23378463, 45803155, 53664337, 1[Alpha][Alpha]66831, 6[Alpha]78727[Alpha][Alpha], Hope this help if not call us @ 775- 358-2922 : - )
Jul 09, 2008 | VeriFone Omni 3700
VeriFone VX510 Logo
448 people viewed this question
Top VeriFone Retail Supplies Experts
Da Doc
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
