Question about LG 47LG50 47 in. LCD HDTV
Fridge Model# RS261MDWP Ser # JJ674BBC300678X 1) Filter Indicator/Icon: is OFF (no light) (normal)?? yes or no a) till I open Fridge OR Freezer door or run water (3 separate actions) independent of e
Fridge Model# RS261MDWP Ser # JJ674BBC300678X 1) Filter Indicator/Icon: is OFF (no light) (normal)?? yes or no a) till I open Fridge OR Freezer door or run water (3 separate actions) independent of each other. Then the light comes on when doing any of these three functions. 2.) Water Icon: This Icon is always OFF. It does NOT come on when I run water. My manual states it should come on when I run water.Should it be OFF normally and then come on when I run water.
antiochpc
  • 1314 Answers
SOURCE: My new refrigerator's ice maker and water dispenser doesnt work
Since this is a brand new unit, I wouldn't waste the time or money troubleshooting it yourself; contact the place you purchased it from and exchange it.
Posted on Jul 15, 2008
peyton32034
  • 410 Answers
SOURCE: Connecting the fridge to the water point
you need to connect your fridge to a constant water supply such as a water main make sure it is a cold water line that you connect to. good luck peyton
Posted on Feb 02, 2009
MNTECH
  • 1543 Answers
SOURCE: Inside top of refrigerator hot light don't turn off.
There is a service bulletin related to this, dealing with deformation / melting of the lamp cover. The fix is to change the lamp wire harness to one that now has a thermal protector incorporated in it (part number 6621JK2003B) along with changing the main PCB board to one that uses a larger relay for this function (part number 6871JB1423N).
In case you want or need to replace the following,
The lamp cover is part number 3110JA1096A and the lamp holder is part number 3034JA1009A
I tried to cut and paste a few photo's, but was unsuccessful. Sorry. Make sure to test that fans and light switches work after part changes.
Posted on Apr 11, 2009
  • 28 Answers
SOURCE: Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
Posted on May 09, 2009
SOURCE: how do I reset the lg water filter indicator light
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Posted on Oct 15, 2009
The fault warning sign is beeping when i open the fridge door
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Feb 19, 2017 | Refrigerators
E240B Fridge Freezer door open alarm goes even when door closed.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Dec 22, 2016 | Fisher Refrigerators
Model E402b. Why is the alarm going off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jun 02, 2015 | Fisher and Paykel Refrigerators
Open door 18 beeps lights flash red green fridge not cooling
Mar 14, 2015 | Refrigerators
Hisense americanfridge freezer RS731N4AC1. Can the doors be removed to fit through standard door frames.
yes the doors are always removable. Also you can open the door and swing the fridge till it will reach second door .Open second door and complete the chore
Dec 28, 2014 | Hisense RS731N4AC1 Stainless Steel 562 l...
The freezer door wasn't closed properly overnight 2 nights ago and it still didn't cool properly after the whole day yesterday and today. There was a noise which I didn't recognize but now in retrospect...
Is RS261MDWP the correct model number? If you left the freezer door open there is an excess amount of frost covering the evaporators because moisture was drawn inside and has frozen on the evaporator and is too much for a normal defrost to get all of the ice off and drain into the pan below the refrigerator. It may have also frozen over the condensate drain and not allowing the water to drain. You may need to clean the drain hole and defrost the refrigerator manually and insure the evaporators are clear of backed up water. If you don't there is a chance the refrigerator will continue like this until you do. Let me know what the status is so I can help.....Sea Breeze
Does your model have two evaporators?
Aug 05, 2013 | Samsung / RS261MDWP
Only one temperature control??
Good day,
Yes, they are made. The temperature in the fresh compartment will be no issue, since you have control in that compartment.
The engineers designed the balance between the two compartments so the freezer would be normal if the following conditions applied.
1. The room temperature is between 70 and 90 degrees.
2. The machine has normal usage. I.E. 8 to 20 door openings of the fresh food door.
The freezer would start getting warmer if the room temperature dropped much below 70 degrees. or..
If the machine had extremely light usage with very few
door openings, or a combination of both situations described above.
With dual controls, and both set at normal, the above conditions would occur anyway, except you could over ride the normal settings to compensate.
Many people have this setup, and experience little trouble, but without knowing your life style replacing it would be your choice based on the facts given.
Thanks for using FixYa
Dec 23, 2009 | Refrigerators
Freezer frost buildup; fan constantly running; water filter
Just had mine repaired. Tech told me that the tempearature settings on the display panel are not EXACT science. The fridge is cooled by blowing air from the freezer to the fridge and when the sensor in fridge reached approx desired temperature, the damper is closed.
The noise you hear periodically (water dripping) is the heating rod melting the defroster (hence frost freeze), which unfortunately sometimes spills into the blower motor to fridge, causing frozen motor, causing the infamous ER FF error code and fridge failure.
I reluctantly had LG to do the energy saver fix (recall) and it replace everything that the internet users are complaining about.
Jun 27, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
LG 47LG50 47 in. LCD HDTV Logo
42 people viewed this question
Computer Repairing
Computer Repairing
