Question about Pioneer VSX-305 Receiver
Hello - Our Pioneer vsx-305 display screen doesn't light up anymore and we are unable to get it to work even though the on/off button appears to operating correctly (red standby light comes on). T
    Novelist:
    Scholar:
  • 165 Answers
It is likely failing due to age.Cold solders fail, corrosion can cut a connection, a capacitor can harden and fail... a myriad of things can happen in time. Repairing it will cost more than an inexpensive replacement. The same receiver can be had on ebay from $60 up (with shipping). It is a cost benefit issue at this point.
Posted on Jan 07, 2014
  • 30 Answers
SOURCE: Pioneer VSX-D412 AMP-ERR message.
The AMP-ERR message in many Pioneer Receivers is caused by some DC in the output. The microprocessor then issues the warning and shuts the unit off. It is definitely not a relay switch. It could be the amplifier power pack, i.e. PAC011A or similar that is faulty or something else. Not easy to repair for the non- experienced DIY.
Good luck
Posted on Apr 24, 2009
dunnbiker
  • 8546 Answers
SOURCE: won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
Posted on May 16, 2009
dragster301
  • 12 Answers
SOURCE: Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Posted on Jul 31, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a VSX-918V Pioneer
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 07, 2011
sieberbob
SOURCE: I have an older Pioneer vsx-403 receiver that
I have the same problem. I have taken off the top cover and you will see a tiny glass fuse which looks good, but I change it and then it powers up but only for a while. weird. I can hold the power button down while I unplug the power cord from the rear and plug it back in some times it takes a few times before it comes back on. Looking for a permanent fix
Posted on Sep 09, 2012
My Pioneer Receiver VSX-519V has a blinking HDMI light and won't show video.
You guys mentioned the reset via the front panel, and I tried that with this very same issue on my VSX-822-k and it worked!
thought I would post the instructions for anyone else that lands here:
Reset the main unit if the receiver is generally not operating correctly. Switch the receiver into standby mode. Hold down the "BAND" button while pressing the "STANDYBY/ON" button for about two seconds. When "Reset?" appears in the display window, press the "AUTO SURROUND/ STREAM DIRECT" button. "OK?" appears in the display window. Press "STEREO/A.L.C." to confirm. "OK" appears in the window. The system has been reset.
Oct 28, 2012 | Pioneer Vsx 519v-k 5.1 Home Theater 550...
How can I connect an HD LCD tv to an ancient (I think 1980s) Pioneer Receiver Model VSX-305? The receiver is in great condition, and I'd rather not replace it. I have Bose speakers connected to i
I have never seen RCA to digital conversion, and if it did exist you would have to convert from digital to analog in order for this to work, the sound quality would be degraded and unreliable, plus sound level would drop.
Mar 20, 2012 | Pioneer VSX-305 Receiver
How to reset pioneer vsx-819h
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx819hk.html
It's in the manual. Page 12.
Resetting the Main Unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the BAND button, press and hold the STANDBY/ON button for about two seconds.
3 When you see RESET? appear in the display, press AUTO SURROUND/STREAM DIRECT.
OK? shows in the display.
4 Press STEREO/A.L.C to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory settings.
Sep 08, 2011 | Pioneer VSX-819H-K A/V Receiver
Need a pioneer vsx 305 remote
Search eBay for "Pioneer vsx-305 remote" and check the 'Include description' box. Many available.
Aug 31, 2011 | Pioneer VSX-305 Receiver
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
hope it worked!!!
Jul 30, 2009 | Pioneer Audio Players & Recorders
Won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
May 16, 2009 | Pioneer VSX-305 Receiver
Pioneer Home Theater System VSX-305 owners manual
Dear Sir/Lady
I wat to get the
Pioneer Home Theater System VSX-305 owners manual Thanks a lot
WILLIAMS
Apr 08, 2008 | Pioneer VSX-305 Receiver
Vsx 305 surround sound
The stand-by light is supposed to go off when you power on the receiver. You should get the display light and you should have power on.
Dec 18, 2007 | Pioneer VSX-305 Receiver
Universal home theater remote for Pioneer VSX-305 audio/video stereo receiver
Don't spend a lot of money for a universal remote. Radio Shack has some good buys. I think you are the same person who is having problems with a 305. Get rid of it. You can make a quantum leap at Amazon for less than $200 for a Pioneer.
Nov 16, 2007 | Pioneer VSX-305 Receiver
198 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
