Question about Exercise & Fitness
Treadmill stopes dead during workout showing error 1
It will run all day without preasure on running deck.
    Top Expert:
  • 12,223 Answers
Step 1:
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.see the diagram attached, and test it for open or faulty. Clean it, and tight the connector very well
treadmill stopes dead during workout showing error - 1_11_2013_8_06_40_pm.gif
Step 2:
However LUBE the deck belt and rollers bearings too.see the video atttached.
Iif the problem persist too, TIME to replace the old deck belt board.
God bless you
Posted on Jan 11, 2013
SOURCE: with every step I get squeak / chirp while running on treadmill.
Check the knob used to hold it up in the folded position. While running, have someone pull it to the out position. That was the problem on mine. If it is, a little grease on the end of the rod should do it.
Posted on Nov 05, 2009
SOURCE: lifefitness 9100hr treadmill cut out
iv had similar problems, only happened once tho - i switched it on after a few mins it would go off.
iv read to dismantle the stop switch, clean and replace the microswitch. where can the microswitch be found from?
also, is the red stop switch that needs looking at? how can i remove it?
i was wondering on how i can service/maintain this properly, can anyone advise my on how to give this a service.
Posted on Dec 01, 2009
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
SOURCE: york t101 treadmill ls error
York treadmill T101 will not run has a error L5
Posted on Feb 20, 2010
SOURCE: horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Posted on Aug 22, 2010
Low speed fault
With belt movement check speed sensor. Without belt movement check MCB. If you neglected unit it could be belt and deck if its shutting down during a workout. I have also see a lot of on/ off switches getting old and causing LS errors due to low voltage to MCB
Apr 19, 2014 | RTO Sole F80 Treadmill
Error 27
Precor Error 27, Too Much Drive Motor Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 27
Feb 18, 2014 | Precor 933 Premium Series Treadmill
Treadmill keeps stoping
Corrective Action
Jan 27, 2014 | Life Fitness Treadmill Precor C954 (Used)
Treadmill stops dead with error 1 showing
Step 1:
Adjust the sensor speed see the diagram attaached, test for open or faulty. Clean it, and tight very well the connector
Step 2:
However you must LUBE the deck belt+rollers bearing see the video attached.
If the porblem persist, TIME to replace the old board deck belt
God bless you
Jan 10, 2013 | Exercise & Fitness
Hi i have horizon treadmill t401 i don't when i start it 3 miles for hours for my workout it stoped and restart very fast i don't no what to do can u tell me how to solved the problems please
1)this a problem by lack of maintenance schedule. LUBE the deck belt, probably you have a worn deck belt.
2) Lube the rollers bearings too , inmediately.
3) measure the input voltage motor in the terminal, if there are the motor need repair.
4) measure the output voltage board, if there are NOT the board is faulty.
se the block diagram. attached. see my personal TIPS
God bless you
Oct 07, 2012 | Horizon T401 Treadmill Walking Belt
I am having problems with my treadmill when some one gets on it then it slow downs and dosen
The first place to look would be the condition of the walking belt and deck. If they are worn, dry or several years old the friction between the walking belt and deck might be causing the drive motor to slow down during your workout. If the walking belt and deck have never been replaced we would recommend starting with that repair since these are parts which will need to be replaced anyway during the life of the treadmill. if you continue to experience problems following this repair, there may be a problem with a weak drive motor or in some cases a motor control board which is failing to send the appropriate amount of current to the drive motor during a workout.
Sep 12, 2012 | Life Fitness T5-0 Treadmill
Treadmill stops dead during workout
Dear Sir:
The most likely cause of the problem is a worn treadmill belt and deck.
Most of the time its caused from not lubricating between the treadmill belt and deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics.
Feb 14, 2012 | Exercise & Fitness
Stops dead during workout
Dear Sir:
Most of the problem with this situation is lack of lubrication and regular maintenance.
The treadmill is very complex electronic equipment. The friction between deck vs walk belt is Enough for to protect the equipment, the electronic design shut down the treadmill, for to avoid damage to the electronic components.
2nd failure is main motor board. But you must lubricate your equipment, see your instruction manual or user guide. If you do not have you can download free from Nordic: www.Nordic.com, go to service customer, then parts%Manuals, give your model, etc, and download for free.
sincerely. God bless you
ernesto cuadra
managua, nicaragua.
Feb 14, 2012 | Nordic Track NordicTrack Treadmill, A2550
I bought a Reebok V8.90 with iFit cards. My problem is that the workout will stop multiple times during the workout. Then I have to start over. It seems that each time I start over I can get a little...
Dear Sir:
I hope your are very well in union with your family.
I will help you inmediatel.
Please do the following:
If you can walk on your treadmill but it shuts down during a workout, it is normally caused by a friction problem with the belt and deck.
Here are the most common symptoms and solutions:
1)
Symptom: The treadmill operates for a given period of time and the circuit breaker on the treadmill trips causing you to have to reset the breaker, or let it cool off then reset the breaker.
The amount of time required to shut down will progressively get shorter.
Solution: The walking belt is worn. The incline test is the best test for it if you don't have a way to take a
DC amp draw. Put the treadmill at full incline and walk normally. If it takes it longer to shut off or does not
shut off at all, you need to replace the walking belt. Be sure to inspect the deck for wear too. If you want to
go for a cheap fix try lubricating the walking belt. The best fix is to replace the
walking belt and then regularly maintain it and keep the treadmill clean.
2)
Symptom: The treadmill will show power but after a given period of time, the treadmill will simply shut
down. Once you let it cool off, you can restart it back up but it shuts down faster and the time required
before it shuts down gets progressively shorter.
Solution: Your treadmill is most likely equipped with a heat sensor which shuts down the motor and/or
electronics to prevent them from burning up. If this is the case, replace the walking belt. Be sure to inspect
the deck for wear too. If you want to go for a cheap fix try lubricating the walking
belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
3)
Symptom: The treadmill shuts down in an intermittent pattern...there is no rhyme or reason to when it will
shut down. I get an error code or nothing shows up on the panel. I have to either unplug the treadmill or
reset it to restart the treadmill.
Solution: If you get an error code, contact us with the code and make and model and we will try to help
you figure out what is going on. Typically we either find a loose wire, an intermittent short, a bad power
board, or a bad control panel in service calls that we do locally. Unplug your treadmill and then check all
your wiring to make sure nothing is pinched, crimped or loose. Remove and replace each connector in
case corrosion is causing.
Thank you in advance, sincerely. God bless you.
If you need further assistance,please contact us.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 27, 2011 | Exercise & Fitness
Treadmill shuts off in middle of workout
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend replacing the motor controller,walkbelt,deck and applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
Aug 09, 2010 | Precor 9.31 Treadmill
Exercise & Fitness Logo
57 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
