Question about Saws
I have a Sears mdl 113.244512 bandsaw. The blade will not stay on the wheels. It works its way to the outside of wheel and comes off. Do you have any suggestions on how to remedy this problem?
  • 3 Answers
SOURCE: Sears 12 in bandsaw vibrates when cutting
Are you sure the wheel bearrings are in good shape, and are all the screwws in the drive pulleys tight,including the pulley set screws.
Posted on Dec 28, 2008
  • 58 Answers
SOURCE: upper wheel on a model 28-682 bandsaw. How do you adjust it.
With saw unpluged!!!!! open top wheel gaurd.Spin wheel by hand while moving the adjuster knob on back of the machine. As you turn both at the same time the blade will trac either the front or back of the wheel. Move the knob (while spinning the wheel) until the blade is tracking in the middle of the tire. (rubber strip around the wheel)
Posted on Jun 13, 2009
  • 582 Answers
SOURCE: bandsaw blade keeps coming off the wheels. What
ALL BAND SAWS HAVE AN ADJUSTMENT FOR THE BLADE TRAVEL WHEN I WOULD REPLACE MINE I WOULD ROTATE THE TOP WHEEL BY HAND TO CHECK THE ALIGNMENTAND WATCH WEHICH WAY THE BLADE STARTS TO TRAVEL THERE SHOULD BE AN ADJUSTMENT ON THE TOP WHEEL THAT TILTS THE WHEEL IN OR OUT JUST A TINY TURN WILL MAKE A BIG CHANGE
Posted on Aug 22, 2009
  • 4090 Answers
SOURCE: 14'' Sears craftsman bandsaw blade slips off, not much power
It sounds to me like the blade has stretched which the do in changing temperatures.
Try replacing the blade before you give up altogether. i was having the same problem with a Ryobi Blade would come off whenever i tried to cut a pice of 3 ply. I eventually replaced the blade and all ny troubles evaporated.
Posted on Aug 29, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need to find replacements for the rubber on the
the part number you need is 817911 and they list for 12.99 each and you can find them at searspartsdirect.com and they just roll on making sure the notches line up. If I have helped you with your request would you please rate this response accordingly. thank you
Posted on Dec 03, 2009
The blade won't stay on even though I have it on properly it comes right off when I turn it on
I have no experience of portable bandsaws but do have some experience of workshop bandsaws.
One wheel is generally movable in order to "steer" the blade and careful adjustment is needed with the blade guides retracted until the blade runs full on the wheels. The blade guides are then brought back to prevent the pressure against the work from pushing the blade off the wheels.
Oct 04, 2015 | Milwaukee tools 6242-6 Compact PortaBand...
Bandsaw blades keep popping off,could it be heat related?
Blades slip off the wheels on these saws is because one or both wheels are not turning true to the blade. This can be caused by:
- Missing or worn tires on the wheels. The rubber tires have to be on the wheels and they have to be in good condition.
- Occasionally the screws holding the sprocket on the driven wheel come loose and the wheel will wobble causing the blade to come off.
- Both wheels ride on bearings and shafts that, if seized, worn or broken, will let the wheel wobble enough that the blade won't stay on.
- If the blade is stretched or twisted from use it won't stay on very well.
Aug 06, 2012 | Dewalt DWM120 Heavy Duty Variable Speed...
Tire comes off top wheel almost all the time. Tire comes off bottem wheel sometimes. Don't know how to set up this saw.
My jet bandsaw did same thing only fix was new tires .Tires are supposed to be tite on wheel .get wood dowels between tire and wheel and roll new tire onto wheel. If desperate could glue on with weather strip adhesive.put bandsaw blade on both tires spin wheels with power off till blade is running in center of wheel by adjusting top wheel in or out. When done adjust blade guides to blade and bearings to back of blade .This is top and bottom of cutting area
Jan 16, 2011 | Delta Woodworking Delta Rockwell 14 Inch...
Need a manual for a sears/craftsman model #103.24300 bandsaw
Any particular reason? If general settings problem, please follow this advice:
Brand of bandsaw is of no importance, problem is... I assume that problem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
I love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is housed driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
Switch machine off and remove power plug from the socket.
Start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel, is rotating freely without wandering, and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock bearing guide in.
3. insert paper on internal side of the blade and slide internal slide guide block till you can only pull the paper out, lock the slider.
4. repeat previous (3) operation on external guide block and after you slide paper out, lock it in position as well.
5. manually rotate the tension wheel, should operate freely, without wandering, without touching bearing or side slides.
6. repeat step 2 to 5 on the bottom guide
7. close the covers
8. adjust hight of the top guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. connect power, switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
This general rule applies to all bandsaw, regardless of brand, make, vintage. Do remember that this is not a toy, it will cut through, wood, metal and your fingers...
Do remember, that these operations must be performed every time when you change the blade, do not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, allow blade to slide and cut, use protection screen and googles, you have only two eyes and there are no spares...
If you have problem with your bandsaw, not related to adjustments, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 15, 2010 | Craftsman Saws
I cannot get the blade to track correctly on my JET 12" band saw. What could be wrong? I have done exactly what the manual says to do. I am not sure the square box on the outside is fitting. The little arm...
i love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. basic "anatomy" of bandsaw is that it have body, in it there is driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for bette adjustment and protect teeth on the band.
start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock it in.
4. repeat previous operation on external guide block and after you slide paper out, lock it in position.
7. close the covers
8. adjust hight of the guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
this general rule applies to all bandsaw, regardless of brand, make, vintage. do remember that this is not a toy, it will cut through, wood, metal and your fingers...
do remember, that these operations must be performed every time when you change the blade, to not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, use protection screen and googles, you have only two eyes and there are no spares...
Jul 30, 2010 | Jet JWBS-16B 708749B 16-inch Bandsaw
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
New blade will not stay on top belt
There should be adjustments for tracking the upper wheel. Turn the machine by hand until the tracking is perfect. Check the bearings in both wheels for looseness. Hope this helps!
Jan 21, 2010 | Saws
Craftsman 12" Bandsaw Blade Tracking Problems
Sounds like you have a saw with defective castings. Either cast out-of-true or deflect under pressure.
Jan 03, 2010 | Saws
Clark 6x4 bandsaw
there should be an adjustment knob on the back that changes the angle of the top wheel and this will center the blade so it stays on. I do this by jogging the saw on and off while I adjust it. hope this helps you
Sep 23, 2009 | Grizzly Saws
Bandsaw blade keeps coming off the wheels. What
Aug 22, 2009 | Craftsman Saws
Saws Logo
97 people viewed this question
Top Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
