Question about Exercise & Fitness
Looking for pedal hinge bolts for an e strider BE5920 - any ideas where I can get them?
  • 3 Answers
I'd go to ace hardware they should have any bolt you need
Posted on Jan 10, 2013
  • Karen Jan 10, 2013
    Thank you i will certainly give them a try - will call body sculpture first as its a new machine but unfortunately my husband told me to ring them and get bolts that were not included - he quoted me number 4 bolts but he was wrong its the pedal hinge bolts that are missing - not sure if they will replace these free of charge as they have sent me the ones i wrongly told them but will give it a shot - thank you again
I need a new bolt (with handle) for the steering shaft. It is a bolt that holds the two parts of the shaft together, and when loosend it allows you to fold the shaft down.
Go t Ace hardware take your old bolt they'll probably have a bolt the same size, otherwise you'll need to contact the manufacturer of the item, Electric Strider, Call 1-800-555-1212 and ask for the 800 number of the company of manufacture... There should be a plate on strider with name of company of production.. May even have phone number on plate and possibly web site..
May 29, 2014 | Electric Strider Midi 4 Wheel Mobility...
I have a Proform Smart Strider. We just assembled it & when I tested it there's a very loud scraping sound when I stride, regardless of the level or program...help, pls. Thx.
I recomend you to disassemble again, and repeat the steps. Something must be there ARE not according with the instruction assembling. Try however for to see the some loose parts, bolts, nuts, and lube.
See this small instruction.s
God bless you
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.
Lubrication:
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Oct 15, 2013 | Proform Smart Strider SpaceSaver...
How do I replace the driver side hood hinge? 1994 Jeep Grand Cherokee
The hinges are held together with two top, and two bottom, 10 millimeter bolts. (At the pivot point) However, one half of the hinge is welded to the pillar, the other half to the door. That being said...The bolts can be removed to take the door off. BUT, in order to go any further: the hinges will have to be cut and welded. So I guess the answer your looking for is. Take the door off, unplug the wires, cut and weld the half necessary to repair the deficiency
Feb 23, 2011 | 1994 Jeep Grand Cherokee
I am looking for a manual for strider 4 mobility scooter
There is a great website for all your service needs for this scooter from Medline Industries:
http://www.striderscooterservice.com/
There is a specific service manual for the strider:
http://www.striderscooterservice.com/strider-scooter/files/TechManual.pdf
These two sources should provide all the info you need. Hope this helps.
Nov 23, 2010 | Health & Beauty
I have a Nordic Track Audio Strider 900 and I have had it for a year. There is now a very loud intermittent sound coming from the back of the machine. It happens rather randomly- but when it comes, the...
Hi We have a Nordic Track AudioStrider 900 and it is squeeking when in use - it's getting so bad that we feel we can't use it. Do you have any advice?
Oct 03, 2010 | Nordic Track Exercise & Fitness
How do get to the inside nut to replace driver door top hinge?
The better solution is to go to auto zone and buy door hinge pin and bushing kit.Part # 38438.
You have to remove the door from the hinge cut the existing pin and replace and rest the door. The bolt you are looking for is inaccessable
Nov 09, 2009 | Lincoln Town Car Cars & Trucks
Passenger door dropped on my Daewoo how do i fix
Hi David,
It's either loose hinge(s) or a loose lock.
The lock is easier. Make sure the mechanism within the door is secure. The screws tight. That there is no movement of the latch assembly.
Next the hinges:
With the door fully open, position yourself so you can observe the hinges while lifting the door. It will be easier with a helper.
You are looking for movement at the mounting points of either hinge. Check mounting bolts and tighten where necessary.
Comment me back with the results.
Best regards,
Mike
Aug 22, 2009 | 1999 Daewoo Lanos
Exercise & Fitness Logo
252 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
