Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
How to Install the "Door Center" part to the Ice maker of a side by side Model # FRS3R5EMBC
  • Official Brand Answer
  • 4,342 Answers
Hi Herb Keller - Typically this type of information is not release to someone who is not a technician and it is very rare to locate step by step instructions on how to install/replace part(s). In most cases this information can be found on the internet; however it is not provided directly from the manufacturer due to liability
Posted on Jan 14, 2013
  • 1073 Answers
SOURCE: Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Posted on Apr 17, 2008
SOURCE: Ice Maker offers Cubes or Crushed
sell it
Posted on Aug 12, 2008
SOURCE: Not making ice
the icemaker is not making ice,In the bottom of refridegerator you can see some coils and they are iced over bad.
Posted on Jun 04, 2009
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
My Frigidaire model FRS24ZGE leaks water from the bottom of the freezer door after using the water/ice dispenser. Any ideas on a fix?
Posted on Jul 18, 2009
tooltech75
  • 80 Answers
SOURCE: Frigidaire side by side FRS24ZSG. Door Dispenser doesn't work
click on the wiring diagram and look at the circuit which powers the dispenser...it looks like the safety switch would be a problem to all the functions you listed above..such as the light not working.. no ice... no water
i would look for power to that safety switch..and if its getting power.. then i would check continuity through that switch.
also another possibility maybe its the wiring harness that leads to the dispenser.
Posted on Oct 05, 2009
How to reinsert ice maker into 1992 Model TS25AF
You unscrew the srews holding the ice maker into the refrigerator. There may be 2 or 3. Then you should unplug any electrical connection, and saw on another site you need to remove the arm and install it onto the new ice maker. Then replace the new ice maker into refrigerator. There should be a different piece that's actually connected to the water input and then sends the water into the Icemaker.
Aug 31, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a KitchenAid side by side Refrigerator Model KSRG22FKWH15 with style 2 ice maker. Have water but ice not being made. Have checked all normal reasons for not making ice. How do I remove ice maker...
try this:
1. Remove the bucket from the door to get some room.
2. Put a piece of tape on the sensor flapper to hold it down so you won't damage it while removing the ice maker.
3. Remove the ice maker service cover door by spreading the two hinge fingers apart away from the center and the door should lift out of the slot.
4. Remove the screw in the right rear bottom side of the ice maker.
5. After removing the screw that cover should lift up from the rear and just work it out from the rear and you see the electrical harness.
6. On the left track the should be a tab toward the bottom which you need to push up.
7. Push up tab and start working the ice maker towards you pulling it out of the track.
8. Careful with the electrical harness in the back as you're pulling out.
9. Disconnect the electrical plug by lifting the clip on the plug.
10. Remove the side cover on the side module by pulling off.
11. Remove the bottom shield by removing the 3 screws on the bottom.
12. To install reverse the order as it came out.
Apr 02, 2010 | KitchenAid (KSRD22FKST) Side by Side...
The ice maker doesnt work, and in the day several times appears water in the floor, in the side of the door of the ice maker
Uplug refrigerator and remove the ice maker so we can look at the tube that comes into the back of the ice maker. It maybe the ice maker is calling for water but ice or a crack in the tube that delivers the water is being deverted to inside the freezer area. Also look behind the fresh food compartment door and see if you can send me the model number so I will be able to go over the correct model. Let me know, Thanks, Sea Breeze
May 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Red light on ice maker blinking twice, no ice.
I would assume you are referring to the ice level sensor that is on the center divider. It is normal for it to blink if the door is open. You can test out this theory by holding the flap on the left side closed but not blocking the sensor. The light should go steady. If the ice maker is not working then you either need to change the lazer sensor or the ice maker itself.
Feb 01, 2009 | KitchenAid KSRG25FK Side by Side...
Ice maker stopped working
I just had the same problem. You need to purchase a new motor module part numnber #8021515. I purchased mine at a Sears Service Center for 77.59. I installed it yesterday and again now have ice. Took about 10 mintutes to install. The tricky little part is removing the old one. Unscrew the three screws, and there is a white tab that needs to be pressed together (use tweezers) to remove the unit from the shut off arm.
Jul 31, 2008 | KitchenAid KSCS25FKSS Side by Side...
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
46 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
