Question about Dryers
Dryer does not run
When you turn the dryer on, you can hear a humming sound. the drum does not turn. I checked the belt and it is on. 220 at wall outlet.
    Problem Solver:
  • 18 Answers
Your motor is going out. Try rotating the drum by hand a quarter turn or so and starting it again. If that doesn't work, TURN POWER OFF, take dryer apart and clean the motor. If still not working, it's time for a new motor, they range between $80 - $140 and reletively easy to replace.
Posted on Jan 21, 2009
The drum is not turning?
First is motor humming when door is closed and start button is pushed, if you hear motor running but drum does not move , check belt, broke. If motor does nothing check breakers one could be blown , next check door switch , if it was running on last load but quit check thermal switch it opens if lint builds up in vent or vent is plugged, make sure motor turns easily. Dryer are pretty easy to repair just watch how you take it apart , these run on 220 volts so unplug machine
Aug 12, 2017 | Dryers
Dryer only hums when turned on. The drum does not rotate, but the belt is intact.
Hi there. Sounds like it is a dead motor. Check it by measuring the terminals on the motor when you hear the humming sound. If it reads 110VAC on the meter the motor is dead or seized. Might also be the drum that is jammed. Check the drum holes for a screw or something that locks it?
Oct 16, 2011 | Dryers
Drum doesnt turn when turned on, can hear power goes to motor. Hve checked the belt and it is attached and can be maually turned
SOUNDS LIKE YOU HAVE A PULLY ON THE MOTOR SLIPPING IF YOU CAN HEAR THE MOTOR RUNNING, BUT THE DRUM DOES NOT TURN. IF NOT THE PULLY, THEN THE BELT MAY BE SLIPPING IN THE PULLY, BUT THE PULLY IS TURNING. THEN A NEW BELT IS NEEDED. IN EITHER CASE YOU WILL NEED TO ACCESS THE MOTOR AREA TO SEE WHATS HAPPENING. MOTOR COULD BE NOT RUNNING, EVEN THOUGH YOU HEAR A HUM IN IT. BUT, MOTORS NORMALLY RUN LONGER THEN THE LIFE OF THE DRYER.
Feb 20, 2011 | Dryers
I push the start button and the dryer makes a humming sound and the drum doesn't turn nor does the dryer turn on
Humming indicates motor is getting weak. If you look in the back compartment of your dryer you can probably see the belt. You can relieve the belt tension and then take the belt off the motor pulley. Once you do this, make sure the belt is out of the way and push the start button. If the motor turns it means it couldn't push the weight and is too weak to run. It make not turn without the belt on it either but you will hear if the sound is coming from the motor. In either case you need a new dryer or new motor if the dryer is pretty new.
May 02, 2010 | Dryers
Today our dryer quit drying. It hums but is not tumbling.
Dryers are belt driven. Something has locked the drum or motor, and that is why you hear the humming sound. With the dryer turned off, reach inside the drum and try to turn it. It should turn pretty freely. There will always be some drag. If you need a lot of effort to turn the drum, then it is time to investigate what is causing the drag. Probably, something has gotten wedged between the drum and the front wall of the dryer.
If you cannot find anything there, then it could be helpful to remove the outer shell from the dryer and investigate further to find the source of the drag. This requires some mechanical skill, so think carefully if you want to try it or call a service company or simply replace the dryer. A used dryer can cost $100 or less.
Feb 16, 2010 | Maytag Dryers
When i turn the on switch i hear a humming as if it is going to start but it does not. my dryer brand is Frigidaire FEQ 332 E s
Depending on the hum you hear (if you hear the sound and it keeps humming) the belt that connects the motor and the drum is probably broken.
If the hum only happens when you turn the on switch, the motor has probably failed.
Aug 31, 2009 | Frigidaire GLEQ642A Electric Dryer
When we push the on button, you can hear a hum,
Sounds like the belt that turns the drum has broken. the hum sound is the motor turning. Does it still get hot in the drum? If so then you need a replacement belt ($15-$25).You can open the rear or the dryer to confirm the belt is broken. Be sure to unplug from the wall outlet to avoid electrical shock.
Aug 18, 2009 | Dryers
Humming sound
If you open the door can you turn the inner drum by hand , if you can is any there any resistance or does it just spin freely
It sounds as if your drive belt has snapped and what you hear is the motor running on its own
If the drum spins freely you will need to take the back off the machine and see what state the drive belt is in
Ps
Is there heat inside the drum when you try to make it work without a load.
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
54 people viewed this question
Top Dryers Experts
