Question about Moffat Ovens
Broiler will not come on when baking
When I start the oven to bake something the broiler will not come on
Take a look at the element ( the "tube" inside the oven that glows red hot when the oven is turned on). If the element is burned out it will not be hot and glowing. You may have a loose connection to the element but most likely it is burned out and needs replacing.
Our stove is 27 years old and I have had to replace top or bottom elements every 6 years or so. I just bought a replacement element at Canadian Tire in Calgary for about $34. Just undo the 2 screws around the element and attach the new element to the old wires.
Good Luck -I hope this works for you
Posted on Jan 10, 2013
hotuna
  • 288 Answers
SOURCE: Oven not working in Bake setting
Visually inspect the element for any kind of rupture on the shield covering the element. If it looks good the next step is the wire connections at the back of the element. Most likely is has a burnt wire.You will have to pull the back cover off to check this.
Posted on Nov 04, 2007
docjohn174
  • 943 Answers
SOURCE: the oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Posted on Sep 30, 2008
SOURCE: fridgidaire FGF 374 CCSA oven and broiler do not come on
F1 means it is a defective eeprom. The software is incorrect. Replace EOC. Check inside the bottom drawer on the right side: there was an envelope with the troubleshooting and maintenance diagrams in it.
Posted on Jul 23, 2009
SOURCE: GE True Temp Oven not heating. Broiler works
we bought a new oven
Posted on Dec 15, 2009
Daniel S
  • 4323 Answers
SOURCE: My Frigidaire 30" oven ES300 the broiler element
Hi
Error F10 appears due to a faulty oven temperature sensor or faulty wiring on the oven temperature sensor. F10 indicates that the control detects a runaway temperature in the oven. If this error is appearing when the oven is at high temperatures then it is due to a faulty relay on the electronic control board. If this fault code appears when the oven is at room temperature, then the failure points to a failed oven temperature sensor probe circuit or a bad electronic oven control board.
To check this you’ll need to use a multimeter, the resistance of temperature sensor should be around 1100-1200 ohms. If it is above 2000 ohms then the sensor has turned bad. However, if the reading is between the specified range then check the wiring harness connection directly at the electronic oven control board (with the range still unplugged). If the wiring is perfect then you would need to replace the electronic control board.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 13, 2010
Bake and broiler element come on when bake is selected. Why?
Understand that I am not a professional, so this answer is subject to revision by someone who is more knowledgeable.
Where I live now I'm on Natural Gas, but in the past I've had electric stove/ovens. Based on my best recall the situation you describe is NOT abnormal.
When in the Broil mode, the Bake element is NOT on, but the Broil element is on FULL-bore to provide that strong radiant heat required for the Broiling process, AND for the good browning /crusting of the product being Broiled!!!!!
On the other hand, when Baking, not broiling, IF the Broiling element were on high it would provide too much radiant heat to the top of the product being Baked, and would burn the top.
While Baking, by energizing the Broil element in a lower power setting, the Baking process is enhanced with more heat by the assistance of the Broiler element, BUT without the hazard of burning on the top!!!!!
Hope this is right and helps your understanding.
Jan 16, 2015 | Ovens
First start up
You're actually referring to the "broiler" elements. Most electric ovens have these at the top of the main oven space. (Some gas ovens are set up the same way, but many put the broiler elements in a bottom drawer.)
As their name implies, broiler elements are active only when you're broiling. They will not go on for baking.
Broiling is the process of cooking food by exposing it directly to a high heat source at close range. To broil a steak, for example, you would place the pan holding the steak on an oven rack raised to the top or next to top position in the oven (consult the manual) and set the oven to broil. The top elements will then turn on and cook the meat by direct radiation.
Most people, however, use ovens for baking far more often than for broiling. Baking is the process of cooking food (cakes, casseroles, roasts etc) by indirect heat. In other words you raise the oven to a certain temperature, put the food on a rack more in the middle of the oven, and let the surrounding heat cook it over time. When you bake the top broiler elements usually don't come on at all.
I hope this helps.
Apr 30, 2014 | KitchenAid Ovens
Will the oven work without the broiler attached
You could use the oven without the broiler. It is customary that the oven will use the broil element to even out the heat in the oven for better baking but you could use if. it just may not bake evenly. There could be two things that is causing the broil element to stay energized. the control is not shutting down or there is a short to ground in the broil element. Have the broil element tested, it could just need replacing. If it is in the control that is a bigger problem.
Mar 19, 2014 | Ovens
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 | Ovens
Bake element does not heat up but broiler does. Do
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 06, 2010 | Thermador SMW272 Electric Double Oven
When I turn my oven on bake the broiler element runs and eventuly the f2 codes comes on.
your oven uses fboth the broiler element and the oven element during baking. Since you know the broiler element works, you most likely will have to replace the oven element.
Oct 01, 2009 | Ovens
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
Oct 24, 2008 | Frigidaire FEB24S2AB Single Oven
The oven broiler work but the baking part doesent.
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
130 people viewed this question
Top Moffat Ovens Experts
Lawrence Oravetz
john h
Are you a Moffat Oven Expert? Answer questions, earn points and help others
