Question about SkyGolf SkyCaddie SGX GPS Receiver
Skycaddie sgx screwdriver
The case is coming open and I need a screwdriver that will work with sgx skycaddie
4 Suggested Answers
SOURCE: My new Skycaddie sgx had a install problem and now
just wodering if you got the problem sorted. i have similar issue
Posted on Jul 17, 2010
drifterK
  • 4924 Answers
SOURCE: sgx skycaddie will not shut
perform a soft reset(a forced restart basically ) . hold power and joystick for 8 seconds. it will turn off. now turn on. if boots up correctly, then ok. if not, then perform hard reset.(remember that this will delete any information already installed..) push the information button (i) and flag button at same time. while both buttons are pressed turn on power. you should be in recovery mode. if so, re-sync.
Posted on Sep 03, 2010
  • 1417 Answers
SOURCE: i have just bought a
Hello.
If you have the update installed, your Sky Caddie Legend willdisplay the information on startup. You can also change the owner information.You may want to change the information if you purchased the GPS used, ornoticed an error in the information.TOLLS NEEDED AND INSTRUCTIONS ARE STATEDBELOW.Software update 2.42 or higher1 Press the "Thumb Stick" to display the Sky Caddiemain menu.2 Scroll down with the thumb stick and select"Options." Tap the thumb stick to enter the menu.3 Select "Owner Information," and tap thethumb stick to enter the folder.4 Enter or change the current owner data (Name,telephone, etc.). Scroll down with the thumb stick and select "OK."Thanks.
Posted on Sep 30, 2011
Why is it locked up?
How do I Reset My SkyCaddie If It Locks Up? - SkyGolf 360
clubsg.skygolf.com/.../6-6178-How_do_I_Reset_My_SkyCaddie_If_It_...
If your SkyCaddie is locked up you can reset it by following the instructions for your ...If you have a SkyCaddie Breeze or SGX you can reset these devices by .
Aug 11, 2015 | SkyCaddie GPS
I have a SGX and have lost the antenna cover. Can I find a replacement?
Stay AWAY from the SGX. The quality control is really poor. I know of three other users having the same problem, the antenna cover falls off and the unit does not get satelite reception. It becomes a piece of junk. Once that unit got replaced, in less than 5 months, the rubber covering the knob that allows you to select items had a tear and now the unit is no longer waterproof. This is not covered under warranty and they want you to pay $89.95 for a replacement. I am done with SkyCaddie. I have just purchased the new Garmin G6, awesome device, no annual fees, long battery life and touch screen enabled.
Look at the following link to get other user experiences.
Amazon com Customer Reviews SkyCaddie SGX Golf GPS
Feb 09, 2015 | SkyGolf SkyCaddie SGX GPS Receiver
On starting skycaddy sgx, I get the following message on screen: application servicesd.exe encountered a serious error and must shut down
Find the maual or go to ther website. see if they have a software fix for it if not you are most likely going to have to reinstall the software. Errors like these are startup errors and there is no work around that i know of.
Nov 04, 2013 | SkyGolf SkyCaddie SGX GPS Receiver
Skycaddie will not sync
Hi!
Do you use Windows or Mac as operating system?
Anyway, basically the procedure is almost the same for the both:
# you cannot sync the device because the firewall doesn't let you to do so. So you have to add this SkyCaddie as an EXCEPTION.
1. check the firewall icon in your toolbar
2. double-click on it to open the main window
3. in SETTINGS (or similar name) check ADD EXCEPTION
4. open ADD EXCEPTION and click on a "+" sign or on "ADD..."
5. go in the list of software and pick up your device
You're done!
GOOD LUCK!
_______________________
don't forget to RATE if you've liked it...!
Mar 05, 2011 | SkyGolf SkyCaddie SGX GPS Receiver
Registration
Where do I find Caddiesync>
May 28, 2010 | SkyGolf SkyCaddie SGX GPS Receiver
Upgraded to the SGX and now the Caddy Sync won't work.
Had the same problem when i first tried to sync on 2 different OS (XP and 7) as soon as I put skygolf.com into my antivirus software as a trusted site, it worked like a charm. Hope this helps someone as this is a great gps.
May 08, 2010 | SkyGolf SkyCaddie SGX GPS Receiver
SkyGolf SkyCaddie SGX GPS Receiver Logo
164 people viewed this question
Top SkyGolf GPS Experts
Oloyede Monsuru
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
