Question about Refrigerators
Stainless steel splash back lots of scratches some one cleaned it with something rough how may we fix it
    Genius:
  • Refrigerators Master
  • 1,669 Answers
The easiest, cheapest solution is to use a ball of stainless steel wool and rub it briskly against the panel making more scratches so that the panel appears to have that look but done purposely.
Posted on Jan 10, 2013
fridgetech
  • 473 Answers
SOURCE: stainless steel refrigerator with a bad scratch
Check out this site and see if it helps. Usually stainless has to be buffed out. http://www.stretcher.com/stories/01/010723a.cfm
Posted on Nov 06, 2007
aborcass
  • 2651 Answers
SOURCE: scratch on stainless steel Kenmore fridge
brillo a little harsh, finer steel wool would be better ive even used the scour side of the sponge, using wd40 as a "cutting oil" lightly go over scratched area. look close and follow the grain of the S/S. just likje wood S/S has a grain direction
Posted on Feb 22, 2008
ginko
  • 19396 Answers
SOURCE: Stainless Steel Refrigerator Care
You need to repaint the fridge with apposite product.
Posted on Mar 28, 2008
DeBruce
  • 145 Answers
SOURCE: Dent in stainless steel refrigerator door
Find and auto body that performes the paintless dent repair
Posted on Aug 24, 2009
  • 1456 Answers
SOURCE: I have a BLACK
Hello
You will be needing a scratch be gone kit.
Assess the damage. Determine if this is a deep scratch or a surface scratch, by running your finger across it. If you can actually feel the indentation, you have a deep scratch, gouge or ding. With clamps, carefully hold a small piece of dry ice over the gouged area. Hopefully,it will pop out, and not be as noticeable. Then you can treat it in the same way other scratched areas are treated in the steps below.
Use an abrasive pad from the Scratch-B-Gone kit to repair scuffs, light scratches and even deep scratches. The kit has 4 different abrasive pads and instructions to tell you which one to use depending on the severity of the scratches and scuffs. Otherwise, go to an automotive shop and buy different fine grades of sandpaper.
Apply a small amount of Ultra Shine from the Scratch-B-Gone kit onto the appropriate abrasive pad. Or use an automotive rubbing compound on the sandpaper.
Begin rubbing the damaged area of the satin in the direction of the grain covering over about a 5-inch area at a time. Slide the pad backward and forward increasing pressure as needed until you see the scratch is disappearing.
Repeat this process until the scratch is removed and the surface is restored. For a deeper scratch, dry rub the area with the coarse pad, and wipe area off with a microfiber cloth to make sure the scratch is gone.
Blend the metal surfaces by using the finest grade sandpaper or abrasive pad with the rubbing compound or Ultra Shine and gradually increase the area around the original damage to about three times the original scratched area. Be sure to go with the existing grain of the material so you don't create crosshatching.
Posted on Sep 30, 2010
Scratches because of steel wool
Is there directional grain..? I have removed small imperfection in stainless look by gengtly rubbing only in the same direction as the existing grain.. and be careful sometimes the repair is worse than the issue..
Oct 12, 2013 | KitchenAid Cooktops
How to remove scratches from stainless steel appliances
Try this at your own risk. Step 1 Consider using a product made for stainless steel2_bing.gif such as Scratch-B-Gone or Bar Keepers Friend (see Tips).
  • Step 2 Or, try spraying an all-purpose cleaner (such as Formula 4092_bing.gif) on the scratches.
  • Step 3 Use a non-metal scouring pad (such as Scotch-Brite pads) to rub the cleaner in, always rubbing in the direction of the grain.
  • Step 4 Keep the stainless steel wet with the cleaner as you work, and rinse the pad often.
  • Step 5 Rinse the surface and wipe dry.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Tips & Warnings
    • Before using any treatment on your stainless cookware, sink or appliances, it is wise to call the manufacturer for advice.
    • A new product called Scratch-B-Gone is touted as the "first aid kit for stainless steel." You can find it at many home improvement stores.
    • Bar Keepers Friend is another product for stainless steel. It can be found in most grocery or home improvement stores, or at www.barkeepersfriend.com.
    • To keep stainless steel sinks from scratching, put a rubber mat in the bottom of the sink to protect it.
    • Avoid using abrasive
    Please rate 4 thumbs for the free answer
    Mar 13, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Need new stainless steel top.
  • Firstly clean with DeBruce Polish to clarify area.
  • you may have to "re-grain" those finely scratched areas.
  • Blend or "scratch out" the misdirection scratch's with new "controlled" scratching, useing a 3M scotch brite #7447 you get at auto parts store (Nappa). Use medium very firm pressure.
  • -Re-clean with DeBruce Polish. Touch ups are now a breeze
  • DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. NO NEED TO REPLACE. We buy DeBruce at debrucepolish.com.
    Feb 16, 2010 | Tappan TGF657 Gas Kitchen Range
    Scratched stainless steel
    We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
    use scotch brite #7447 get at automotive stores and blend scratches with the grain. If they still exist use 180 to 240 grit sandpaper and again finish with the 7447
    Mar 29, 2009 | Kenmore 99123 Electric Kitchen Range
    I just purchased a G.E. dishwasher with a black front panel that is glossy. My daughter used a mister clean sponge to clean it and is now full of scratches, is there anything I can use on it to get them...
    Once paint is scratched it is scratched. There are cheap and inexpensive ways to cover that panel with a glossy black, or even stainless or white, or whatever. Go to www.applianceart.com, they have a ton of options to help your dishwasher getting back to its new look....and give your daughter a break, she was just trying to help :)
    Mar 27, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
    How to clean stainless steel
    You say your new oven...and DW have stains...I will assume (if that's OK) that you have a stainless steel oven...and are washing stainless steel in the DW...but you are having streaks and or white...spots or deposits...Sounds like hard water...you may try a localized..(just for the DW and kitchen sink area) filtration system...to reduce hardness of water...(is this well water)..if so you definitely need filtration...if you don't already have it.
    Here are some issues and or cleaning techniques for stainless steel.
    stainless steel is known for its ability to be a clean surface that resists corrosion and rust. Dirt, dust and grime, however, put stainless steel at risk for corrosion and rust. Luckily, stainless steel responds well to cleaning, never wearing out from excessive cleaning, as long as certain rules are followed. 1. Water and a cloth.
    Routine cleaning can be accomplished by using warm water and a cloth. This is the least risky option For cleaning stainless steel. Dry with a towel or cloth to prevent water spots. Wipe in the directions of the polish lines.
    2. Mild detergent, (dish washing liquid) and cloth.
    For cleaning that needs more power, mild detergent and warm water can do a great job without damaging the stainless steel. Make sure you rinse the surface thoroughly to prevent staining and spotting. Towel dry to prevent water spots which can be caused by minerals in water.
    3. Glass cleaner for fingerprints.
    Fingerprints are one of the biggest complaints about stainless steel, but can be taken care by using glass cleaner or household ammonia. Rinse thoroughly and towel dry. There are some newer types of finishes for stainless steel that resist fingerprints, a must if your pint-sized helpers leave their mark on your stainless steel appliances.
    4. stainless steel Cleaner.
    If you’ve had staining or scratching, or need to polish your stainless steel, a stainless steel cleaner may be a good option. Some of these cleaners and polishes can help minimize scratching and remove stains. They also can polish stainless steel surfaces nicely. Read the directions on the stainless steel cleaner and test in an inconspicuous spot. Be sure to rinse thoroughly and towel dry.
    If this does not help please clarify...with specific model #'s and walk me through (step by step) what the specific problem is and how you address it....Thank you and I hope this helps.............
    Good Luck...........The Fang.
    Mar 06, 2009 | GE Nautilus 24" Built-in Dishwasher
    Scratches on stainles steel door
    IF IT IS BRUSHED STAINLESS, AND THE SCRATCHES ARE REALLY BAD, YOU COULD TRY SOME STEEL WOOL TO SOFTEN THE SCRATCHES, BUT IT WILL BE A TRADE OFF OF MINIMIZING THE SCRATCHES AND CAUSING A SMEARED LOOK TO THE BRUSHED STAINLESS PATTERN.
    Apr 16, 2008 | GE Profile PSW26P Stainless Steel Side by...
    Rust stains appeared all over the outside of the stainless steel front of over, air outlet and splash back. What would have caused this and how can we fix this problem?
    If I understand your question, your stainless steel surfaces have rusted. Correct?
    Contrary to popular belief, stainless steel CAN rust under the right circumstances.
    I won't go into what may have caused this problem, but I will hopefully help you solve it and prevent future rusting.
    Usually it is only surface rust and not deep pitting of the steel.
    Surface rust can usually be removed with a product like Soft Scrub cleanser or liquid Meguiar's Car Cleaner Wax.
    Apply a small amount of either product to a clean cloth and rub over the rust until it is removed.
    Wait until the product dries and buff with a clean cloth.
    If you have a brushed stainless steel surface, you will want to rub in the same direction of the "grain".
    One benefit of the wax is that it will protect the surface from future rusting.
    If the rust cannot be removed in this manner, a more aggressive approach is required. Do NOT use the following procedure if you have a smooth stainless steel surface, only if you have the brushed surface..
    Use a non-metallic scuff pad, such as a 3M Green Scouring Pad and rub in the direction of the brushed stainless steel grain.
    This process should remove all surface rust and even some minor scratches. You can use the pad dry or better yet, with a liquid wax as a lubricant.
    Never use steel wool!
    It will only leave small particles of steel imbedded in the surface. The condition will look worse when the particles themselves rust!
    I cannot be held responsible for any damages that may occur from the above procedure. But, it has worked fine for me whenever I have implimented it on dozens of similar surfaces.
    Good Luck!
    Mar 05, 2008 | Kitchen Ranges
    SCRATCHED STAINLESS STEEL SINK
    Have you tried a really fine steel wool? I don't know if this would work. I have stainless steel farmhouse sink, front exposed all stainless steel. My contractor scratched it up horribly when he was putting it into the kichen. he fixed it amazingly with a fine steel wool pad. I don't know if your scratch is too deep for that but it couldn't hurt. The scratches on our sink were surface but very noticeable. Hope this helps.
    Feb 08, 2008 | Kitchen Ranges
    How to clean the stainless steel stove top
    try a non abrasive cleaner like bartenders helper. it wont scratch and should help to tone down some scratch marks.
    Aug 04, 2007 | Thermador 37 in. SGSX365 Gas Cooktop
    Refrigerators Logo
    263 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
