Question about Oreck MKT800 Vertical Hand Mixer
My Mom wants me to find an Oreck 800 MKT for her, but I don't think they are available anymore...Any ideas?
Most places have it listed but they are actually out of stock when u go to order.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Oreck Master
  • 102,366 Answers
As of this post there is one here.
Posted on Jan 10, 2013
  • winklerorama Jan 10, 2013
    I see it is there, thanks! But for $99? Salesstore had them for $32 'til they ran out!
A mixer blade for an Oreck MKT800
Hello, Gary -
From what I have found about the Oreck MKT800 Vertical 5 Speed Hand Mixer, there is no "mixer blade" attachment for the appliance. The attachments for the mixer are:
- 2 beaters
- 2 whisks
- 2 dough hooks
You can see an image of the hand mixer with all 6 attachments here:
http://www.qvc.com/Oreck-Vertical-5-Speed-Hand-Mixer-with-Attachments.product.K6135.html
If you mean a replacement beater, whisk, or dough hook for your Oreck MKT800, so far, I have not found a source for those replacements.
Best wishes.
Mar 24, 2018 | Oreck Food Mixers
Where can I find replacement beaters for an oreck mixer?
They no longer seem to sell mixers, so no spares. You could contact them direct from this link.
http://www.oreck.com/customer-service-group/contact-us.html
Or you can look in the main link and see if any for sale are the same. The mixer was probably made in Taiwan and badged 'Oreck'.
mixer beaters replacement parts Google Search
Nov 22, 2016 | Oreck Food Mixers
Kitchen Aid flat beater leaves carbon on my hands and food
Are you using the white coated beaters or the burnished beaters. If they are the white coated beaters then the finish has come off and the zinc/underneath is rubbing off. Are you using the aluminum looking beaters in heavy acidic applications? if the mixer is new go to kitchaid customer support they will re-place. if your mixer is out of warranty then you need to replace it. about 15.00 t0 24.00 USD. if the problem persists then you may be leaking metal shavings from the planetary head, (I don't think it is happening but it is a possibility) if it is ground metal shavings you have a serious problem. I can't say anymore without knowing more. What application are you getting this result. is it all the time. is it after the mixer sits along time. need more info.
Aug 27, 2012 | KitchenAid Food Mixers
Killed my mom's mixer on accident and was planning on taking it part to see if I can fix it. only problem is I cant get the dang thing open. can anyone help, please?
It also has snaps that have to be popped loose in order to separate the bottom from the top it takes some force here. Even after the screws are out
Apr 07, 2012 | Kenmore KSM035 Stand Mixer
I don't have a problem I just wanted to know the difference between the two products. I have the KSM 90 and nothing is wrong with it. I just wanted to know how much of a difference between the two. ...
Except for asthetics and whatever obvious trim such as handles on bowls, etc, there is NO PRACTICAL DIFFERENCE; both mixers are outstanding appliances.
There has always been ONGOING MODIFICATIONS in motor design, relating mostly to formation of the electromagnetic flux and other intangibles, you will find OLDER KSM90s may have a slightly higher degree of OVERBUILDING- such as COPPER plating flashed on the back end of the carbon brushes to improve effciency, reduce heat, and lower electricl resistance, another example is oil wick felts included with the rear bearing assembly to help lubrication on older models. In both cases its over-engineering and it costs money- Ive never been able to read difference between the two carbon brushes on a Watt meter in actual use, nor have I ever actually seen, in more than 30 years mostly as authorized warranty service center more than just one single WORN rear bearing (from a mixer in a science lab, not a kitchen) with or without the oil wick felt- thats out of several hundred thousand mixers!
Newer mixers lack other similar accoutrements which had proven to provide limited tangible benifit on a practcal level.
KitchenAid keeps knowledgeable staff available at their 800 phone line at customer service to go into this subject without the unnecessary technical depth I've given,, and they may yet recall my name after these many years -DeSantis (Im the [disabled] son, JD2, not the grandson)- from the Trenton/central NJ area.
Sep 18, 2011 | KitchenAid KSM150PS Artisan Series Stand...
The top part of my mixer is sitting about 1/4 inch lower than it should. It's placing the beater too low in the bowl and therefore won't mix. (I tried to whip up some whipping cream but it pushes...
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download the following Kitchenaid Service Manual:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers several models including yours.
1. Check/Adjust the Flat Beater to Bowl Clearance:
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
Jul 04, 2011 | KitchenAid KSM150PS Artisan Series Stand...
MY kitchen Aide mixer was running alittle rough /loud and now has stop completely. It is approx 24 years old and has never had any problems. It is hard to find a local repair [place. any suggestions
Two things you can do for a 24-year old machine:
1. Replace both motor brushes (Black large plastic Caps on each side
of the Moto Housing). Without these, the motor wouldn't even run.
2. Replace the Worm Gear (the cause of the Rough Loud noises)
Download a copy of the Repair Part List from Kitchenaid.com for
your model KSM90.
Also don't forget to tighten all the screws inside the mixers and use
fresh Kitchenaid Grade Food Grease for all the gears.
Jun 21, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Beater broke apart
You can visit http://www.prodprotect.com and click on the Name Brand of product, under Parts & Accessories click on the Contact Us. Once this page has loaded, click on the link at the top of page that states 'To order accessories click here'. If the model or part is not listed on the website, then call 1-800-738-0245 (Monday-Friday, 8:30 a.m. to 8:00 p.m., ET) for price and availability. All major credit cards are accepted. Have the model number of your product when placing the call.
Or you can visit www.fox-international.com or send an e-mail to applicaconsumeraffairs@fox-international.com.
Jan 18, 2009 | Black & Decker 200 Watts MX85...
Oreck MKT800 Vertical Hand Mixer Logo
50 people viewed this question
Top Oreck Food Mixers Experts
vince
Paul Carew
Andrew Taylor
Andrew Taylor
Are you an Oreck Food Mixer Expert? Answer questions, earn points and help others
