Question about Frigidaire FEQ1442ES Electric Dryer
My dryer will not quit beeping
  • Official Brand Answer
  • 4,342 Answers
Hello Lindsay Haney - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If it proves to be ineffective, then the dryer may be experiencing a wiring failure or communication error with the control board. Contact a professional to move forward accurately.
Posted on Jan 14, 2013
How do i make it quit beeping so often
Hello friend, thanks for your post!
I understand that your Frigidaire dryer is beeping and flashing lights. To reset your dryer you should disconnect power, by unplugging it or flipping the household circuit breaker, for roughly ten minutes. Which lights are blinking on your display panel? It could be providing you an error code.
If the reset does not help correct the issue, could you please provide me with your model number? Typically you can locate the serial tag (which lists your model number) on the door frame of your dryer. If you need further assistance please reconnect with me. -Matt
Sep 27, 2014 | Frigidaire Dryers
How to fix the heat in a dryer
In an electric dryer you check for bad components using an ohmsmeter. I like to use an audible ohm meter. if it beeps it bueno if it don't beep it is bo bo. I remove at least one wire from each component to get a good reading on each component, The bad conponent gonna be the reason for no heat.
For gas I do basically the same thing however if the heat does work a little and quits that is the solenoids. they go bad when heated up with age.
All dryers basically have these components on them. Kimits on the heater, a heater element, a control tstat and fuse on the blower. All have this type setup no matter how they are put together. here is a video I made of an electric dryer:
Roper dryer no heat
Gas dryer no heat
Jul 31, 2012 | Maytag Dryers
Dryer has power, buttons on front beep when touched, but dryer will not turn on when you hit the run button, and drum light has quit working, cannot seem to locate my users guide or fine one on-line to...
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Jan 29, 2011 | Kenmore 84072 Electric Dryer
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Works for a few minute then shuts off and beeps quite often
check the exhaust vents for any lint build up which will shut down the burner electronicly
Aug 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
3 beep-tones
I am having this same problem, and it seems quite intermittant. I have finally narrowed it down to an electrical issue, somewhere on the control circuit board (which I have sitting in front of me right now.) I'm going to see if I can buy a new one, and for how much, before calling out the repairman.
Mar 16, 2009 | Frigidaire FEQ332E Electric Dryer
I checked clothes just before cycle was ended and can't restart
This code is obviously protecting the dryer from doing further damage to itself. This is like a breaker. Call a repairman and have it serviced. If it is more than 12-15 years old, consider a new one.
Nov 13, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Ge harmony dryer not heating up dpgt750ec1pl
If you hear the blower ramp up when you start the dryer and if slowly ramps down or quits all together then you need to replace the blower. If the dryer heats at all then look at the blower.
Jun 20, 2008 | GE Profile Harmony DPGT750EC Electric...
Frigidaire FEQ1442ES Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
