Question about Tascam DA-30MKII
Tascam DA30 Mk1 drawer and noise problems
My Tascam DA30 Mk 1 is exhibiting 2 faults. If you insert a tape it very often spits it out again straight away accompanied by the 'Open' message. Also, when a tape is playing, or even when you are sending a signal through the machine with a stationary tape and the record button pushed there is a rhythmic clicking sound ( about 2 per second ) on analogue or digital out. Any ideas?
  • tim58 Jan 23, 2009
    Thanks, I'll take a look : )
    Genius:
  • 1,175 Answers
HI...
There are 2 belts in the mechanism that would need replacing.
I've fixed 2 of these.
There's a very small belt on the underside of the tape drive assembly
1.55 inch belt x 0.039
www.studiosoundelectronics.com # SBO1.55
Dont remember the other
Posted on Apr 10, 2009
    Scholar:
  • 140 Answers
Sound like it needs servicing.
You prob have a bad or warn capstain or pinch roller.
Also replace the belts if this unit is not direct drive. The mechanics are simple. The only relacement parts are the rubber.
Posted on Jan 23, 2009
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
Tascam 424 mk 11 wont record but lights come on
These unit as small as they are have to be worked on by professionals that know how to fix them. So far as I know there is only me in Chicago and Russ in New Jersey that can repair them.
Without seeing the unit I can not tell you more about how to fix it.
It could be anything in the unit that has the problem.
Jul 27, 2016 | Tascam Audio Players & Recorders
My TASCAM DA-20 Mk II DAT doesn't play back any of my tapes. It still appears to record OK, but there is no level meter or sound or track finding when playing back, though the tape seems to be run
Hi Julian,
There is a lot that can go wrong with these miniature helical scan systems. When I had units like that I packed them off to Russ at New Jersey Factory Service and they were restored. I am not sure about parts like drums at this point but Russ is your best chance to get it working again. He has corrected CDRW and DAT as well as just about anything Tascam makes and he even fixed some Sony units too. I know him as the counterpart to the Chicago Factory Service facility when it was open. He was the Manager in New Jersey then.
New Jersey Factory Service, Inc.
16 Chestnut Avenue Suite 103 B
Emerson,New Jersey 07630
201-967-0060
Fax 201-967-0062
Mon- Wed 8-4 Thurs 8-3(July-Aug) Closed Fri Sat by appt.
Aug 23, 2012 | Tascam Audio Players & Recorders
I have a standard DP 02 (non cf) and I want to add vocal tracks to a previously recorded song (tracks 1 and 2) and I don't get any sound from my mic. The mic/line/guitar switch is set to mic/line but the...
you have to make sure the song tracks(1 &2 ) are not armed. then you can assign your vocal to any of the other tracks. after you do this , make sure you arm the track. you should be able to hear your mike.
Apr 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
I am having problems with my Tascam Da-88 8
Maybe you could just clean the heads. If anything visible comes off they're TOO dirty. Or or look at it yourself with a strong light source and see the wear by evaluating reflections from the head surface.
May 31, 2010 | Tascam HHB DA30 Tape for DA-88
How to load tape
it's not obvious indeed!
The idea is to;
1. take out the ring (try it by releasing the back part first! easy does it.
2. put tape into the Dymo 1855 mk II by pressing the white lever down
3. then take the tape you pushed through and guide it through the ring.
4. Put the ring back into the Dymo.
It worked for me ;-)
Good luck,
Marc
Nov 16, 2008 | Office Equipment & Supplies
Tascam da30
www.datrecorders.co.uk/da30.pmp has a pdf version you can download for a fee.
Apr 12, 2008 | Tascam DA-30MKII
Tascam 488 mk II recording problems
Have you taken a look at the edge of the tape? tracks 1 and 2 on a cassette are usually next to the edge and you may have a bad batch of tapes that have the edge damaged. Another possible but not a likley problem might be the tape is out of spec. for the width, and your heads MAY have a little wear from use, and are trying to act like tape guides. If the tape is slightly wider than the grove worn in the head, the tape would be lifted at the edge and not make contact to the head. It is not electronic as you have diagnosed this with other tapes. Give it a try and see!
Aug 05, 2007 | Maxell 109069 Audio Cassette (Type 1)...
Electronics - Others Logo
626 people viewed this question
Top Tascam Electronics - Others Experts
Glenn Mayer
Glenn Mayer
Computer Links
rjivaro
Are you a Tascam Electronics - Other Expert? Answer questions, earn points and help others
