Question about HP/Compaq P4 System - WinXP Pro/Office (HPCQP4) PC Desktop
I play igi3 the picyur is lift right not up and down
  • HP Master
  • 2,385 Answers
Adjust the controller from setting
Posted on Jan 11, 2013
Lifted front wheels got play side to side but not up and down lifted front wheels have play side to side not up and down
If you mean that the wheels seem loose on their spindles then your wheel bearings may need to be replaced. If you mean there is excess play in the steering then your tie rod ends, pittman arm, or idler arm are worn and need to be replaced. Put the wheels back on the ground and try shifting the tie rod back and forth. There should be no free play. If you replace any of the steering parts, you will need to get a front end alignment.
Sep 29, 2013 | WELLY 1/18 99 Ford F150 Flareside Lariat...
I'm tryin to take down my Eddie Bauer pack n play!
Some of these Pack n Plays are double jointed where you fold the sides. Feel around the buttons you release the sides with and see if there isnt a release button on each side of the joint. Remember, all Pack N Plays use a safety on the floor of the playpen that must be lifted to allow the sides to fold. I think you have already done that but the second release button is holding you up.
Feb 10, 2012 | Eddie Bauer Baby Gear
Bcm locate and change .picyure where it is
Are you trying to locate the body control module in your 98 Voyager? It's under the dash on the left hand side. The interior fuse box is mounted to it. Remove the lower cover, the lower half dash cover, the metal kick panel, possibly a couple other dash components. (can't exactly recall right now) Unscrew the four electrical connectors on the front of the BCM and the two electrical connectors on the bottom of it. Remove 3 bolts holding the BCM in place and it should come right out.
Jan 27, 2012 | 1998 Plymouth Voyager
I have a acer aspire, i just bought it and the thing wont let me put any picyures on the back ground i when through the help thing ad nothing it said worked either
Hi, if you're trying to set a picture as your desktop background, you can right click on it and then choose "Set as desktop background".
May 04, 2011 | Acer Computers & Internet
Knoking front right wheel
Hi if you hear the knocking noise more when you go over slightly bumpy road then the chances are the bottom ball joint needs replacing these dont cost much to buy and its best to replace both sides, you will need some special tools such as ball joint splitter and a workshop manual would be helpful if you have never done this before and you are doing the work yourself
another problem could be the anti roll bar bushes what you can do to test to see if its the bottom ball joint or not is to jack the car up so that wheel is off the floor slightly then place a stand under the car so its safe to get under then get a strong bar such as crow bar and get someone to put this under the tyre and lever it up so they are lifting the wheel up and down slightly then if you get under neath and have a look behind the wheel then the bottom ball joint is the part that fits into the bottom of the hub, now once you have found this see if their is any play when the person is lifting the wheel up and down with the bar.
if their is play then it needs replacing, it will be hard to lift the wheel up and down so you will need a strong bar to put under the tyre on the road and wiggle it up and down so it lifts the wheel slightly then have a look and listen for any play in the bottom ball joint.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Oct 01, 2010 | Mitsubishi Galant Cars & Trucks
How do i take a black and white picyure with canon sx20is.
Press the FUNC/SET button, then use the up/down buttons to select the second item on the menu. Press left/right or turn the command dial to choose. Your choices include SE for sepia-toned and BW for black&white. For the full list of choices, look under "Changing the Tone of an Image (My Colors)" in the manual (it's on page 76 in my copy).
Having said that, it's usually better to do the conversion on a computer. You get more control over brightness, contrast, and so on that way. And, if that once-in-a-lifetime thing happens, you have the original in color.
Mar 30, 2010 | Canon PowerShot SX20 IS Digital Camera
Green light but no picture or sound.
First thing you wanna try is a manual video reset.
It's probably a good idea to hook up the regular av cables as well.
While the PS3 is off (red led)
Hold down the power button until you hear the second beep, quickly release.
Let me know what happens.
Jun 17, 2009 | Sony PlayStation® 3 (60 GB) Console
Grandautosandandreascheat
Cheat: Infinite Lung Capacity
During game play press DOWN, LEFT, L1, DOWN, DOWN, R2, DOWN, L2, DOWN
Cheat: Cars Fly
During game play press UP, DOWN, L1, R1, L1, RIGHT, LEFT, L1, LEFT
Cheat: Taxis Have Nitrous and L3 Bunny Hop
During game play press UP, X, TRIANGLE, X, TRIANGLE, X, SQUARE, R2, RIGHT
Cheat: Weapon Aiming While Driving
During game play press UP, UP, SQUARE, L2, RIGHT, X, R1, DOWN, R2, CIRCLE
Cheat: Traffic is Fast Cars
During game play press UP, L1, R1, UP, RIGHT, UP, X, L2, X, L1
Cheat: Reduced Traffic
During game play press X, DOWN, UP, R2, DOWN, TRIANGLE, L1, TRIANGLE, LEFT
Cheat: Spawn Dozer
During game play press R2, L1, L1, RIGHT, RIGHT, UP, UP, X, L1, LEFT
Cheat: Gangs Control the Streets
During game play press L2, UP, R1, R1, LEFT, R1, R1, R2, RIGHT, DOWN
Cheat: Massive Bunny Hops
CJ has the ability to bunny hop on the bmx over massive distances: TRIANGLE, SQUARE, CIRCLE, CIRCLE, SQUARE, CIRCLE, CIRCLE, L1, L2, L2, R1, R2
Cheat: Beach Party
Pedestrians turn into girls wearing swimsuits. Vehicles are also beach style and CJ will be dressed in shorts and sandals. While playing Grand Theft Auto: San Andreas enter: UP, UP, DOWN, DOWN, SQUARE, CIRCLE, L1, R1, TRIANGLE, DOWN
Cheat: Spawns a Stunt Plane
CIRCLE, UP, L1, L2, DOWN, R1, L1, L1, LEFT, LEFT, X, TRIANGLE
Cheat: Monster Truck
RIGHT, UP, R1, R1, R1, DOWN, TRIANGLE, TRIANGLE, X, CIRCLE, L1, L1
Cheat: Vehicle of Death
Any vehicle the player is using becomes invincible and gains the ability to instantly destroy anything it touches. L1, L2, L2, UP, DOWN, DOWN, UP, R1, R2, R2
Cheat: Get Parachute
LEFT, RIGHT, L1, L2, R1, R2, R2, UP, DOWN, RIGHT, L1
Cheat: Full Health, Full Armor, $250,000
To have all of the above, press the following while playing GTA: San Andreas: R1, R2, L1, X, LEFT, DOWN, RIGHT, UP, LEFT, DOWN, RIGHT, UP.
Cheat: Weapon Set 2
To unlock the Knife, Pistol, Sawnoff Shotgun, Tec 9, Sniper Rifle, Flamethrower, Grenades, Fire Extinguisher in Unlock some new rides in GTA: San Andreas enter: R1, R2, L1, R2, LEFT, DOWN, RIGHT, UP, LEFT, DOWN, DOWN, LEFT.
Cheat: Weapon Set 3
You can unlock the Chainsaw, Silenced Pistol, Combat Shotgun, M4, Bazooka, Plastic Explosive in Unlock some new rides in GTA: San Andreas during gameplay by pressing R1, R2, L1, R2, LEFT, DOWN, RIGHT, UP, LEFT, DOWN, DOWN, DOWN.
Cheat: Weapon Set 1
To unlock the Bat, Pistol, Shotgun, Mini SMG, AK 47, Rocket Launcher, Molotov Cocktail, Spray Can, Brass Knuckles in Grand Theft Auto: San Andreas enter: R1, R2, L1, R2, Left, Down, Right, Up, Left, Down, Right, Up.
Cheat: Get Rhino
To make a Rhino tank fall from the sky, press the following during gameplay: CIRCLE, CIRCLE, L1, CIRCLE, CIRCLE, CIRCLE, L1, L2, R1, TRIANGLE, CIRCLE, TRIANGLE.
Cheat: Wanted Level Up
To raise your Wanted Level, enter the following during gameplay: R1, R1, CIRCLE, R2, LEFT, RIGHT, LEFT, RIGHT, LEFT, RIGHT.
Cheat: Blow Up All Cars
To make all vehicles explode, press the following during gameplay: R2, L2, R1, L1, L2, R2, SQUARE, TRIANGLE, CIRCLE, TRIANGLE, L2, L1.
Cheat: Wanted Level Down
To erase your Wanted Level, enter the following during gameplay: R1, R1, CIRCLE, R2, UP, DOWN, UP, DOWN, UP, DOWN.
Cheat: Flying boats
During game play press R2, CIRCLE, UP, L1, RIGHT, R1, RIGHT, UP, SQUARE, TRIANGLE
Cheat: Spawn Bloodring Banger
During game play press DOWN, R1, CIRCLE, L2, L2, X, R1, L1, LEFT, LEFT
Cheat: Spawn Ranger
During game play press UP, RIGHT, RIGHT, L1, RIGHT, UP, SQUARE, L2.
Cheat: Spawn Hotring Racer 1
During game play press R1, CIRCLE, R2, RIGHT, L1, L2, X, X, SQUARE, R1.
Cheat: Spawn Hotring Racer 2
During game play press R2, L1, CIRCLE, RIGHT, L1, R1, RIGHT, UP, CIRCLE, R2.
Cheat: Spawn Romero
During game play press DOWN, R2, DOWN, R1, L2, LEFT, R1, L1, LEFT, RIGHT.
Cheat: Spawn Stretch
During game play press R2, UP, L2, LEFT, LEFT, R1, L1, CIRCLE, RIGHT.
Cheat: Spawn Trashmaster
During game play press CIRCLE, R1, CIRCLE, R1, LEFT, LEFT, R1, L1, CIRCLE, RIGHT
Cheat: Spawn Caddy
During game play Press CIRCLE, L1, UP, R1, L2, X, R1, L1, CIRCLE, X
Cheat: Bounty on Your Head
While playing Grand Theft Auto: San Andreas press DOWN, UP, UP, UP, X, R2, R1, L2, L2.
Cheat: Perfect Handling
During game play press TRIANGLE, R1, R1, LEFT, R1, L1, R2, L1.
Cheat: Aggressive Traffic
While playing Grand Theft Auto: San Andreas press R2, CIRCLE, R1, L2, LEFT, R1, L1, R2, L2
Cheat: Drive on Water
During game play press RIGHT, R2, CIRCLE, R1, L2, SQUARE, R1, R2
Cheat: Black traffic
While playing Grand Theft Auto: San Andreas press CIRCLE, L2, UP, R1, LEFT, X, R1, L1, LEFT, CIRCLE
Cheat: Pink Traffic
During game play press CIRCLE, L1, DOWN, L2, LEFT, X, R1, L1, RIGHT, CIRCLE
Cheat: Suicide
RIGHT, L2, DOWN, R1, LEFT, LEFT, R1, L1, L2, L1
Cheat: Faster Clock
CIRCLE, CIRCLE, L1, SQUARE, L1, SQUARE, SQUARE, SQUARE, L1, TRIANGLE, CIRCLE, TRIANGLE
Cheat: Sunny Weather
R2, X, L1, L1, L2, L2, L2, SQUARE
Cheat: Faster Cars
RIGHT, R1, UP, L2, L2, LEFT, R1, L1, R1, R1
Cheat: Pedestrian Riot- Cannot be disabled
DOWN, LEFT, UP, LEFT, X, R2, R1, L2, L1
Cheat: Overcast Weather
R2, X, L1, L1, L2, L2, L2, TRIANGLE
Cheat: Faster Game Play
During game play press TRIANGLE, UP, SQUARE, SQUARE, L2, L1, SQUARE
Cheat: Foggy Weather
During game play press R2, X, L1, L1, L2, L2, L2, X
Cheat: Slower Game Play
During game play press TIRANGLE, UP, RIGHT, DOWN, SQUARE, R2, R1
Cheat: Rainy Weather
During game play press R2, X, L1, L1, L2, L2, L2, CIRCLE
Cheat: Pedestrians Have Weapons
R2, R1, X, TRIANGLE, X, TRIANGLE, UP, DOWN
Mar 23, 2009 | Sony PlayStation 2 Slimline Console
My picyures come out with lighter color stripes down them. I just
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP/Compaq P4 System - WinXP Pro/Office (HPCQP4) PC Desktop Logo
14 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
