Question about Whirlpool GEW9250 Electric Dryer
Dryer is leaving burn marks on clothes on any temperature.
Burn marks occur even if clothes are taken out as soon as cycle is complete. Clothes are being ruined.
  • 1 more comment
  • abbengoodwin Jan 28, 2009
    My dryer leaves burn marks too.
  • jsuareo Feb 05, 2009
    No matter what temp we have the dryer on, or how much or little we have in the dryer, it leaves burn marks on our clothes
  • mpilot May 04, 2009
    We have a 3 or 4 year old super capacity dryer and it is leaving little marks that look like burns, mostly on bed sheets.
    Model LEB-603582
  • 686 Answers
Change your cycling thermostat. It is not telling your heat element to shut off at the rated emp
Posted on Mar 12, 2009
MY FRIGIDAIRE ELECTRIC DRYER IS LEAVING BURN MARKS ON CLOTHES,WHAT IS CAUSING PROBLEM
Assuming that you have the correct temperature selected for your clothes, there are two likely causes:
If the clothes are showing randomly shaped burn marks, the dryer is overheating. This would be accompanied by a burnt smell on the clothes. The high limit thermostat is the culprit.
If the burn marks are dark streaks, the clothes are getting pinched between the drum and the inside of the dryer that does not move. This is caused by worn bearings, slides or rollers. Should you choose to repair this yourself, there is a great deal on a kit with all of the parts you need plus a new belt for only $32 here:
http://www.repairclinic.com/PartDetail/Drum-Bearing-Felt-Seals-Pulley-Belt/5304461262/1261075
Good luck from Detroit, Mi.
Jul 20, 2011 | Frigidaire GLER341A Electric Dryer
Leaving burm marks on clothes
its getting to hot,,,check its air intakes to see if there blocked up and also the hot air outlets (hose pipe) if thats blocked up change it
Jul 10, 2010 | Hotpoint NBXR333EGWW Dryer
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
Whirlpool Duet dryer - "burn marks", "out of round" drum
It's not really BURN marks - it is the adhesive used to affix the felt. You can substitute for silicone to remedy this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Kenmore Elite 45986 Front Load Washer
Burning marks on clothes in dryer
how old is dryer. drive belt may be slipping. Unit may have a faulty control that allows element to superheat. You have a potential fire hazard. What type of clothes are getting the burn marks? Should they be dried in a dryer?
Jul 02, 2009 | Dryers
The dryer is leaving what looks like brown burn marks on clothes
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
Dryer door pops open. leaves burn marks on clothes.
check to see if you have bent door hinges first, do this by opening the door all the way down and see if it is level with the floor. if it goes past level then the hinges are bent.
guess someone may have fell on the door or used it as a step.
if so, then you can take a hand towel and roll it up, then put it at the bottom of the door and close the door gently to "bend" the hinges back into place. this will aloow the door to stay closed and should also take care of the "burn" marks on your clothes.
i would guess the unit was overheating from the door not closing right allowing air to enter around the door. that will cause the unit to overheat and leave marks on your clothes.
Dec 28, 2008 | Kenmore 63942 Dryer
Dryer Leaving Burn Marks On Clothes
HI thanks for your question. the problem with your dryer, is that the front felt bearing is worn. and dropped the drum a bit and clothes getting caught. replace the front bearing and the back bearing. not too expensive. thanks the appliance doc. please rate my question. thanks.
Oct 09, 2008 | Dryers
Burn marks on clothes
problem is caused by drum seal usually the back one look closely at seal to see if there appears to be rust if so replacedrum seal ..clothes ten to rub against it while in motion causing brown streaks..would replace both front and rear just to be sure front doesn't give problems soon
Jul 26, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
1,002 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
