Question about Ryobi Garden
I have a Ryobi 780r that won't run unless it is on choke. The moment I remove the switch from choke to run it shuts off.
    Sergeant:
  • 322 Answers
This means you have an air leak somewhere adding more air than fuel with the choke off. With the choke on it blocks off the fresh air coming in and mixes with the maverick air from the air leak. You need to find the leak and fix it or you may damage the unit
Posted on Jan 16, 2013
boscia
  • 163 Answers
SOURCE: ryobi weed trimmer
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. i
Posted on Nov 29, 2008
#1 Taper
  • 1040 Answers
SOURCE: My Ryobi 705r strimmer won't run !
The carburetor needs to be disassembled and cleaned with carb. cleaner. Or, it needs a new carburetor kit. If you need tips on how to do this, just let me know.
Jim
Posted on Jun 04, 2009
#1 Taper
  • 1040 Answers
SOURCE: Ryobi 700r trimmer will not run without choke
First check the fuel lines for breaks, usually found at the tank. If lines are o.k. then you will need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush, (used for cleaning between teeth), to clean the small portals in the carb. Reassemble and start. If it still doesn't run any better, then you will need to buy a carb. kit and replace the small screen, gasket(s), diaphragm, & needle valve.
Jim
Posted on Jun 05, 2009
  • 15 Answers
SOURCE: Ryobi weed eater runs at full choke, but stalls
does it blow out alot of blue or dark exhaust? if so adjust screw on carberator as it maybe be running rich, if this doesnt work have the switch checked for malfunctioning
Posted on May 31, 2010
JAL69692002
  • 334 Answers
SOURCE: my 32cc 4 cycle craftsman weedwacker won't run off choke
MORE THAN LIKELY YOU HAVE BEEN USEING ETHANOL FUEL NEED A METANOLE FUELCLEANER AT MOST AUTO PARTS SUPLYER THEY SELL A FUEL CLEANER FOR SMALL ENG. IF NOT THAT MAKE SURE FUEL LINE IS NOT CRACKED
Posted on Nov 15, 2011
I have a 30cc ryobi trimmer that will start but not run unless the choke is fully on. The moment I use the throttle or turn off the choke ,it dies. what could be the problem? thanks.
Hi Guy:
The first thing I would check would be the fuel filter.
Try pulling it out and giving it a really good clean.
Probably a good idea to put fresh gas in at the same time if it's been sitting for a while.
Aug 11, 2015 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
Ryobi problems
Yes sir it is. You need to adjust the carburetor. Unless you have an adjustment tool you'll have to take it somewhere to have this done.
Jul 16, 2014 | Ryobi Garden
Bolens cultivator model BL410 won't keep running
clean the screen inside the muffler
Aug 03, 2012 | Garden
2007 Yamaha 115 Hp 2 stroke idle problem
Check the idle mixture. Sounds to me like it is too lean.
Mar 20, 2017 | Clymer EvinrudeJohnson Outboard Shop...
Mower starts and runs but has no power acts like its flooding it burns a lot more gas can barley pull it self
Sounds like maybe the choke is stuck closed. If you remove the air filter the choke is the first butterfly valve you can see. The throttle looks similar but is a inch or so deeper into the carb, and you can't see that unless the choke is open. Try removing the air filter and starting the mower. It might run just a little better without the air filter since it will get a bit more air, but if the choke is stuck it still won't run right. But you will be able to see if that's the problem right off. If it runs great without the air filter, and the choke is not stuck, then the problem is a clogged air filter and you need to replace it. Good luck, Al K
Jul 26, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How to replace recoil assembly on roybi 780r
have ryobi 780r and primer bulb won't show fuel pressed and fuel comes out of fuel cap,i have pressure in fuel tank. it ran 2 weeks ago great?
Jul 01, 2009 | Ryobi Garden
Garden Logo
270 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
