Question about Ricoh Aficio AP3800C Laser Printer
Hi, Our company recently purchased a Ricoh Aficio AP3800C but when it prints it leaves 2 or 3 small black marks on the top of each page. What do we need to do to get rid of these marks?
Almost certainly the black PCU...order from dealer
Posted on Feb 26, 2009
Ricoh 3800 printing dots on the page
sounds to me like there is damage to the charge roller in the black pcu. these can be dissasembled and the charge roller inspected/cleaned but the blk drum units are inexpensive enough its probally just better to replace it
Oct 31, 2009 | Ricoh Aficio AP3800C Laser Printer
Wont print 2 colors, only black and white
The print driver might be defaulted to black and white. Change it to color.
May 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
My printer will only print from bypass tray. Why?
It may be something to do with the paper size settings on printer driver, document print settings or page setup. If for example the computer thinks the paper size is Letter, and the paper in Tray 1/2/3 is A4, it won't print.
Jan 23, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio AP3800C Printing Problem
If the marks are along the same line and look like dots the black photoconductor needs to be repalced.
Jan 21, 2009 | Ricoh Aficio AP3800C Laser Printer
Aficio SP4100N
Check the brown conveyor-belt inside the fusing unit. Maybe it has holes inside.
Dec 16, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh CL7000 protected menu
Go in through the web page (printer's ip address) Default username:Admin
Password: password
You can change it in there.
Oct 20, 2008 | Ricoh Aficio AP3800C Laser Printer
Nor printing magenta
If there is toner in the cart but not getting onto the page, the most likely cause is that the toner delivery tube is blocked. You can try removing the unit and vacuuming out the supply line to remove any lumps that may be lodged and then run the forced toner supply in the Service Mode.
Sep 14, 2008 | Ricoh Aficio AP3800C Laser Printer
Black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Feb 26, 2008 | Ricoh Aficio AP3800C Laser Printer
Smearned Printing on Ricoh Aficio AP3800C Laser Printer
Hi there the smudges are most likely down to the black PCU (Drum Unit) and following are the reasons for the two fault caode you have given me.
SC 261 LD HP sensor
not switched
off (for K only)
After the laser beam pitch was
changed, it takes more than
five seconds for the HP sensor
to switch off.
• Defective motor
• Defective sensor
• Mechanical problem
when switching the
actuator
• Brown fuse (FU81) on
the Power supply unit
1. Turn the main switch off and on.
2. Check the sensor actuator position of
the LD positioning motor.
3. Replace the LD positioning motor.
4. Replace the LD home position
sensor.
5. Check and/or replace the PSU.
SC 380 Black
development
motor error
SC 381 Color
development
motor error
When the motor speed is
within the target level, the
motor sends a lock signal
(High to Low at CN214-5) to
the BCU.
SC380 is detected under the
following conditions:
• The Lock signal stays High
2 seconds after the motor
turns on.
• The Lock signal stays Low 2
turns off.
for more than 2 seconds
while the motor is on.
• Defective motor
• Defective BCU
2. Replace the motor.
3. Replace the BCU.
Hope this is any help
Thanks J
Feb 21, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
296 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
