My problem is that the Internet connection is falling out sometimes.
My problem is that my Network that I got from my ASUS EA-N66 Universal Repeater/AP/Client sometimes falls off. (I lose the connection to the network). Its very annoying when im in the middle of a game, and suddenly the i lose the connection. and must start a new game from the start. And sometimes the network just gets so bad that I got huge lag in a game, and thats a problem, both of these problems are very annoying. and its never happend before I got my pc connected to the ASUS EA-N66 Universal Repeater/AP/Client. Hope you have a answer/a solution to this problem.
  • 244 Answers
SOURCE: AP Mode Problems
Probably you have to learn that there are various people looking for an access of the internet through your facilities. Anyway, inorder to solve your problem these are the following recommendation I made just for you. Hope this will be helpful.
PHASE I
1.) How do I reset the EOC-3220 / EOC-3220 EXT / EOC-3220+ back to factory default settings? An RS-232 null modem serial cable is required for this procedure.
(where to buy it : http://www.keenansystems.com/store/catalog/product_info.php?cPath=3&products_id=221)
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press “OK” to bring up the HyperTerminal window.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Phase II
1.) Since that you already reseted the AP you need to use the default IP which is 192.168.1.1 user: admin password: admin
2.) Make it sure you need to use different IP such as 72.10.251.xxx and the subnet: 255.255.255.xxx
3.) The idea of configuration in come from your own desire which was no body can no longer try to match your network IP so that there will be no body access your AP anymore without your knowledge.
4.) You need to make you SSID invisible to everyone inorder no body no longer able to reach your SSID by setting up basic setting which is transparent to everyone.
5) And lastly change the default user and password of your AP.
Good Luck
Posted on Nov 24, 2007
SOURCE: BELKIN Universal Repeater - 2.4GHz-802.11g - (f5d7132) Setup problems
My nephue has the same problem i told him to junk it and get a diffrent brand. He did and now he has no problem with the internet. Also I just tried to install it on my PC but all I get is a 10 seconds of internet then it does not connect after that. Thats why I was looking for any info on this problem.
Posted on May 06, 2008
Rubec
  • 42 Answers
SOURCE: dlink 2100 ap
If you default the unit, does it still reboot?
If so, it looks like the unit is faultly.
If not, you might have a IP conflict, or channel problem. Check the two units are on the same channel, but have differant IP address.
Posted on May 09, 2008
SOURCE: Asus EE PC Issues with Connecting to a wireless network.
Ok I have a new ee with linux and had all the above problems. Geek at best buy helped me understand that linux doesn't do things automatically the way windows soft ware does. It gets confused easily! Since learning to think differently and not expect things to happen automatically I've had NO problem! For starter delete every network you can in the network icon. Have it be blank. Then choose one of the wireless available and I bet you'll get on. Always go to the network icon to reconnect to an network you've used before, if you choose it from the wireless available you will start a new connection, the linux doesn't know which one to use and you see pending - not knowing why it worked once and now today you cant get on. Bottom line, until you learn to think like this operating system just delete all the networks each time, and then connect. Over time you'll learn more.........
Posted on Aug 07, 2008
TIPS72
  • 369 Answers
SOURCE: ASUS EEE PC 900 wireless lan doesn't appear on network connection
please if u have a switch for the wifi connection on your laptop please put it on and should see the wifi on your taskbar also please check in controll panel then go to my network connections and see the wifi resides there if yes just right click and enable if not ther check device manager and check for nework devices if the wifi is enable and installed ...if not please installed by right clicking on it and using reinstall..
please let me know what happens
thanks
Posted on Jan 24, 2009
Change wi-fi network
Log in to the router page with the username and password and change the SSID of the network. If you dont remember the username and password, then u might need to reset the router but ask ISP settings before you reset the router
Jul 15, 2014 | ASUS EA-N66 Dual-Band Wireless-N900...
Tip
EPrinter Not Detecting iPhone or iPad to "Airprint" or "Direct Print"
I run an ePrinter wirelessly (WiFi) off a ASUS EA-N66 wireless repeater. This tip pertains to a HP 6525 printer in case you find this attempting to correct the same problem.
When first connected everything connected except the "Airprint" features or 'Direct Print" off my iPhone and iPad. I found the default printer settings were set to "Simultaneous IPv4 & IPv6". The iPhone/iPads communicate at IPv4. Theoretically they should function in the "Simultaneous IPv4 & IPv6" setting but they did not. Changing to the "IPv4" only setting corrected the issue and the printer functions with everything I have including a WiFi PC laptop, a Wifi Mac, iPhone and iPad.
on Feb 03, 2015 | HP Office Equipment & Supplies
Setup wizard
Try doing a hard-reset on the unit. There should be a little inset button on the rear of the unit where you can press it with a pen or paperclip. With the power supplied to the unit, press and hold this button for 10 - 15 seconds until you see the indication/status lights change their pattern. Sometimes all of them will become solid lit, sometimes they will flash, just keep your eye out and look for it. If you dont notice anything, then just make sure you give the button a solid 15 second hold. It can't hurt.
After you do this, try logging into the configuration page and resume setup. Sometimes routers crash. Most all of them are built on the Linux operating system and a crash or glitch is bound to eventually happen. A proper reset usually fixes things like frozen ports, broken wifi or other problems that just seem to appear for whatever reason.
Jan 28, 2014 | ASUS EA-N66 Dual-Band Wireless-N900...
Iphone wont connect to extender
Go into the set up menu of the ASUS. ensure it is not set to 'N only'
Dec 20, 2013 | ASUS EA-N66 Dual-Band Wireless-N900...
How to connect the ASUS EA-N66R as a range extender.
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
Mar 08, 2013 | ASUS EA-N66 Dual-Band Wireless-N900...
The gui setup wizard is not popping up/opening and i cannot access www.asusrouter.com
If you're using Windows, plug the ASUS device in via wired (ethernet). Hit Start, then type in CMD, then type in ipconfig. Look for wired local area connection. Do you see 10.0.1.1? That's probably the ASUS. Now, type that in your browser. Voila, the GUI should pop up. It worked for me.
Oct 10, 2012 | ASUS EA-N66 Dual-Band Wireless-N900...
When i push the play online button and it says could not connect to ea servers for madden 10
It is likely the servers have been deactivated for sometime not due the the introduction of The PSN and Xbox live. Im not sure on this so it could be a network setup Issue. Is the PS2 connected to the internet. and does the connection work with other titles. If id does work with other Titles it may be the EA server is down.
Jun 05, 2011 | Sony PlayStation 2 (PS2) Console
Can't find any network
Same **** here .... All I am finding all over the internet is people complaining about this card. WTF how Asus could make such a pice of **** ??? My card sometimes connects to the router sometimes doesn't and when it does the speed it terrible really. Did almost everything with it so far nothing helped. I wonder if I can take it back and ask for money back.
Mar 11, 2009 | ASUS WL-138G 802.11g/b (wl138g) Wireless...
Computers & Internet Logo
198 people viewed this question
David Payne
David Payne
