Question about Frigidaire FDE336RE Dryer
REPLACE MOTOR WHAT AND WHERE DO I START TO DISASSEMBLE THE DRYER TO REPLACE THE MOTOR?
    Problem Solver:
  • 7 Answers
Start by taking the top off, you should see the motor at the top or bottom in the corner, there should be two 13mm bolts on the bracet holing the motor to the bracket, you will need to loosen these to slacken the drive belt. Once thats done undo all bolts and replace motor then follow these steps backwards!
Posted on Jan 21, 2009
I have a 14 yr old AEG 3200 dryer. The drum has stopped turning.Could this just need a simple belt replacement or wld you recommed a new dryer. Thanks
If you can hear the motor run when activated replace the belt. You should check or have checked the rollers that the drum is supported by. Check the belt tension-er replace if worn. While the unit is disassembled the rollers are easy to replace.
Vacuum all loose lint out from around the motor while disassembled.
These simple older machines are reliable and very durable and only have a few moving parts.
Hope this helps?
AEG LAVATHERM 60750225500 Tumble Dryer Section Spare Parts Diagram
Jun 21, 2017 | AEG Dryers
My Maytag Performa Dryer model PYG3360AWW wont turn on it just buzzes when I push the start button. what do I do to fix it?
See if you can turn the drum by hand, there should be some resistance. If its locked you will need to disassembly the dryer and see what is binding. If everything(motor,rollers,pullys)spins freely they you most likely have a faulty motor winding and will need to replace it.
Dec 21, 2014 | Maytag Dryers
Will not start, no light in display
I also just experienced this problem. I disassembled the dryer to replace the belt and motor, and after reassembling everything, making sure all wires were connected, the dryer would turn on but no drying level displayed
Mar 03, 2014 | Asko T731 Electric Dryer
Blower motor not always coming on
the blower wheel is attached to the dryer motor if the motor is running the blower is moving unless the shaft end is worn out the blower threads onto the motor shaft
Nov 19, 2013 | GE Profile Harmony DPGT750EC Electric...
Bad motor for pyg2300aww gas dryer?
How stiff is the motor? You can lube them sometimes and free them up for a while:
Aug 22, 2012 | Dryers
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
Overheating dryer - motor replacement???
Good day,
You said "The dryer is still overheatng". If your not describing the motor but the whole machine then that problem will have to be resolved.
Maytag's build lint up badly in the blower housing area and the duct between it and the filter. Requires disassembling the front of the dryer and cleaning that area as well as determining if the blower wheel is loose on the motor shaft requiring replacing.
If the overheating is the motor itself, then replacing it would be a common item on that brand.
May 14, 2010 | Maytag Dryers
Motor buzzes - won't start
It can be that you use engine oil to the bearing so that it will work loose . because sometimes grease can stick or carry more dirt found inthe engine .dont change the motor yet coz there is still a solution and make sure that the bearing is clean before lubricating with engine oil and place to the motor.
Mar 14, 2009 | Amana ALG866SB Gas Dryer
Hotpoint dryer
Completely disassemble your vent from the dryer to where it exits the building. Clean out all lint. Disconnect the dryer from the electrical service and check for lint build up inside the machine. This lint build up usually makes the motor shut down on it thermal overload. Check the motor also to see if the air vents on it are blocked with lint. If no lint is present, the motor or the start relay need to be replaced.
Oct 24, 2008 | Hotpoint NBXR463EBWW Electric Dryer
Dryers Logo
93 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
