Question about HP W2007 LCD Monitor
Black Bars each side of my new monitor wide screen
I have a wide screen 20" W2007 HP monitor but being disabled, I use this for making online 1000 piece puzzles and the monitor has over an inch of a black bar on each side of the screen , making it more like a 17" of useage?
HELPPPPP Please?
  • Roberta Smith
    Roberta Smith May 11, 2010
    should be an adjustment in the menu to fix that... or your video settings are not right.... vista or xp ?
    Robert
    Novelist:
    Sniper:
  • 63 Answers
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Posted on Jan 30, 2009
  • Ryan Stiers
    Ryan Stiers Feb 04, 2009
    Please let me know if this fixed your issue
How can I adjust the screen resolution?
select menu > wide, then select wide or zoom.
some TV channels add black bars to the picture.
Apr 12, 2013 | HP Compaq Presario FP7317 17" LCD Monitor
My monitor, hp w2007, shows for about 20 seconds when turned on then goes blurry then black how do i fix???
The most common problem that causes the screen to go to a black screen is due to bad capacitors in the screen's power supply board. The bad caps are the cylindrical and will appear to have bulging tops. 66c561df-0d01-416a-ae23-71f3b3965c88.jpg
Oct 24, 2010 | HP W2007 LCD Monitor
My hp w2007 moniter keeps going black after about 10 mins. of idle .turned off screensaver because i want moniter to stay on but it doesnt.
Where you go to select "no" screen saver, there should be a "Power Settings" button. Press this and in there you can set the power save feature to "never" switch off monitor. Hope this helps. Ian.
Oct 21, 2009 | HP W2007 LCD Monitor
HP w2007 LCD monitor goes off Monitor going to
Make sure that everything is connected to the monitor properly. Go to the back of it and make sure the VGA or DVI cables are secured and then check the back of the computer to do the same.
Sep 16, 2009 | HP W2007 Desktop Monitor
I play Combat Arms and am having monitor problems.
Put off the Monitor once more and get the proper performance.. Coz the some time the resolation is not matching..
Jul 10, 2009 | HP W2007 LCD Monitor
BRAND NEW MONITOR OUT OF THE BOX? DRIVER WILL NOT LOAD. DRIVER WONT LOAD FOR HP W2007 WIDE LCD MONITOR (32 BIT) HAVE DISK. (STILL WILL NOT LOAD)
This monitor doesn't need a driver installed. If you can see an image on it, you don't need the driver for it. Windows will install the default monitor driver, and that works for 99.99% of monitors on the market. You need to go into the Display control panel and change your resolution. If the monitor's native resolution isn't available as an option in the control panel, it's because your video card can't display it, not the monitor's fault.
Jun 17, 2009 | HP W2007 LCD Monitor
I just purchased an HP w2007 hp monitor. After going through all the suggested start up routines, images are stretched horizontally. I'm using XP home edition with sp 3. My resolution doesn't seem to go...
if it's a wide screen monitor then the monitor is likely doing the stretching and you have to adjust using the monitor controls (either buttons on the monitor itself or it may have come with software as well if you loaded a CD when you first installed).
Mar 31, 2009 | HP W2007 LCD Monitor
Hp w2007 blank screen
we have here , like 1000s of black screens posted here now.
all the same all with CCFL lamps. that die. same solution.
older monitors have a power saver mode inside it,
push the front button called menu, then see OSD menu
then find and turn off power saver.
if the OSD fails to show up; the CCFL are dead.
this monitor was made in 2007, and 2010 is the starting year
for ending the usage of CCFL (starting on large screens working to small)
im reading your manual for you now, free.
page 4 tells you it has CCFT (T mean Tube, L means lamp)
same same.
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=4#manual
now lets look at the page on saver. power
page 7, (its on by default ) oops !
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=7#manual
turn saver OFF
see next page 8 and turn DDC ON.
see sleep timer and turn that all off.
if you push factory reset, it the problem begins again.
bad. for you.
https://www.manualslib.com/manual/1110533/Hp-https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=8#manual
you can in fact download the whole manual.
for free. here. the site on the internet in this regard.
all old HP monitors are made for old PC 2000 year.
your PC is not 17 years old i bet.
so all this old saver stuff is now WRONG.
(all this is old school Energy Star , malarkey, )
Nov 13, 2017 | HP W2007 LCD Monitor
HP W2007 LCD Monitor Logo
1,253 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
